Author Topic: [IC] Habitat Keycaps | GB LIVE 28 Feb - 28 Mar  (Read 20960 times)
Offline switchlab.sg
« on: Sun, 09 April 2023, 04:37:35 »
GB LIVE
GB THREAD
GB is now LIVE
Switchlab here and welcome to the interest check for Habitat keycap set
INSPIRATION
The Inspiration
Inspired by nature, greenery and the profound impact it has on our mental wellbeing,
"Habitat" brings harmony to your keyboard setup while fostering a sense of tranquility in our digital lives.
The design blends botanical elements with soft shades of green, beige and earthy tones, evoking a sense of calm and serenity.
Beyond aesthetics
"Habitat" is a gentle reminder to prioritize self-care and tranquility. Just as plants thrive when nurtured,
so too can your mental wellbeing. By bringing nature indoors it allows us to reconnect with it amidst the digital chaos.
INTEREST CHECK
IC FORM
KITTING
PBT Dye Sub
Cherry Profile
1.7mm thickness
Base: $89
Deskmat & Pricing
Polyester
Standard - $22
60-65 - $14
900 x 400 x 4mm
355 x 152 x 4mm | 60 - 65%
COLLABORATIONS
Will be updated as it goes
Artisans - HIBI
Artisan - temo.studio
Custome themed cable - LoobedSwitches
SCHEDULE
GB: 28 FEB - 28 MAR
Fulfilment: Q3 2024
RENDERS
VENDORS
US - LoobedSwitches
CA - Ashkeebs
EU - Keygem
SEA - Switchlab
KR - MonstarKbd
OCE - Allcaps
SOCIALS
Instagram
Discord
SIGNATURE
If you like this project, do consider showing support with the signature!
[/more]
« Last Edit: Tue, 27 February 2024, 11:01:58 by switchlab.sg »
Re: [IC] PBT Habitat by Switchlab
« Reply #1 on: Sun, 09 April 2023, 06:03:02 »
UPDATES
Receiving sample kits soon and finalizing GB dates as well as US vendor
« Last Edit: Thu, 18 January 2024, 07:37:40 by switchlab.sg »
Offline Rhienfo
  • GOTHETIGES
« Reply #2 on: Sun, 09 April 2023, 06:49:36 »
With the kitting, there is no 1.5u backspace (R2). If your including the rest of hhkb/tsangan support then you should definitely include it. Also not the biggest fan of the center left alphas and would prefer to keep them in the top left, but that's just preference, I assuming that was a design choice you made?
« Reply #3 on: Sun, 09 April 2023, 09:16:56 »
Thanks for the feedback! We will add the 1.5u backspace however we might have to replace it with the green accent pipe. The legends placement is part of the design.
Offline Cylent
  • Formerly cylentshadows
Re: [IC] Switchlab PBT Habitat
« Reply #4 on: Sun, 09 April 2023, 14:24:29 »
Yo the alpha arrows need to stop.
« Reply #5 on: Tue, 11 April 2023, 04:16:07 »
I'm not sure what you mean by stop?
Re: [IC] Switchlab PBT Habitat | Vendors Confirmed!
« Reply #6 on: Thu, 20 April 2023, 00:18:18 »
Updates for the IC
1. Keycap legends have been adjusted
2. Vendors are confirmed
3. Artisan keycap confirmed (HIBI). Final design TBC
Re: [IC] SL PBT Habitat | Vendors Confirmed!
« Reply #7 on: Tue, 30 May 2023, 00:10:08 »
HIBI Artisan Design is now confirmed with renders!
Offline HealthyMental
« Reply #8 on: Mon, 05 June 2023, 00:19:11 »
I enjoy this colorway along with the kit size for a good price.
« Reply #9 on: Sun, 11 June 2023, 22:56:15 »
Thank you! We're awaiting the color samples now.
Offline shansoft
« Reply #10 on: Mon, 12 June 2023, 01:22:00 »
The color looks very similar to the GMK Hanami Dango.... which color matching screwed the set completely.
Looking forward to this set as the alternative!
« Reply #11 on: Mon, 12 June 2023, 02:53:12 »
How did they screw up the color matching? The set looks very saturated overall.
We're going for a more pastel/smokey palette.
« Reply #12 on: Fri, 16 June 2023, 04:56:48 »
Quick update.
Adjusted the colors for the novelties and we're close to finishing the color proofing.
We will adjust the renders to match it closer to the samples once the color has been confirmed.
Offline seemovn
Re: [IC] SL PBT Habitat | New Collab announcements
« Reply #13 on: Sat, 16 September 2023, 09:19:59 »
Super hyped for the caps! Any news on when and if the GB might happen?
Edit: ah, just saw that you changed the GB time to Q4 2023, that answers my question :)
Offline SirYeetWilliams
« Reply #14 on: Sun, 17 September 2023, 13:21:16 »
plants? yep. I'm in!
Sofle+ user.
Colemak enjoyer.
Unnecessary GB addict.
« Reply #15 on: Wed, 04 October 2023, 07:45:06 »
UPDATE
Sample kits are being finalized at the moment. I'm pretty confident that it'll be ready for launch this year.
Re: [IC] SL PBT Habitat | GB Update on samples
« Reply #16 on: Thu, 18 January 2024, 07:38:46 »
Finalizing the samples and GB date.
« Last Edit: Sun, 21 January 2024, 05:27:28 by switchlab.sg »
Re: [IC] Habitat Keycaps | GB Date confirmed!
« Reply #17 on: Mon, 05 February 2024, 03:23:29 »
GB Date
28 FEB - 28 MAR
Fulfilment ETA - Q3 2024
Offline Neongreen
« Reply #18 on: Wed, 07 February 2024, 09:34:41 »
Any chance for a metal artisan that’s solid green and engraved? I like the monochrome look but seems like artisan monochrome keycaps aren’t that common.
« Reply #19 on: Fri, 23 February 2024, 03:24:25 »
Hey, we're currently only collaborating with HIBI for the artisan. Sorry about that!
Re: [IC] Habitat Keycaps | GB LIVE 28 Feb - 28 Mar
« Reply #20 on: Tue, 27 February 2024, 11:02:10 »
GB is now live!
