Author Topic: [IC]hǎitún 40 - gasket / Bluetooth 40% keyboard (Last day for GB)  (Read 22759 times)
Offline jacky
Hi,friends.
I’m Jacky,What I bring today is a small member of the chonker family- hǎitún 40!we originally wanted to call it dolphin40, but to avoid overlap with Linworks Dolphin we are changing it to Hǎitún, which means dolphin in chinese
Introducing the hǎitún, a 40% custom keyboard that's small, sleek, and smart - just like its namesake! We named it  hǎitún because these beloved animals are known for their intelligence, friendliness, and agility - just like our keyboard. With its compact size and chonky design, the Hǎitúnn matches our other animal-themed keyboards and is perfect for anyone on the go. Plus, the name  hǎitún is easy to remember and consistent with our naming convention. Get ready to dive into a world of productivity and fun with the  keyboard!
hǎitún40
GB colors :
More photo pls check here
https://markerchun.com/haitun40
_________________________________________________________________________________
Features:
  • 6063aluminum,anodized or e-coating for the surface treatment
  • 5 degree  typing angle ~2KG
  • Dimensions:313mmx129mmx28mm
  • PCB: Hotswap with bluetooth /1.2mm/black with gold trace
  • MCU:stm32f401+52810(5.0) or 51822(4.0),No switches led, support Vial and VIA,firmware code would be public
  • case material:Alu,brass
  • pcb layout :hotswap https://i.imgur.com/NS3dwIS.jpg solder :https://imgur.com/Mv5Po7E
Exploded view:
  • New gasket poron ,We tested several new materials and chose one more suitable
  • Battery compartment size 80mm x45mm x4 mm,Batteries cannot be shipped by air and need to be purchased by yourself
  • Inner frame for the gasket mount,leave more space for the bottom
  • No plate foam ,case foam available.
Groupbuy info:
  • We will release 100 kits in stock first ,groupbuy would open later
  • Default kit : Aluminum Case/e white middle frame/Brass Weight/Pc plate
  • E-white :30kits E-beige:30kits  Anodizing gray:20kits  Anodizing blue:20kits
  • In stock would have four colours ,groupbuy it may have more options !
    In stock price : $335 For Aluminum
                           $899 For Full bras pvd
  • Groupbuy time :April or earlier
Prototypes photo would post later days ,it would have streamer for reivew too ,pls join us discord to get news in time
pls fill the ic form ,if you are interested in this chonker baby  :thumb:
https://tinyurl.com/4zdsrdhn
__________________________________________________________________________________________________________
31/March Update :
1.We sent out four sets of samples and there will be live streaming and testing,stream time pls check in my disocrd (tbd)
2.We will provide batteries for free, if the delivery is not available in your area, you need to buy it yourself,DHL is the first choice for courier, and other couriers will be selected according to needs
3.In stock  and group buy will be released in April, the specific time is to be determined
4.We will decide the solder layout  as soon as possible, we will refer to these https://i.imgur.com/rsMskFB.png
5.Part of the sample pictures have been re-topped
6 IC link would closed on 1th,April
« Last Edit: Wed, 19 April 2023, 11:32:01 by jacky »
Offline jacky
Re: [IC]Dolphin 40 - gasket / Bluetooth 40% keyboard
« Reply #1 on: Mon, 13 March 2023, 05:04:58 »
 :D
Offline Sissy
« Reply #2 on: Mon, 13 March 2023, 05:16:19 »
I would suggest a name change, Dolphin is a pretty well known and iconic board already.
Offline jacky
« Reply #3 on: Mon, 13 March 2023, 06:26:33 »
Yes ,thanks for advise
Offline geekkeey
Re: [IC]hǎitún 40 - gasket / Bluetooth 40% keyboard
« Reply #4 on: Mon, 13 March 2023, 07:07:23 »
I don't care if it's a dolphin or not, I have a Piggy60 and I'm going to buy it thinking it's a smaller version of the Piggy. :))
Offline KuroTheCrazy
« Reply #5 on: Mon, 13 March 2023, 07:22:33 »
Are the enter and lshift 1.75u or 2.25u? The renders with caps look like 1.75 but the render showing switches has stabs on them.
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
« Reply #6 on: Mon, 13 March 2023, 07:40:17 »
YES
Offline jacky
« Reply #7 on: Mon, 13 March 2023, 07:45:49 »
Fixed ,render was mistake for stabs
Offline piercejenkins
« Reply #8 on: Mon, 13 March 2023, 08:19:50 »
Should have called this the Piglet!!  :cool:
Offline nickthaskater
« Reply #9 on: Mon, 13 March 2023, 09:14:30 »
Bluetooth? I'm in.
Offline neon_tom
« Reply #10 on: Mon, 13 March 2023, 09:36:06 »
+1 on this!
Offline tactilesbad
« Reply #11 on: Mon, 13 March 2023, 11:17:52 »
+1 for piglet
Offline Upstart5
« Reply #12 on: Mon, 13 March 2023, 11:46:31 »
Love the chonky 40! It's exactly what I hoped you'd be making.
I will say that the lack of split spacebar support is a huge downer and will prevent me from buying the board. Split space is very popular in the 40s community.
Offline summerqm
« Reply #13 on: Mon, 13 March 2023, 12:24:28 »
Second this! Not having the split spacebar support is a pretty big deal breaker for this otherwise great looking keeb! Please please please please consider split spacebar support 🙏
Offline dededecline
    • Linktree
« Reply #14 on: Mon, 13 March 2023, 12:40:29 »
If I could make a suggestion for a split space option that would look good, not add too much swiss cheese to the plate, and function well
Offline Upstart5
« Reply #15 on: Mon, 13 March 2023, 12:56:59 »
This would be perfect! Thank you for mocking that up so it's clear what we would like.
Offline Kuj0
« Reply #16 on: Mon, 13 March 2023, 15:07:40 »
Can't wait to see the weight design on this one!
+1 for DD's suggestion above for split space!!!
Offline Krolyk
« Reply #17 on: Mon, 13 March 2023, 15:27:12 »
Can we get split space bar support and I'm in.
Sent from my SM-S908U1 using Tapatalk
Offline Hedgey
« Reply #18 on: Mon, 13 March 2023, 15:36:58 »
So happy to see this Jacky!!
Ever since I had my Elephant I always wanted a 40 to match it.  Are you doing HHKB only or would you be open to non-hhkb tops?  Either way I'm in!
Hedgey
"Resellers don't kill the community, auctioneers kill the community. Look at what happened to Diablo 3"
Offline patcoll
  • !40s
« Reply #19 on: Mon, 13 March 2023, 15:47:16 »
100% this. Gave this feedback on IC form too FWIW.
Offline mr_foggy
  • neue = nope
« Reply #20 on: Mon, 13 March 2023, 17:13:49 »
tremendously interested. BT pcb please.
Offline jacky
« Reply #21 on: Wed, 15 March 2023, 01:28:15 »
looks nice
Offline jacky
« Reply #22 on: Wed, 15 March 2023, 09:37:02 »
i have do the solder pcb layout for this ,any advise ?
Offline summerqm
« Reply #23 on: Wed, 15 March 2023, 11:12:18 »
Thank you for considering supporting split spacebar! I will be begging for hotswap support for split spacebar layout if possible 🙏 the split layout looks good though so I will definitely be interested in one!
Offline surplusofchairs
« Reply #24 on: Wed, 15 March 2023, 11:21:48 »
i would prefer dede's version of no key in the middle of the bars, personally. this is more 60+% split style, i think
Offline mr_foggy
  • neue = nope
« Reply #25 on: Wed, 15 March 2023, 18:59:32 »
no pink??? pls consider pink :(
Offline jacky
« Reply #26 on: Thu, 16 March 2023, 00:41:23 »
check the ic form
Offline Nonnegaard
« Reply #27 on: Thu, 16 March 2023, 02:50:37 »
why are the gaskets on a beautifully polished bracket that's completely hidden when the board is closed? looks like extra cost to me, is there some reason? edit: read your explanation, still don't get it. you want the case as hollow as possible for better acoustics?
« Last Edit: Thu, 16 March 2023, 02:52:09 by Nonnegaard »
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline jacky
« Reply #28 on: Fri, 17 March 2023, 08:52:46 »
Default was alu,you dont need pay extra
Offline paperassgasket
« Reply #29 on: Fri, 17 March 2023, 22:00:09 »
2u backspace is a nice option.
That center 1.25u is awful though. Definitely not my taste. My advice is don't.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #30 on: Fri, 17 March 2023, 22:11:09 »
the 1.25u bar in the middle is unpopular. 3u spacebars are becoming more common; maybe mess with those?
Offline SDKCAMPING
« Reply #31 on: Sat, 18 March 2023, 23:36:01 »
Cute board and a really familiar (good thing) design
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Krolyk
« Reply #32 on: Sun, 19 March 2023, 15:33:29 »
Ditch the space between the space bars I think.
Offline Nonnegaard
« Reply #33 on: Tue, 21 March 2023, 09:40:15 »
untrue, theres literally an entire extra part you have to machine. why would you even make it this way.
Offline jacky
31/March Update :
4.We will decide the solder layout  as soon as possible, we will refer to thesehttps://i.imgur.com/rsMskFB.png
6 IC link would closed on 1th,April  ;D
 :thumb: :thumb:
Offline jacky
Solder pcb layout confrim :
« Last Edit: Tue, 11 April 2023, 02:41:56 by jacky »
Offline jacky
In-stock Buy Time: Apr 11th 11:00am EDT - Apr 12th 11:00pm EDT
In-stock Buy Link: https://jackylab.com/collections/h%C7%8Eitun40-in-stock
Group Buy Time: https://jackylab.com/collections/h%C7%8Eitun40-gb
Apr 12th 11:00am EDT - Apr 19th 11:00pm EDT !
« Last Edit: Tue, 11 April 2023, 09:30:09 by jacky »
Offline Lockkkk
cant miss it !keep up
Thank you for your warm service and perfect work, I have a very good experience with you :thumb:
Offline jacky
 :D Thank you
Offline jacky
Re: [IC]hǎitún 40 - gasket / Bluetooth 40% keyboard (Last day for GB)
« Reply #39 on: Wed, 19 April 2023, 11:32:45 »
Last day for this keyboard !
« Reply #40 on: Fri, 01 September 2023, 02:24:30 »
Just chiming in to say this is an amazing board and I'm super happy with it. The Bluetooth connectivity makes such an awesome difference not having a desk cluttered with wires while offering a wonderfully premium feel and aesthetic. It's flawlessly finished, sounds amazing, and is built like a tank.
If and when extras drop, if you were interested, just buy it.
Offline richardaskew
« Reply #41 on: Thu, 07 September 2023, 04:10:33 »
https://tinyurl.com/4zdsrdhn only up
31/March Update :
Hello, I am living in Chicago now. When can I receive if I ordered it?
