Author Topic: [IC] Katze - 60% O-Ring  (Read 11076 times)
Offline Dunne
    • Dunne
« on: Sat, 18 March 2023, 11:03:18 »
Katze
IC Form
A 60% O-Ring keyboard with a cat drinking wine.
Background
The board pays homage to older kustoms that of the Unikorn and OTD356mini with my own twist. Also, cats and wine are great!
The first run of Katze was a 15-unit run exclusively for the Vietnamese market (since I was based there at the time), however, since I got a lot of good responses on the first run I wanted to bring it "back home"/internationally with new revisions and updates to the initial design.
Pricing Aim & MOQ
Brass Kit w/ Alu weight: $300 - $330
Copper Kit w/ Alu weight: $305 - $335
Brass Kit w/ Brass/Copper weight: $320 - $345
Copper Kit w/ Brass/Copper weight: $325 - $350
MOQ: 50 - 100 Softcap
What's Included
- Aluminum Case/Polycarbonate Case
- Mechlovin' Kay60 PCB Variant
- O-Ring
- Brass/Copper Weight
- Aluminum/Brass/Copper Cat Weight
- Aluminum Plate
- x4 Geonworks custom molded feet
- M2.5 x4 screws for weight fastening
- Daughterboard and JST connector cable
- Carrying Case & microfibre cloth
Case Specifications
Mounting Style: O-Ring (i.e. friction-ledge assembly)
Case Material: Aluminum (6063) / Polycarbonate
Main Weight Material: Clearcoated Copper or Clearcoated Brass
Cat Weight Material: Sandblasted Aluminum 6063 (Matches case color) | Clear coated Brass or Copper | PC case - Alu weight: TBD
Case Colors:
- Alu: Purple, Burgundy, and Beige
- PC: Clear Polycarbonate
Plate Option: ANSI and ISO | 1.5mm Aluminum 5052 (Full and Half-plate) | CF and PC as add-ons
PCB Option: 1.6mm Soldered PCB | ANSI (ICing for ISO interest)
Typing Angle: 6 degrees
FH (Front Lip): 20.4mm/EFH: 21.6mm
Heft: 1.43kg unbuilt | approx. 1.7kg built
Layout Options
PCB changes may occur depending on ISO interest
(Potentially looking to add 10U spacebar compatibility, if there’s enough interest)
Media
(Katze FE/PC version shown below, is indicative of the Katze final design but solely in Aluminum)
Katze FE (near identical design, showcase reference) Typing Tests:
Katze R1 (a first-run aluminum variant for "sound" references)
Groupbuy and Timeline Information
GB Format: TBD
Vendors
US: KeebsForAll
Asia: HexKeyboards
UK: Prototypist
OCE: AllCaps
If you are a vendor and are interested in supporting this project, please email at: dw.keyboards@gmail.com
Revision Log
- Minor aesthetic revisions based on Katze FE
- Internal JST Cable channel widened
Updates
[20/03/2023]
- Added PC as a case option
- Added Brass and Copper cat weight option
- Adjusted price range aim to reflect the material option changes
To-Do
- Publish IC
- Purchase units to send to streamers/reviewers
- Establish GB format and vendors for unit allocation
Special Thanks
Quan Bot for helping since day one
Shy for bouncing ideas and helping each other out on board designs
Flyin’ for his support in all my projects
Simon for glancing for the IC before publishing it
Elaine for a quick "go ahead" inquiry on the board
Links
IC Form
Discord
Instagram
« Last Edit: Thu, 23 March 2023, 04:34:05 by Dunne »
Offline Dunne
    • Dunne
Re: [IC] Katze - 60% O-Ring
« Reply #1 on: Sat, 18 March 2023, 11:03:56 »
Reserved
[20/03/2023]
« Last Edit: Mon, 20 March 2023, 05:02:39 by Dunne »
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #2 on: Sat, 18 March 2023, 11:44:52 »
Purrfect
Offline TheGreenLion172
« Reply #3 on: Sat, 18 March 2023, 12:22:53 »
Do you ever plan on adding WKL units to the sale?
Offline krzank
« Reply #4 on: Sat, 18 March 2023, 12:46:40 »
I like it, just not sure about IC form.
IC form question: Do you want 10U spacebar compatibility?
My answer: Give me thocc
IC form question: Would you like a brass or copper option for the cat weight?
My answer: Yes
Q: Can you add split left shift support?
Offline Dunne
    • Dunne
« Reply #5 on: Sat, 18 March 2023, 13:01:34 »
My answer: Yes
- Yes= give me thocc (just some memeing…fyi)
- In the IC I’m asking about solely Alu or having the options for brass/copper. That’s why it’s a yes/no question
- I’m supporting left shift for the universal plate, depending if there are a lot of ISO users via the region selection being EU, I’ll consider revamping the current Kay60 PCB for ISO support
Offline aicyborg
« Reply #6 on: Sat, 18 March 2023, 21:28:50 »
If it's a solder PCB anyway it should have as much support as possible, including ISO. If you'd prefer fixed ANSI plates that's one thing but the PCB should certainly have it.
« Last Edit: Sat, 18 March 2023, 21:30:37 by aicyborg »
Offline Dunne
    • Dunne
« Reply #7 on: Sun, 19 March 2023, 00:47:09 »
Yeah I see what you mean - that’s the rational of an IC, to gauge interest to determine if I modify the PCB entirely, potentially make it a split case incl./excl. PCB option, etc. Regardless, I am talking with Flyin about ISO support and I’ll likely add more support to the PCB
Offline Oogtug84
« Reply #8 on: Sun, 19 March 2023, 01:20:56 »
Cute, just curious why the negative space where the cat is holding the wine?
Offline Dunne
    • Dunne
« Reply #9 on: Sun, 19 March 2023, 01:31:53 »
They are 2 different weights. If it was only a single weight, there’d be different leveled extrusions. The cat weight has an unpolished portion to it, to bring out more layers. I think that’s your answer?
« Last Edit: Sun, 19 March 2023, 01:40:16 by Dunne »
Offline Dunne
    • Dunne
« Reply #10 on: Mon, 20 March 2023, 05:04:52 »
For the time being no, due to the number of necessary design elements to run a one-piece WKL Katze variant, but I will keep it in mind!
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #11 on: Mon, 20 March 2023, 13:09:38 »
I really like this but I just can't get behind the way the weight looks with that cutout in the middle of it.
Offline Dunne
    • Dunne
« Reply #12 on: Tue, 21 March 2023, 14:10:41 »
« Last Edit: Tue, 21 March 2023, 14:12:31 by Dunne »
Offline Dunne
    • Dunne
« Reply #13 on: Tue, 21 March 2023, 14:11:21 »
That look is only for this variant since it’s SS polished and unpolished. I won’t offer this kind of finishing anyway.
Offline whitewolf154
« Reply #14 on: Tue, 21 March 2023, 17:54:41 »
So how will the weight of the production version look like?
Offline RzrRaptor
« Reply #15 on: Tue, 21 March 2023, 19:19:24 »
Love how it looks, just wondering what it meant to have a 100 soft cap in terms of moq?
Offline Dunne
    • Dunne
« Reply #16 on: Wed, 22 March 2023, 02:34:34 »
It would look like this via a render (please take the render with a grain of salt though, since I can't render to save my life):
or if imagined, the weight has a single uniformed finish (sandblasted, and clear coated) on this close-up of the SS weight:
Offline Dunne
    • Dunne
« Reply #17 on: Wed, 22 March 2023, 02:43:30 »
The 50 MOQ is the highest price and anything above 100+ would be the lowest price that I am aiming for, but prices may change due to numerous variables. Hope that is what you're wondering about!
Offline KFOXE
« Reply #18 on: Fri, 26 May 2023, 21:34:10 »
Curious to see what type of purple you have in mind for the case.
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #19 on: Sun, 28 May 2023, 01:59:09 »
Definitely feel that there should be ISO Support on that PCB, and I also don't like that back weight and how that section between the cat and the wine glass the cat is holding is a light grey compared to the rest of the weight minus the cat being a darker grey, it doesn't look as good as it could be. The board does seem fine otherwise so GLWIC
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
