Author Topic: [GB] V81 PLUS by FinalKey  (Read 7608 times)
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« on: Sat, 29 April 2023, 11:07:10 »
Finalkey’s newest creation is now officially revealed.
Same unique design language with the V65, more functions, and also looks bolder  :cool:
75% layout
Anodized aluminum kit
Customizable LCD screen
3 modes
Gasket-mount structure
FNK V81 PLUS
Price: $130
Worldwide shipping
Pre-order link: https://iconlabsofficial.com/product/gb-finalkey-v81-plus/
Pre-order now and fulfillment starts in June 2023
SPEC LIST:
1.6mm PCB, hot-swapable (No RGB)
3 modes: Bluetooth, USB 2.4Ghz receiver and wired mode (USB type-C).
4 colours: black/white are spray paint, red/navy blue are anodised
Gasket Mount
QMK/VIA Support
135*240 LCD screen support display of connection mode, time, date, charging, low power
Screen support custom GIF via FinalKey's software
PVD Aluminum USB dongle storage compartment cover
Inside the box includes:
Aluminum alloy case*1 | 3 mode PCB*1 | Type-C daughter board*1 | 135*240 pixel LCD screen*1 | PC plate*1 | A set of PCB mounted stabilizers | 3000mAh lithium battery*1 | Wireless 2.4G signal receiver*1 | Aluminum alloy sandblasting PVD storage compartment cover*1 | A set of silicone feet pad | USB-C cable*1 | Poron Gasket strips one set | Poron plate foam*1 | ixpe PCB foam*1 | Poron socket foam*1 | Poron case foam (flat)*1 | Keycaps and switch puller*1
Thank you everyone  :thumb:
More pictures on the pre-order link
Re: [GB] V81 PLUS by FinalKey
« Reply #1 on: Mon, 01 May 2023, 13:47:04 »
Approved :thumb:
    • Iconlabs
« Reply #2 on: Mon, 01 May 2023, 20:51:28 »
    • Iconlabs
« Reply #3 on: Thu, 04 May 2023, 10:44:37 »
The GB will be extended for 5 more days. So it will officially ends on the 10th of May, 2023. Hurry up guys.
    • Iconlabs
« Reply #4 on: Sat, 06 May 2023, 09:15:27 »
Instead of USPS, Fedex will be the chosen shipping service. So basically it takes maximum 10 days to get to your door  :eek:
