Author Topic: What switches does blue G710+ keyboard have?  (Read 5583 times)
Offline 10basetom
« on: Thu, 06 April 2023, 16:04:18 »
I have this Logitech G710+ keyboard that has the blue trim I got many years ago. I don't have keycap pullers...does anyone know what switches are used by the blue G710+? I can't tell whether they are Blue or Brown switches.
I'm confused because the G710+ usually comes with Brown switches, but those have the orange trim. The G710 comes in blue trim and has Blue switches. I can't find anything on the G710+ with blue trim. My hunch is since it has the blue trim it likely has Blue switches, but wanted to verify here.
Offline Sup
Re: What switches does blue G710+ keyboard have?
« Reply #1 on: Thu, 06 April 2023, 16:41:11 »
well does it make a clicky sound its blue, If it doesn't make a clicky sound but you feel tactility its brown. You just feel smooth all the way to the bottom its linear.
current
Coming soon
Offline 10basetom
« Reply #2 on: Thu, 06 April 2023, 16:59:08 »
I know it's not linear because I can feel the tactile bump. I'm having a hard time telling the difference between Brown vs. Blue sounds though. Attached is the recording...
Offline Sup
« Reply #3 on: Thu, 06 April 2023, 19:26:51 »
clicky for sure.
current
Coming soon
Offline 10basetom
« Reply #4 on: Fri, 07 April 2023, 01:30:41 »
Cool thanks man. I had a feeling it was blue from the blue trim  ;D
