Author Topic: [GB] LM60 V2 - 60% - Now with back weight  (Read 174030 times)
Offline daviddgm
« on: Sat, 25 March 2023, 20:21:38 »
[GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount
Now with back weight!
LM60 update with thin borders and tadpole/rubber soft mount
Mount type
Tadpole from Geonworks (will be included - MOQ 40 sets)
Mount Shock Absorption Balls - used in drones (will be included)
Silicone wire seals - Little more flex than above option (will be included)
Alternatively It can be top mount using 8x M3 screws.
The plate
Details
Top Aluminum
Bottom Aluminum
Side RGB led light through Polycarbonate (no RGB available)
Case Angle: 6.5 degrees
Mounting: Silicone Tadpole from Geonworks or Rubber Shock Absorption Balls
Case Material: 6063 aluminum
Making process: CNC - sandblast - anodizing
Front Height: 19 mm
Back Height: 21 mm (with chamfer) and 32 mm (before chamfer)
Weight: ~1400g and ~1800g (mounted with brass plate)
Plate:  Aluminum, Brass, FR4 (PBT on demand)
PCB Compability: GH60 style (GH60, DZ60, BM60, etc) for LM60 V2; DZ65RGB and BM65RGB (and others) for LM65 V2
Prototype
We made in this color because the factory just offered black or this for the sample.
Without PC inserts, but it will be included. No hole for RGB is available too.
https://youtube.com/shorts/AF4tVdQx4gs
https://youtube.com/shorts/sNy4kU_97B4
What will be included
- LM60 V2 Top
- LM60 V2 Bottom
- Plate
- Stainless screws
- Silicone Rubber Mounts (Mount Shock Absorption Balls)
- Tadpole from geonworks (if MOQ 40 sets sold)
- Silicone Rubber feets
- Polycarbonate inserts for the RGB pockets
Timeline and fulfillment date
Nov/Dec: 14-05 Group Buy
Dec/Jan: Production
Jan/Feb: Shipment (Will be available: Aliexpress forwarding, Fedex/DHL and Germany forwarding to EU).
Price
One set USD 140.00
Two sets USD 235.00
Thee sets USD 325.00
Solder PCB USD 25.00
Solder PCB with RGB underglow USD 28.00
Hotswap PCB (with RGB Underglow by strip) USD 30.00
130pcs Hotswap pin sockets 1.5mm USD 15.00
Extra plate USD 20-30.00
Order Link
https://www.dgmelet.com/opencart/index.php?route=product/product&product_id=558 (the payment is processed by PayPal)
(For two and three sets - contact us for color and options)
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=559
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=560
The second order option: Pay 30% in advance (PayPal) and others 70% more shipping by Aliexpress link when your LM60 V2 is done, before the shipment.
Regards,
Eng. David Martinz - LM Keyboards
daviddgm at gmail
@lm_kbd
« Last Edit: Wed, 10 January 2024, 08:33:16 by daviddgm »
Re: [GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - Mar 26 to Apr 23
« Reply #1 on: Thu, 30 March 2023, 10:51:24 »
Approved :thumb:
Offline ampp33
Re: [GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - Mar 30 to Apr 26
« Reply #2 on: Thu, 30 March 2023, 16:36:46 »
Killer!  What layouts does the plate allow?
Offline daviddgm
« Reply #3 on: Thu, 30 March 2023, 19:50:08 »
I think it support all layouts. I have added the plate drawing image. Thank you.
Offline LMarci
« Reply #4 on: Thu, 30 March 2023, 19:56:23 »
I want one :thumb:
Offline DirtyGingy
« Reply #5 on: Thu, 30 March 2023, 20:00:00 »
so, your link talks about an LM65 v2 that uses the dz65 PCBs. When is that dropping so I can support your work?
Offline daviddgm
« Reply #6 on: Sun, 02 April 2023, 04:59:05 »
Hi. We are planning to make on the second bulk order... If we decide to make on this first I you tell you.
Offline Nuap
« Reply #7 on: Sun, 02 April 2023, 19:59:10 »
I want the board but only if it can be tadpole mount. Can you tell us when the MOQ of 40 units is met so I can be sure that I am ordering a unit with these included?
Offline daviddgm
« Reply #8 on: Tue, 04 April 2023, 07:03:56 »
Ok. Thank you.
Offline daviddgm
« Reply #9 on: Tue, 04 April 2023, 07:04:39 »
Added another order/payment option.
Offline daviddgm
« Reply #10 on: Mon, 10 April 2023, 06:27:27 »
Added price condition for 2 or 3 sets.
Offline erifis
« Reply #11 on: Mon, 10 April 2023, 10:29:08 »
Is it possible to order each LM60V2 in different colors and specifications on the product page for a set of two?
For example, if I want to buy a blue case and a black case, I know that I need to add each to the cart separately on the individual item page.
Offline daviddgm
« Reply #12 on: Mon, 10 April 2023, 12:45:24 »
Yes, you can contact for different color and specs of the second or use this product link as the second one:
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=561
« Last Edit: Mon, 10 April 2023, 16:28:49 by daviddgm »
Offline daviddgm
Re: [GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - Last week
« Reply #13 on: Tue, 18 April 2023, 18:22:16 »
Does anyone have interest in front bezel with angle?
Last week of GB!
Offline daviddgm
« Reply #14 on: Fri, 28 April 2023, 07:09:25 »
Thank you for the orders. Now we are starting the production. For those still want to buy, is possible in the next days, because we are making on the batch (CNC stage) few sets without confirmed layout/color.
« Last Edit: Fri, 28 April 2023, 09:40:08 by daviddgm »
Offline moonsearch
    • Visit our website
Re: [GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - In production
« Reply #15 on: Fri, 05 May 2023, 20:49:57 »
Really dig that brown colour
Offline erretter
    • My Merch Shop
« Reply #16 on: Mon, 08 May 2023, 01:42:43 »
Just bought the brownish/beige/bronze one, because it's so unique overall, not just the color.
Question: Where and what is the best way to follow you for updates on this project? Newsletter, this thread right here, discord?
Offline daviddgm
« Reply #17 on: Tue, 09 May 2023, 13:03:49 »
Thank you for the order. We will post here the updates. The factory says that will begin the CNC this week. When receive the video we will post It on Instagram and Youtube.
@lm_kbd
LM keyboards
Offline daviddgm
« Reply #18 on: Sat, 20 May 2023, 15:07:15 »
Please check the progress on our Instagram. https://www.instagram.com/reel/CsekdfEOIfm/?igshid=MmJiY2I4NDBkZg==
PS. This top with front angle on reel is customization for a group of 8 customers on the Group Buy.
Offline erretter
    • My Merch Shop
« Reply #19 on: Sat, 03 June 2023, 10:28:55 »
Wait a second...
https://dgmelet.com/opencart/index.php?route=product/product&product_id=558&search=lm60v2
It's now showing as in stock?!
Shouldn't that be posted as an update anywhere?!
What's going on?
I also didn't get a shipping confirmation.
Please update on the situation.
Offline daviddgm
« Reply #20 on: Mon, 05 June 2023, 08:41:07 »
Dear, still on anodizing phase. I think we can start to ship with 10-15 days.
New orders will be accepted only for the next GB run, Jul/Aug.
Wait a second...
What's going on?
Offline daviddgm
Re: [GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - starting to ship
« Reply #21 on: Tue, 13 June 2023, 04:00:08 »
The sets are finally done. Please check the videos on our Instagram @lm_kbd
We will start to ship to the customers.
Thank you.
« Last Edit: Tue, 13 June 2023, 05:20:37 by daviddgm »
Offline daviddgm
Re: [in-stock] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - 70% shipped
« Reply #22 on: Thu, 29 June 2023, 18:58:56 »
Hi!
We have 6 sets available in stock for sale with immediately shipping.
WKL Black
WKL Beige Grey
WKL Navy
WKL Light Green
WKL Light Blue
WKL Grey
*all with front angle
Thank you.
Offline erifis
« Reply #23 on: Fri, 07 July 2023, 05:50:18 »
When will the remaining 30% be shipped?
I'm curious because my purchase is still PENDING.
Offline daviddgm
« Reply #24 on: Fri, 07 July 2023, 11:41:08 »
All shipped, remain just one to California because we are waiting a  confirmation from him.
Who are you (name, order number or destination)?
Thank you.
Offline erifis
« Reply #25 on: Sat, 08 July 2023, 01:20:29 »
Thank you.
Is it true?
Here is my purchase information.
Please tell me about the current status of my current purchases.
Order ID: #312
Payment Method: PayPal
Shipping Address:Tokyo Japan
Order History:02/04/2023   Pending
LM60 V2 Aluminum Case Mechanical Keyboard
  - Plate Material: Brass
  - Layout: WKL
  - Anodizing Color: Blue
  - RGB Pocket: Without
Offline daviddgm
« Reply #26 on: Sat, 08 July 2023, 04:25:08 »
We sent your tracking by email. Thank you.
Thank you.
Is it true?
Order ID: #312
  - Layout: WKL
Offline erifis
« Reply #27 on: Sun, 09 July 2023, 00:03:53 »
Thank you for sending me the tracking number.
My item arrived safely and is now on my desk.
Thanks for the great keyboard!
https://imgur.com/a/nUEJcE5
Thank you.
Is it true?
Order ID: #312
  - Layout: WKL
Offline daviddgm
Offline daviddgm
Re: [GB] LM60 V2 - 60% WK WKL HHKB rubber/tadpole mount - 2nd round Live
« Reply #29 on: Sat, 05 August 2023, 05:37:35 »
Hi! The second round of Group Buy is open.
Offline daviddgm
LM60 V2 is now available in full polycarbonate or bottom polycarbonate and aluminum top.
PS: Not in stock, but Group Buy.
Offline daviddgm
Re: [GB] LM60 V2 - 60% - Now with back weight (live)
« Reply #31 on: Tue, 14 November 2023, 07:51:26 »
Live again! Now with back weight option.  ;)
Offline Veronicagc
Re: [GB] LM60 V2 - 60% - Now with back weight - Last day
« Reply #32 on: Tue, 05 December 2023, 13:18:58 »
Ordered mine in champagne color on the last day.  :)
Offline suparnemo
« Reply #33 on: Sun, 07 January 2024, 12:21:50 »
Is it still available? Shows in stock on your website
Offline daviddgm
« Reply #34 on: Wed, 10 January 2024, 08:32:54 »
Hi! Available to order, but delivery within 45-60 days.
« Last Edit: Wed, 10 January 2024, 10:42:06 by daviddgm »
Offline geec
  • Noob
Any photos of the polycarbonate case?
Offline daviddgm
We just have photos of others designs made in PC by the factory.
« Last Edit: Wed, 17 January 2024, 11:02:19 by daviddgm »
Offline daviddgm
« Reply #37 on: Thu, 29 February 2024, 16:29:21 »
We are selling just 10 sets by the cost price of USD 80/set to reach MOQ. Does anyone interested?
« Reply #38 on: Fri, 19 April 2024, 03:12:23 »
What sets do you have? will there be another wave?
Offline erretter
    • My Merch Shop
« Reply #39 on: Fri, 03 May 2024, 12:05:39 »
I got the V1 and I'm kinda confused. Would like a straight answer (even if just an estimate):
If I order now, when will the shipment happen?
Offline daviddgm
« Reply #40 on: Sat, 04 May 2024, 06:57:16 »
Are you interested in V2?! We have light blue and light green in stock. For V2 customized we are still accepting the orders... To be delivered within 50-60d.
« Last Edit: Sat, 04 May 2024, 07:10:03 by daviddgm »
