Author Topic: [IC] Ultra-Wide,Ultra-Minimal,big-knob: Aquila Keyboard  (Read 28657 times)
Offline Kevin-3992
  • kindlestar team
Aquila
Aquila is a 60% wireless mechanical keyboard featuring an ultimate minimalist design and our proprietary tri-mode wireless solution.
Layout and Design
Aquila adopts a 60% compact layout with 3U spaces on both sides, creating an unparalleled visual balance. After multiple comparisons and adjustments,
we have determined the most reasonable and aesthetic aspect ratio. Aquila has the same length as a 104-key keyboard but is narrower, which will not cause
adaptation issues or mouse compatibility problems. The only consideration may be desk space.
Wireless Connectivity
Aquila is equipped with our proprietary tri-mode wireless solution which strengthens signal stability through a
separate external antenna design.
This solution has been continuously improved through feedback from Orion87 users to provide a fast, lag-free experience.
Specs:
•Name: Aquila
•Modes: Wired, Bluetooth 5.2, 2.4G Wireless
•Size: 430x120x24-32mm  6.5 degree
•Material:Aluminum 6063
•Weight: 2.5kg
•Gasket mount + poron+PE
•VIA support
•RGB backlighting with 26 million colors
•Hot-swappable switches
•4000mAh battery
We are looking for a vendor partner. If you are interested in representing Kindlestar products, please contact me
Check out Aquila's color matching below for more details. Please let me know if you have any questions or need any clarification.
We aim to highlight Aquila's key features and design innovations to garner interest from Geekhack members and input for continued improvements.
Photos
Photos  by  Ziyang
Photos  by  Sasachi
Photos  by  Val
Photos  by  Liqi
Photos  by  Tianyu
Contact US
https://discord.gg/ztQnqW5MTd
IC FORM
https://docs.google.com/forms/d/e/1FAIpQLSeSd9hP2KAURxfA0TOK5M1gvHcPGPbCIlDE2jK0M2KIEloleA/viewform?usp=pp_url
0815 Update:
GB will be launched from August 15th to September 15th, 2023
Planned to start shipping in December 2023
Price:
[/b]
« Last Edit: Thu, 17 August 2023, 12:07:47 by Kevin-3992 »
Offline roostrc0gburn
  • its just plastic
Re: [IC] Ultra-Wide,Ultra-Minimal,big-knob: Aquila Keyboard
« Reply #1 on: Wed, 03 May 2023, 11:13:39 »
finally an original concept
Offline irithyll
« Reply #2 on: Wed, 03 May 2023, 11:36:47 »
This is certainly eye-catching.
GLWIC!
Online Findecanor
« Reply #3 on: Wed, 03 May 2023, 11:51:41 »
I think you somehow must have missed the point of having a 65% ...
  • its just plastic
« Reply #4 on: Wed, 03 May 2023, 14:04:19 »
its more like a 66 layout, which i appreciate because the 65 has been recreated so many times in the last few years. this is at least a fresh perspective
Offline stewfayew
« Reply #5 on: Wed, 03 May 2023, 16:55:58 »
It's the opposite of minimal. Its unique aesthetic appeal is in its excessive width and oversized knob. And there's nothing minimal about three layers of foam.
Weak marketing, neat board.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #6 on: Wed, 03 May 2023, 16:57:05 »
what the
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #7 on: Wed, 03 May 2023, 20:52:24 »
I mean at least it's unique, even if I think it looks ugly as hell, GLWIC
also this isn't minimal this extra lol
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Kevin-3992
  • kindlestar team
« Reply #8 on: Wed, 03 May 2023, 22:42:27 »
Thank you for your recognition
Offline Kevin-3992
  • kindlestar team
« Reply #9 on: Wed, 03 May 2023, 22:44:19 »
GLWIC!
A New Form of Customization  :D
Offline Nishi-
« Reply #10 on: Wed, 03 May 2023, 22:55:13 »
I like the uniqueness, GLWIC
[/url]
Offline Kevin-3992
  • kindlestar team
« Reply #11 on: Wed, 03 May 2023, 23:06:43 »
The conventional 65% layout is characterized by its compactness. Aquila explores the perfection of proportions. It does not affect usability yet decorates the desktop sufficiently
Offline Morbii
« Reply #12 on: Thu, 04 May 2023, 01:32:07 »
Price?
Offline niakulah
« Reply #13 on: Thu, 04 May 2023, 20:01:39 »
No minimal in size, but it is minimal in style. I like it!
Offline Kevin-3992
  • kindlestar team
« Reply #14 on: Fri, 05 May 2023, 01:39:02 »
The ultimate proportion is the key to its uniqueness
Offline Kevin-3992
  • kindlestar team
« Reply #15 on: Fri, 05 May 2023, 01:40:31 »
Price?
We will announce the price soon. You can join our discord or fill out a form and wait for our email to inform you
Offline Kevin-3992
  • kindlestar team
« Reply #16 on: Fri, 05 May 2023, 01:41:29 »
Thank you for your like
Offline headshot
« Reply #17 on: Fri, 05 May 2023, 12:23:15 »
Offline moonsearch
    • Visit our website
« Reply #18 on: Fri, 05 May 2023, 16:20:53 »
I like the badge
Offline Current Keyboards
    • currentkeyboards.com
« Reply #19 on: Sat, 06 May 2023, 01:56:45 »
Yeah this is sick. Would 100% buy this thing. I wish it didn't have arrow keys but that's me complaining about the seat stitching on a Porsche.
Offline Beaniekeys
« Reply #20 on: Sun, 07 May 2023, 00:18:13 »
Love this!! very into unique and standout boards!
Offline nainaigogo
« Reply #21 on: Mon, 08 May 2023, 00:48:30 »
I have only one piece of feedback and it's that it needs to be even wider  :p
Offline jiminojimi
« Reply #22 on: Tue, 09 May 2023, 05:05:26 »
Love it. I'd like to wish for a polycarbonate one or at least something frosted glass like.
Offline Kevin-3992
  • kindlestar team
« Reply #23 on: Wed, 10 May 2023, 05:08:00 »
thanks for your loving , the group buy is coming soon
Offline Kevin-3992
  • kindlestar team
« Reply #24 on: Wed, 10 May 2023, 05:10:33 »
 :p
:p
Offline lorde
« Reply #25 on: Thu, 11 May 2023, 03:54:35 »
Aquila
Layout and Design
Specs:
•Name: Aquila
•Weight: 2.5kg
•VIA support
•4000mAh battery
Photos
Photos  by  Ziyang
Photos  by  Sasachi
Photos  by  Val
Photos  by  Liqi
Photos  by  Tianyu
Contact US
IC FORM
https://docs.google.com/forms/d/e/1FAIpQLSeSd9hP2KAURxfA0TOK5M1gvHcPGPbCIlDE2jK0M2KIEloleA/viewform?usp=pp_url melon playground
Thanks for the information, I will try to figure it out for more.
Offline Morbii
« Reply #26 on: Sat, 13 May 2023, 07:55:39 »
I would really like to see a solderable PCB.  That's basically my 1 must have these days.
Offline sugarfreemedia
« Reply #27 on: Sat, 13 May 2023, 17:15:09 »
Ortho version?
Offline madrone
« Reply #28 on: Sun, 14 May 2023, 00:50:55 »
This is really cool.  It's refreshing to see a concept that's different than the status quo.  Would love to buy if the price is achievable.
Offline yiuoterw
  • i love wasting money
« Reply #29 on: Sun, 14 May 2023, 01:49:10 »
Finally, something that isn't just another 60%!
What's the sound profile like on this thing?
new owlabs board when?
Offline Sandalphon36
« Reply #30 on: Mon, 15 May 2023, 02:13:41 »
Put a can holder on it to fit a 12oz and you have me sold.
Offline Kevin-3992
  • kindlestar team
« Reply #31 on: Wed, 24 May 2023, 06:25:11 »
There will be options for solderable PCB
Offline Kevin-3992
  • kindlestar team
« Reply #32 on: Wed, 24 May 2023, 06:26:45 »
We will update the selling price later. It may be a good idea to fill out a form first
Offline Kevin-3992
  • kindlestar team
« Reply #33 on: Wed, 24 May 2023, 06:28:37 »
This is not an ow project, but we believe its sound performance will be of the same level
Offline Kevin-3992
  • kindlestar team
« Reply #34 on: Wed, 24 May 2023, 06:30:07 »
Ha Ha
Offline niakulah
Offline Kevin-3992
  • kindlestar team
« Reply #36 on: Wed, 31 May 2023, 07:11:08 »
Ortho version?
This, I can get behind. A shorter long long man:
https://www.reddit.com/r/MechanicalKeyboards/comments/ueyqxg/gb_long_long_man/
Just long man?
It has nothing to do with Aquila, which is characterized by the blank areas on both sides
Offline trashem
« Reply #37 on: Sun, 04 June 2023, 09:33:34 »
I love a good chonky boi, there aren’t enough out there!
Offline Kevin-3992
  • kindlestar team
« Reply #38 on: Mon, 14 August 2023, 13:30:45 »
The good news is that it has finally started GB
Offline BRSxIgnition
« Reply #39 on: Tue, 15 August 2023, 13:24:32 »
Very tempted but apparently Alexotos is having issues with doubletyping etc with the 2.4ghz connection.
Do you think this will be fixed for launch?
Also, is there an option for the badge at the bottom to be blank (without the logo)?
Offline Kevin-3992
  • kindlestar team
« Reply #40 on: Thu, 17 August 2023, 11:25:16 »
Thank you for your attention.  signal difference can lead to doubletyping. The aluminum shell has a shielding effect on signals. We solve this problem through an independent antenna. If there is doubletyping, we can adjust the receiver position to solve this problem. This technology has been widely used in the Orion87 project and I often use it to play games. In addition, Bluetooth's doubletyping will be much more than 2.4g. We recommend using 2.4g mode
Offline wongie
« Reply #41 on: Thu, 17 August 2023, 12:27:44 »
Now this is a beautiful minimalist design, and when i say minimalist I mean the aesthetic style of minimalism (Too often I find people confusing something utilitarian as minimalist) with its wide open faces reminiscent of architecture and buildings that uses this philosophy on their wide open walls and surfaces. Reminds me of the Exent 65 and while i prefer its layout without a blocker I do love the the sharper angularity of this design more.
Offline kalyl
« Reply #42 on: Wed, 30 August 2023, 02:55:57 »
Aquila
Layout and Design
Specs:
•Name: Aquila
•Weight: 2.5kg
•VIA support
•4000mAh battery
Photos
Photos  by  Ziyang
Photos  by  Sasachi
Photos  by  Val
Photos  by  Liqi
Photos  by  Tianyu
Contact US
IC FORM
https://docs.google.com/forms/d/e/1FAIpQLSeSd9hP2KAURxfA0TOK5M1gvHcPGPbCIlDE2jK0M2KIEloleA/viewform?usp=pp_url geometry dash 3d
0815 Update:
Price:
[/b]
The design is exactly what I wanted for a wireless mechanical keyboard. The color is simple but very youthful and luxurious, in the long run will not be out of fashion. Great, excellent, wonderful.
« Last Edit: Thu, 15 February 2024, 22:32:22 by kalyl »
Offline hersanchez
« Reply #43 on: Thu, 02 May 2024, 00:27:22 »
It sounds intriguing! Would love to learn more about the features and design of the Aquila Keyboard.
Offline switchlab.sg
« Reply #44 on: Thu, 02 May 2024, 00:58:18 »
Nice concept but would love to see the space utilized, a phone holder, watch holder/charger and I'd be very interested!
GLWI!
Offline Kndra
« Reply #45 on: Thu, 25 July 2024, 08:35:27 »
That's such a unique board!!
That and a set of blank keycaps would be an insane combo
I have a distaste for the function row
Offline kbd0
« Reply #46 on: Fri, 26 July 2024, 22:53:35 »
Very strange look, I like it. GLWIC
Offline tankLancer
« Reply #47 on: Mon, 12 August 2024, 03:50:32 »
This keyboard is a real stunner. It would be a fantastic addition to my collection.
GLWIC
Offline Osidian
« Reply #48 on: Thu, 22 August 2024, 22:53:14 »
Very intriguing, certainly an eye catcher!
GLWIC  :D
Offline missdmclain
« Reply #49 on: Thu, 26 September 2024, 20:33:43 »
The tri-mode wireless solution is particularly appealing, as it enhances signal stability and ensures a lag-free experience—something gamers and typists alike will appreciate. The compact 60% layout balances functionality with aesthetics, making it a great fit for various desk setups.sydney accountant
