Author Topic: Split60 - A Split 60% Board HHKB/WK - Group Buy Live!  (Read 28136 times)
Offline 0ldMate
« on: Tue, 02 May 2023, 10:02:24 »
Introducing the Split 60
This is the second board I've designed, following the Let's Tango. After many years of waiting for someone to design a split 60% made from aluminium I've decided to make it myself.
As the market is quite rough for mid-range boards I am happy to modify the board to reach certain price points to make sure the board runs. Also, I am planning on commissioning a design for the back of the board by the same artist behind the Fever Dreams Deskmat.
This current iteration of the board is made from aluminium and brass and includes the following features:
Features
- Spit 60% design
- HHKB or WK top piece
- 7 degree typing angle
- Top mount design
- Swappable plate - both 1.5mm and 3mm options
- Brass weight
- Swappable divider pieces
- Optional tenting support
Price
Price is TBD at the moment. Depending on the interest and feedback I hear, I may scrap the weight and make the divider pieces part of the bottom case, this would reduce the cost by quite a bit. It comes down to what I hear  :D
Colours
Currently the plan is to produce this board using recycled aluminium for the case. Using this material makes annodisation difficult beyond black and silver. However, ecoating is available in several different colours. Colour choices will be determined shortly.
Topruh?
EC PCB Confirmed. It is in production currently!
Prototypes
There are currently 2 prototypes (one HHKB, one WK), both have faults on my design and will be fixed. I am planning on getting a second prototype produced after these changes have been finalized.
Currently there are no plans for WKL.
First look photo gallery: https://postimg.cc/gallery/RMPBcP8
Discord for updates: https://discord.gg/sbxZQUnfax
IC Form: https://docs.google.com/forms/d/e/1FAIpQLSfxAiN4g2FXgBJVsy9CMcoua9onC51ZlNGHPf0AGq83z2p0cQ/viewform
2nd IC Form: https://forms.gle/7ojK9ECisrVtMZDY9
Thanks everyone!
0ldMate
TO DO
Modify design to fix prototype faults
Gather IC feedback
Alter design based on feedback
Commission back weight art
Prototype Round 2
Modify Prototype 2
Figure out if GB will happen
UPDATES
June 20 2025
Prototype has been done and built. EC PCB functions. Just finalizing pricing.
Build Vod Here
9 March 2025
Prototype 5 done. We're going for one last prototype. EC PCB Done. Pictures done! If you're interested, please fill out both IC forms. Discord will get the most recent updates. This will swap back to 1.5mm plate. Further photos of the protos - https://imgur.com/a/split60-new-proto-uvQzbU1
14 Jan 2024
Prototype 2 Youtube build done. Pics in progress (currently available in discord).
3rd May 2023
IC Created
« Last Edit: Fri, 04 July 2025, 17:46:04 by 0ldMate »
Offline Rafa_n
Re: Split60 (Name TBD) - A Split 60% Board HHKB/WK
« Reply #1 on: Tue, 02 May 2023, 10:12:09 »
reserved and please clean your usb cable
Offline hzh0525
« Reply #2 on: Tue, 02 May 2023, 11:34:54 »
please clean your usb cable or replace it ....
Offline edenfires
« Reply #3 on: Tue, 02 May 2023, 14:32:06 »
friendship ended with kendo now split60 is my best friend
Offline 0ldMate
« Reply #4 on: Tue, 02 May 2023, 17:48:25 »
It has now been cleaned :D
I was waiting for Kendo also but decided to put my own spin on it. Though kendo is a classic piece and I hope they do make it at some point.
Offline SwitchKeys
    • SwitchKeys
« Reply #5 on: Tue, 02 May 2023, 21:21:21 »
Disagree with comments about the cable, I think it adds character.
Great work. Really clear and concise IC, progressive design that is open about the current flaws etc.
Best of luck with IC! Great little project.
Offline 0ldMate
« Reply #6 on: Tue, 02 May 2023, 22:22:01 »
Thank you SK :) Much love!
Offline Oni
« Reply #7 on: Wed, 03 May 2023, 05:16:30 »
Glad to see another split HHKB after no activity on the Kendo IC for a long time! Will spacebar layout support be limited to what's shown in the prototype photos?
Collection: Special Whale, Montage, Infinitum, Kei
Offline 0ldMate
« Reply #8 on: Wed, 03 May 2023, 07:09:22 »
Agreed! I waited a few years for Kendo with no word of it being made I thought I'd make my own spin on the split 60% design.
There are a few different layouts supported on the hotswap PCB bottom row, there will be more on the Solder too. The HHKB version I think fits, that was just a dry build (no pcb) for pictures.
Offline ESJvR
« Reply #9 on: Wed, 03 May 2023, 15:40:31 »
ne iso avail?
Offline 0ldMate
« Reply #10 on: Wed, 03 May 2023, 18:00:39 »
ne iso avail?
No plans at the moment unfortunately
Offline kajahtaa
« Reply #11 on: Wed, 03 May 2023, 18:05:10 »
Looks really fun.  Good luck.
BTW - Kendo was Tesletron?
Hahahhaha. Good luck for people waiting on that.
Offline phatmasterq
« Reply #12 on: Wed, 03 May 2023, 20:15:48 »
strolled over from AUMK on FB to show some love. git it oldmate - great job and GLWIC.
Offline Oni
« Reply #13 on: Thu, 04 May 2023, 04:21:50 »
For the HHKB version would something like 3u space bar on each side be possible with the solder PCB?
Offline 0ldMate
« Reply #14 on: Thu, 04 May 2023, 19:14:57 »
Thank you :)
So the KLE atm looks a bit like this. Note that the blocks for HHKB are 1.5U so you just ignore the control on the left and right.
Offline Oni
« Reply #15 on: Thu, 04 May 2023, 23:05:09 »
Thanks for sharing that KLE! Will be following this IC and hoping to see this board in GB eventually
« Last Edit: Thu, 04 May 2023, 23:06:43 by Oni »
Offline brln
« Reply #16 on: Fri, 05 May 2023, 16:21:41 »
cool
Offline Mr Chrome
« Reply #17 on: Thu, 11 May 2023, 07:38:09 »
This is top tier! I’m a tenting fan and would prefer it without the weight myself.
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline anatworkaccount
« Reply #18 on: Thu, 11 May 2023, 12:34:43 »
Very cool. More split boards is always a plus
Offline armani_
« Reply #19 on: Wed, 17 May 2023, 03:46:46 »
Looking at this has me excited. Sweet work and I look forward to seeing how this turns out!
Finally can give up on Kendo
Offline roostrc0gburn
  • its just plastic
« Reply #20 on: Wed, 17 May 2023, 17:46:39 »
gave up on kendo a while ago, but yeah definitely interested in this project now
Offline brln
« Reply #21 on: Wed, 17 May 2023, 19:52:21 »
If this would become reasonably available from within the EU, I'd greatly appreciate it
Offline thornkin
« Reply #22 on: Fri, 19 May 2023, 04:30:18 »
Not enough split keyboards in this world.  A well built contender is much appreciated.  Looks great!
Sent from my SM-G991U using Tapatalk
Offline 0ldMate
« Reply #23 on: Sat, 03 June 2023, 19:20:52 »
I waited so long :(
Glad to hear :D
I can't agree more. Split boards are my favourite!
Offline niakulah
« Reply #24 on: Sat, 03 June 2023, 20:51:28 »
Oh look, it's the HH  KB
Offline ilikerustoo
« Reply #25 on: Sat, 09 September 2023, 00:12:32 »
I'll take one
Offline Zeelobby
« Reply #26 on: Sun, 10 September 2023, 10:01:12 »
I just want one nice split to make it to GB. Lol
Sent from my CPH2451 using Tapatalk
Offline 0ldMate
« Reply #27 on: Sat, 13 January 2024, 22:33:09 »
Prototype 2 Built
Offline brln
Re: Split60 (Name TBD) - A Split 60% Board HHKB/WK (Prototype 2 Build Video)
« Reply #28 on: Mon, 15 January 2024, 13:41:13 »
Very nice! How is the tenting support going to look like?
Offline 0ldMate
« Reply #29 on: Mon, 15 January 2024, 15:21:44 »
There are two holes in each side of the base that can have tenting posts poked into. :)
Offline brln
« Reply #30 on: Mon, 15 January 2024, 17:55:14 »
 :thumb:
Offline JoltFX
« Reply #31 on: Fri, 23 February 2024, 17:29:40 »
Here for this, sad to see kendo belly up but excited for what appears to be a solid alternative
Offline Woovie
« Reply #32 on: Sat, 24 February 2024, 01:33:30 »
Beautiful board, really interested to see this come to life.  :thumb:
Offline vincen44
« Reply #33 on: Thu, 25 April 2024, 00:21:42 »
Hype. I've been dying for one of these since the kendo thread. Please follow through!
Offline 0ldMate
Re: Split60 - A Split 60% Board HHKB/WK (New Proto Pictures)
« Reply #34 on: Sat, 08 March 2025, 19:18:10 »
Updated IC. Almost there.
« Reply #35 on: Sat, 08 March 2025, 20:20:06 »
Thank you :)
wasn't sure about this but the layout options presented here make this quite tempting
2/1 and 1/2/1/1.5 is ideal
Offline 0ldMate
« Reply #36 on: Sat, 08 March 2025, 20:24:52 »
Thank you :)
For the final sale, I will need to review this to make sure these work. On the EC PCB a lot of these layouts won't be available (due to limitations on that front), on MX, a lot will be from what I can see. However, I'll finalise and will include a layout picture on GB.
Offline brln
« Reply #37 on: Sat, 08 March 2025, 23:31:59 »
I'm in
Offline Gemmmmmmmmmmmmmy
« Reply #38 on: Sun, 09 March 2025, 16:52:51 »
Damn cool! I like this idea a lot, GLWIC
Life seems so much smaller
Swim to the moon
Offline kentdo10
« Reply #39 on: Fri, 14 March 2025, 23:35:48 »
Better throw in some WKL too bro hahah
Offline 0ldMate
« Reply #40 on: Wed, 19 March 2025, 16:40:46 »
Heyo, no WKL on this, sorry
Offline KeyNewb
« Reply #41 on: Fri, 18 April 2025, 00:57:27 »
Wireless! I need Bluetooth wireless!  ;D
Offline quaks
« Reply #42 on: Tue, 13 May 2025, 05:06:16 »
Thank you :)
What about support for stepped caps?
Also what are the holes in the bottom case for?
Offline 0ldMate
« Reply #43 on: Mon, 02 June 2025, 19:10:45 »
Thank you :)
It will support stepped caps
The holes are for tenting poles underneath.
Offline 0ldMate
New prototype pictures and build video uploaded!!
We are so close! Finalizing prices currently for the GB
Offline KOBO ISSHI
Gosh, that split with the red neon. Stunning!
Offline 0ldMate
Re: Split60 - A Split 60% Board HHKB/WK - Group Buy Live!
« Reply #46 on: Fri, 04 July 2025, 17:46:56 »
After many many years, the Group Buy is Live!
Thanks for all the patience and for following me on this journey.
https://geekhack.org/index.php?topic=125335.0
