Author Topic: [IC] KAM Outline - GB Live  (Read 17891 times)
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« on: Fri, 26 May 2023, 12:46:17 »
KAM Outline
By
Beesley
Inspiration
Inspired by a traditional 1935 No.10 Remington typewriter, this is where old meets new
GB Details
GB Date: 12th July!
Kitting
Colours
Deskmat
Diner Deskmat designed by HawkersDraws
Renders
OGR - By AKB
Bakeneko - By CannonKeys
WerkOne - By WerkTechnica
Vendors
NA & Global: Otakeebs
OCE & SEA: ALLCAPS
Collabs
TBD
Beesley Discord Server
Support this kit by using the signature below
Code: [Select]
[url=https://geekhack.org/index.php?topic=120414.0][img]https://i.imgur.com/iV8kkKk.jpg[/img][/url]
Special thanks to everyone who supported through the design of of this set
SpikedSynapse & ImperfectLink
An even bigger thanks to my amazing Fiancée for putting up with me doing all of this!
« Last Edit: Thu, 13 July 2023, 10:36:34 by Beesley »
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
Re: [IC] KAM Outline - Where Old Meets New
« Reply #1 on: Fri, 26 May 2023, 12:46:46 »
FAQ
Can there be a novelties kit?
There are no plans to create a novelty kit for this set, with the inspiration and trying to replicate that look of a typewriter and to feel simple yet elegant
Any chance of a different profile like SLK or something non uniform?
I have tried to get this to work with SLK for the past few months but unfortunately it was not achievable with there manufacturing process compared to Keyreative after seeing there KAM Command samples.
I chose a uniform profile as it fits the inspiration of a typewriter, it also increases compatibility with a wide range of keyboards without including extra kits
Can you split everything in to more kits?
Keyreative have made steps to put a stop to the days of running 30+ kits, reflected in there new cumulative surcharge on sets exceeding 3 kits
There lead times are dependent on the amount of kits, less kits means quicker delivery
Updates
  • Amended some kitting - added HUNT, removed unnecessary keys
  • Second deskmat is Complete phase
  • THOK metal artisans in design phase
« Last Edit: Sat, 03 June 2023, 13:28:28 by Beesley »
Offline spikedsynapse
« Reply #2 on: Fri, 26 May 2023, 12:50:03 »
Oh damn thats hot! Cant wait to get this! GLWIC
Offline Surefoot
« Reply #3 on: Fri, 26 May 2023, 13:14:52 »
Really nice. I suppose it's using KAM matte finish ? Shiny finish would maybe not suit the style that much.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #4 on: Fri, 26 May 2023, 13:16:42 »
Yes im planning to use the matte finish
Offline El Kinoflop
« Reply #5 on: Fri, 26 May 2023, 13:30:40 »
Your 40s support doesn't look right. 3 key 40s is usually R2 1.75u Backspace, R3 1.5u Enter, R3 1.25u Tab. It looks like you've got a 2nd 1.5u Tab in there instead.
Less of an issue with a uniform profile but you might as well have the correct tab if you're putting in 40s support (thanks for doing it).
« Last Edit: Fri, 26 May 2023, 13:32:47 by El Kinoflop »
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #6 on: Fri, 26 May 2023, 13:37:59 »
Thanks for noticing this, it's an error on my part and am fixing this now!
Offline arr1
  • Ñ supporter
« Reply #7 on: Fri, 26 May 2023, 13:57:38 »
It looks awesome!
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #8 on: Fri, 26 May 2023, 14:00:12 »
It looks awesome!
Appreciate it! Thank you!
Offline TerraKeycaps
« Reply #9 on: Fri, 26 May 2023, 16:19:02 »
Yes! Big fan of this already :)
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #10 on: Fri, 26 May 2023, 17:18:05 »
KAM Taskmaster.
I like the idea but is it going to possible to get consistent border placement on each keycap, manu's find it hard enough to get regular legends right.
Offline aicyborg
« Reply #11 on: Fri, 26 May 2023, 19:17:59 »
I hope this won't come off like I'm telling you what do, but iiiiiis there any chance you'd be willing to reconsider on the stroke/border around each keycap? To me, each keycap has a natural innate border where the sides meet the top and I'm not sure if I love how busy it makes it all look.
Feel free to disregard this as I don't want to discount your artistic vision. I'm just kinda wondering aloud here.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #12 on: Fri, 26 May 2023, 23:40:49 »
KAM Taskmaster.
After seeing KAM Command samples, I and Keyreative are very confident with the consistency we will be able to achieve
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #13 on: Sat, 27 May 2023, 01:19:09 »
I appreciate the feedback, but unfortunately not, the stroke and boarder has been my vision for this set from the beginning.
Offline kajahtaa
« Reply #14 on: Sat, 27 May 2023, 01:54:26 »
I love it.
Offline Ciantha
« Reply #15 on: Sat, 27 May 2023, 04:04:12 »
Please consider a more robust 40s support. 3-key 40s makes sense on GMK or other high price manus where a child kit might be too expensive/ have too high a moq to be viable.
Unless Keyreative has significantly changed their pricing a 40s kit at a reasonable price that'll meet moq (if there is one now?) would probably be doable.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #16 on: Sat, 27 May 2023, 05:12:30 »
I'll consider it, if there's enough responses asking for it on the IC form
Offline Eighty58five
« Reply #17 on: Sun, 28 May 2023, 09:23:48 »
Any chance of being able to confirm colour codes at this stage?
Are these going to double-shot in keyreatives pbt blend?
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #18 on: Sun, 28 May 2023, 09:39:08 »
Dysesub, mould costs for the outline is incredibly expensive. Ill be ordering samples soon and sorting out colours
Offline cthalupa
« Reply #19 on: Mon, 29 May 2023, 12:52:49 »
Keyreative now adds a cumulative surcharge on the whole set for every kit over 3
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
Re: [IC] KAM Outline - Looking for Vendors!
« Reply #20 on: Thu, 01 June 2023, 09:23:02 »
Looking for vendors for this set - if you would like to vendor reach out!
Offline Kairo.works
« Reply #21 on: Thu, 01 June 2023, 09:37:43 »
That's a very good looking set.
That means no International Kit then, i suppose?
Or even worse, that means no more international kits for any keyreative sets going forward.
I don't like this even a tiny bit.
Offline Ciantha
« Reply #22 on: Fri, 02 June 2023, 14:51:23 »
If a separate 40s kit is impossible due to trying to keep at 3 kits or below then perhaps a bigger base kit could be considered.
For example NicePBT Noel adds in 1.75u space as well as quite a few extra bars (dual 2u, dual 3u, etc).
Re: [IC] KAM Outline - New Deskmat!
« Reply #23 on: Sat, 03 June 2023, 10:18:48 »
New deskmat looks really good!
Offline just.hymn
« Reply #24 on: Sat, 03 June 2023, 10:20:34 »
Sheeeeesh, looking real nice, GLWIC!!!
Offline HungHingDaiLo
  • 無間道
« Reply #25 on: Sun, 04 June 2023, 19:57:26 »
IMO you can experiment with dark color background for the new deskmat since it compliments your set well/better than the off-white.
IG: @rayhhdailo
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
Re: [IC] KAM Outline - GB Date Announced!
« Reply #26 on: Tue, 06 June 2023, 03:06:33 »
GB date announced!
July 12th!
Offline teenazas
« Reply #27 on: Wed, 07 June 2023, 06:49:35 »
Really excited about this set. Happy to see that the GB is already announced!
Offline Aquarius
« Reply #28 on: Sun, 11 June 2023, 05:30:36 »
Infinite expectation :eek:
Offline Miscfu
« Reply #29 on: Sat, 17 June 2023, 00:42:32 »
Love this! Can't help but think this design would go hard on that new SLK profile too...
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #30 on: Sat, 17 June 2023, 10:35:03 »
This was the original plan but ti didn't work out
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #31 on: Wed, 21 June 2023, 08:28:11 »
This 100%. I'm a shoe-in for the deskmat if it's dark.
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline phinix
« Reply #32 on: Wed, 28 June 2023, 12:11:30 »
What is the turnaround time for KAM caps?
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #33 on: Wed, 28 June 2023, 12:32:56 »
Estimation I currently have from Keyreative is Q4 2023/ Q1 2024 - I already have samples on there way which will arrive tomorrow
Offline phinix
« Reply #34 on: Thu, 29 June 2023, 05:40:43 »
That's not bad at all  :)
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #35 on: Mon, 03 July 2023, 04:59:39 »
With the GB right around the corner I'm happy to show a sample photo from Keyreative!
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #36 on: Thu, 13 July 2023, 09:52:50 »
Group buy is live!
