Author Topic: Does this 40% layout exist?  (Read 5607 times)
Offline tbe
« on: Sun, 21 May 2023, 04:34:46 »
Any suggestions for a keyboard or kit with physical layout similar to this?
299169-0
« Last Edit: Sun, 21 May 2023, 06:20:02 by tbe »
Offline LavenderB
  • I believe in unix control supremacy
Re: Does this 40% layout exist?
« Reply #1 on: Sat, 10 June 2023, 05:10:15 »
I've seen some hhkb 40%s.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline Sup
« Reply #2 on: Sat, 10 June 2023, 07:34:45 »
Not sure if a keyboard exist with this layout but, the layout looks so awful to be honest. going this small and staggered i don't see the benefits and the reason for it to exist then because it can.
I went with this layout and never looked back it is super comfortable and feels way more natural.
current
Coming soon
Offline tbe
« Reply #3 on: Fri, 24 November 2023, 19:03:14 »
What keyboards have that exact physical layout, and which one are you on @Sup?
Offline Rhienfo
  • GOTHETIGES
« Reply #4 on: Sat, 25 November 2023, 11:51:27 »
You would probably be looking at a hhkb 40%, something like this - https://geekhack.org/index.php?topic=92259.0 (do not know if this specific project is any good, just showed a board with a similar layout)
You could DIY and make keyboard with the same layout and handwiring and like a 3d printed case and stuff like that, if you want that specific layout I guess.
Offline Sup
« Reply #5 on: Sun, 26 November 2023, 13:44:08 »
They call it a Corne keyboard. Its a opensource keyboard so you can get all the parts yourself or a kit and build one yourself. I think Boardsource offers the most premium kits.
current
Coming soon
Offline tbe
« Reply #6 on: Sun, 26 November 2023, 18:32:01 »
Thank you Sup :thumb:
