Author Topic: 122key 1397000 USB woes  (Read 4718 times)
Offline Hanno
« on: Wed, 19 April 2023, 16:29:09 »
Hey there, I have an old IBM 1397000 terminal emulator board that I recently pulled out of storage that I've been trying to get it to work on my windows machine.
My previous build's motherboard had a PS/2 port, and with some old 122 dlls I had managed back then to get all f-13 to f-24 keys and the sidebar keys outputting scancodes, which I then rebound using ahk/swiftkey.
Now, however, my new rig has no PS/2, and while the usb converter I have seems to work... Not the top row or sidebar. It only does only up to f12, and maybe a few other keys smattering here or there. They seem to output no scancodes at all when pressed. Is this a problem with the converter? Or something else? I'm kinda stumped on how to proceed.
Any help would be appreciated!
Offline Tactile
Re: 122key 1397000 USB woes
« Reply #1 on: Wed, 19 April 2023, 21:21:05 »
This info makes it seem like you'll need Soarer's Convertor.
REΛLFORCE
Offline Hanno
« Reply #2 on: Wed, 19 April 2023, 22:52:09 »
Thank you, I'll pick up a Soarer's converter and report back
Offline Hanno
« Reply #3 on: Tue, 25 April 2023, 02:22:43 »
I'd like to report  the PS/2 Soarer's converter I bought from orihalcon on ebay worked a treat.
I was able to remap all extra keys with the help of the included documentation in the 1.10 software, utilizing scaswr.bat
Thank you for your help!
« Last Edit: Tue, 25 April 2023, 02:49:57 by Hanno »
