Author Topic: [IC]AeroBoard70 & Wrist Rest with new colors of Powder coat  (Read 36037 times)
Offline S61
Page on ClickClack--https://clickclack.io/pages/aeroboard70
New selectable PCBs & Plates in stock
Non-Flex Cut 1.6mm  PCB and CF Plate typing:https://clips.twitch.tv/HeadstrongGenerousClipzPoooound-r47XH9yF26oCe6W7
Flex Cut 1.2mm  PCB and FR4 Plate typing:https://clips.twitch.tv/WealthyPiliableSandwichPraiseIt-P14lpabSUqhXNlhB
Full rebuilding from Frank: https://www.twitch.tv/videos/1906845819?filter=archives&sort=time
Full building video for AB70 White Gold Edition with Alu Plate from Andy:
https://www.twitch.tv/videos/1909130344
Review from Andy:
and new ESD of super thin PET
New Alu anodized or gold-plated Brass Prime caps kit, available for purchase separately
Price and MOQ will be provided on the 25th
Renderings of the co-op keycaps on the AB70
Relic
Steam Age
Alhambra
KawaiiVoltage
The details of the three editions of AB70
More real-time information and interaction in discord of designers or vendor
ClickClack: discord.gg/clickclack
SMIT6Y WORKS: discord.gg/zZtcwkb39s
Google form IC:
https://forms.gle/vqSXorg8ixCGS4hq9
AeroBoard70 Wrist Rest
Detail of Wrist Rest
AB70 SE: PRIME?
More detail of Prime edition
Regarding the name, it coincides with the release of the Transformers 7 movie. I feel that the shape of the G1 with this theme matches the overall tough appearance of the AB70. There are many discussions about whether the villain Scourge is the Darkside Optimus Prime, so I want to use the Darkside Optimus Prime color scheme. Make a limited edition.
This launch is a limited edition of AB70, which is a product whose effect is determined only after repeated docking with the supplier on materials and processes during the design stage.
Overall realization 316 food-grade stainless steel + mirror/fog PVD coating + AF anti-fingerprint coating
Of course, it’s not just about color matching, this time the keyboard will also come with a kit of 5 artisan keycaps inspired by Optimus Prime’s mask
Specially designed for AB70's symmetrical split space and alt keys(1.5U+3U+1U+3U+1.5U)(Brass+PVD+AF)
Next, please enjoy the overall rendering of AB70 prime
More Rendering->
This position is reserved for videos of youtubers who receive prototypes(The videos will be launched gradually in July)
AB70 standard edition -White- from TofuTypes
Review and Sound Test :
AB70 standard edition -White- from 青空Moore
AB70 standard edition -Silver- from MechMerlin
Building video :
AB70 standard edition -Purple- from Frank
typing video :
Building video : https://www.twitch.tv/videos/1857558313
AB70 standard edition -Blue- from LightningXI
typing video :
Building video :
----------------The following is the information before June 15th, 2023----------------
Long time no see guys.I am the designer of AXE60.Since the launch of AXE60,I have been patiently designing and modifying new keyboards while also thinking about how to make my design serve more players.
After careful consideration,I have decided to split the style into two main branches,where the Nordic mythological style of AXE will continue (players who like AXE don't have to worry) and the other is a relatively more sci-fi and tough style.
The AeroBoard70 to be introduced next is such a keyboard.Let’s show it to you through the following self-made CG trailer video that has been rendered for more than one month.
(Animation: Nearly 3K frames,1 frame render>10Min,Hardware RTX A4000,Software Maya&Arnold,using OptiX denoiser to boost rendering)
A short animation to show the special mount:
Product Introduction
Layout: 70% (65%+5%)
Material: aluminum、stainless steel、PC、tempered glass、brass、etc
Design by SMIT6Y.WORKS, PCB by Eason,Manufactured by RH
Layout | Exploded view | Details List | AF Layer Comparison
Layout
Stepped Caps Lock, Splittable Space(7U=3U+1U+3U),Symmetrical WKL
Exploded view
Details List
 Aluminum  upper shell-[6063-T6]-[anodic or electro]-[AF layer]
 Aluminum  lower shell-[6063-T6]-[anodic or electro]-[AF layer]
 Aluminum  grid bar-[6063-T6]-[anodic]-[AF layer]
 Aluminum  bottom Frame-[6063-T6] -[Anode]-[AF layer](Standard)
or Brass Bottom Frame-[Gold-plated ]-[Sandblasted & Mirror] (Copper Frame Version)
 tempered glass-[black coating]-[shading layer]-[low transmission layer]-[AF layer]
 Layout strip-[Stainless steel][PVD]-[Sandblasting&Mirror]-[AF layer]
 LOGO part-[Stainless steel][PVD]-[Sandblasting&Mirror]-[AF layer]
 Light guide strip-[PC]-[Sandblasting]
 Dual Ring Leaf hot-swap flex-cut PCB and FR4 Plate(provide additional PC/Alu plate)
 USB-C-PCB-[1.6mm][protective film on the back]
 FPC Adapter PCB-[1.2mm]
 RGB-PCB-[1.2mm]-[total 30 lamp beads]
 Silicone suspension support blocks-[40 hardness x 16 pcs] & [50 hardness x 16 pcs]
 Split Space 3U steel wire of stabilizer -[Gold-plated]
 PORON middle pad-[LE20]-[3.5mm]
 PORON back pad-[LE20]-[2.0mm]-[double-sided tapes]
 PORON bottom pad-[LE20]-[1.2mm]
 IXPE pad-[LE20]-[0.5mm]
 Echo Paper-[Masking Paper]-[0.15mm]
 FPC wires & JST wires
 Plastic crowbar [adjust the wire and install the shaft to clamp plate]
 T6 T8 10 star shaped screw wrench
 A complete set of star screws-[m3/m2.5/m2]
 Spare screw storage nameplate-[6063-T6]-[Anode]-[Laser carving]
 User guide
Without AF layer / With AF layer:
Design
Inspiration
No single reference,but influenced by the hard straight lines and grid elements from sci-fi vehicles in movies and industrial or electronic products.
 "aeroboard" is derived from the meaning of "aeroboat" to express a sci-fi  design looking of hybrid spacecraft or vehicles.
When the word aero is mentioned now, people generally think of a more rounded and streamlined shape, but in the last century, whether it was a sci-fi movie vehicle or a real car, there were many tougher lines.
Outside
1.To highlight the symmetry of the WKL on the upper shell, separate PVD stainless steel components are used to fill the gap between 65% and 5%.
2.The RGB light strip composed of 30 lamp beads is  on the top side, which can be used as a desktop ambient light under dim light,like a spaceship thruster.
3.The independent bottom edge components are visually designed with edge wrapping, and inner grooves are cut to allow tempered glass to be embedded in it.
4.The grid part is inspired by Corsair's old Dominator Platinum. The grid, an industrial heat dissipation element, appears very harmoniously on retro vehicles.
5.Two pieces of toughened glass on the top side, the multi-layer coating surface not only has a beautiful reflective effect, but also can smoothly transmit RGB light.
Inside
1.In order to achieve dual leaf mount, double the number of  steps are cut on edge of the bottom and upper shells.
2.Except for the small FPC and FPC adapter PCB grooves on the bottom, no other grooves, which can achieve better sound performance.
3.For the integrity of the bottom case, the vertical PCB and side-emitting lamp beads and light-guiding PC are used to realize a very small light strip isolated from the mount space.
4.The typec PCB adopts a drawer type push in installation method, which only connects to the interior of the bottom shell with very small holes. After installation, a small piece of EVA material in the box can be used to block the holes.
5.The LOGO part is embedded by cutting grooves on the outside, and only 4 screw holes are opened on the inside.
Mount
Trying to design a highly playable mount that combines a soft click and pleasant sound with excellent stability and uniformity, as well as a crisp click experience through switching.
1.Innovative Dual-Ring-Leaf-Spring mount, there are leaf-springs with the same length but staggered positions on the edge of plate and PCB,
which means that users can choose at least 3 kinds of mount, and adjust according to their preferences to get soft or balanced Even a solid tap feel and sound.
2.Two kinds of hardness silicone 16x2 hanging blocks are provided to further enhance the playability.
3.Customized PORON fills the gap at the bottom of the PCB and then covered by customized masking paper, which effectively reduces the clicking noise and the cavity sound.
4.Provide an improved PCB stabilizer quick disassemble design without disassemble the  plate first, which not only facilitates the installation the stabilizer, but also tries to retain the fixing effect of the plate on the switch.
Render
more images
Photos from factory
Updating
New photographic works
New photos taken by players who have received AB70
« Last Edit: Tue, 27 February 2024, 11:58:58 by S61 »
Offline hzh0525
Re: [IC]AeroBoard70 (65%+5%) with Dual-Ring-Leaf-Spring
« Reply #1 on: Sat, 27 May 2023, 07:50:56 »
What a fascinating design! I'm in!
Offline Siak
Re: [IC]AeroBoard70 (65%+5%) Dual-Ring-Leaf-Spring
« Reply #2 on: Sat, 27 May 2023, 09:09:20 »
Any EU vendors?
Offline daethon
« Reply #3 on: Sat, 27 May 2023, 13:53:31 »
Can’t wait!!
Offline FranktheTank319
Looks amazing!
Offline jacksokb
    • n/a
Consider me interested in the white/black/orange one
Sent from my Pixel 6 using Tapatalk
Offline Rhienfo
  • GOTHETIGES
Could you update the layouts, because it's pretty bare. It doesn't have any split backspace or ISO support. And while there should be split backspace, you should may also want to include other spacebar options such as 2.25/2.75 style split spacebar, as they are more readily accessible in base kits.
Offline muradir
Definitely want the white(soy?), black, copper version. Also the lighting looks very nice.
But I also would like to see more layout options, especially split backspace. For the sake of looks and symmetry I can live with the 3+1+3 split Spacebar, but other options are also appreciated, if it fits the design.
Looking forward to updates  :thumb:
Offline S61
Thanks very much for your suggestion. Since the first group is sold in stock, only the hot-swap PCB with the current layout is provided for the time being. Depending on the demand of players in the future, other configurations may be provided.
Offline spikedsynapse
Nice I like this a lot!
Offline keeboredguy
[/quote]
Hi, so the July group is the first group and will be FCFS and there will be another sale group that has been planned in the near future?
Offline S61
[/quote]
Thank you for keeping an eye on this keyboard. Currently, I can only focus on this in-stock group buy. If the sales situation is optimistic, I would like to start another scheduled group buy. This will allow me to present more layouts, configurations, and color schemes, and even offer lower prices. Of course, all of this depends on the performance of this in-stock group buying.
Offline S61
Bump for 15 Jun 2023 update  AB70 Prime Edition
Offline Groom
This time is a completely different style from axe60,but it can be seen that the design is also very meticulous
The key is that the price of the standard version is much lower the axe60.   what is quite curious is whether other related accessories will be launched? or any other color?
« Last Edit: Sat, 17 June 2023, 06:16:37 by Groom »
Offline sketch3v
  • Sketch (astro-keys)
    • Astro
bro made a whole trailer for the keyboard. Haha. Love it.  :thumb:
Offline S61
There will also be accompanying mini pad board and hand pad to be launched in the future, new colors are also possible(if the sales of stocks response is good)
Offline S61
Bump for 26 Jun 2023 update  new photos/videos
Offline Groom
Mini pad? i hope that is a Num pad, with a wireless pcb. by the way, what keycaps are paired with the white edition in the new photos?
« Last Edit: Tue, 04 July 2023, 12:18:07 by Groom »
Offline MaxineCh
https://www.zfrontier.com/app/flow/9XO9mvoRvB8O
is it possible to buy from the Chinese run and pay for intl shipping? Want to save on the difference in pricing.
Offline J_Noes
Will split backspace be supported?
Offline S61
This method of purchase is not a problem, but you need friends to help you find a suitable transit warehouse
Offline S61
If the spot sales are good, more specifications of accessories will be available for purchase.
Offline S61
Re: [IC]AeroBoard70 | IC Form | New Videos | Wrist Rest IC [19 July 2023]
« Reply #22 on: Tue, 01 August 2023, 07:19:19 »
Bump for 1 August 2023 update  new plate & pcb & new GB time & new ESD film & new price
Offline hzh0525
« Reply #23 on: Tue, 01 August 2023, 07:21:18 »
Cool!
Offline S61
Bump for GB anouncement
Offline hzh0525
Come on!
Offline ToFuMaNiA
Color choices and the design is really cool, can't wait to go on gb GLWIC!
Offline S61
Bump for new Building videos for new PCB and Plate
Offline hzh0525
Cool!
Offline juliday
  • Synth, Controller, and Keyboard
    • SagakLabs
Re: [IC]AeroBoard70 | 1.2/1.6 PCB | 5 Plates | New images | IN STOCK NOW !!!
« Reply #29 on: Fri, 25 August 2023, 23:44:37 »
the video is insane! so cool.
Offline S61
Re: [IC]AeroBoard70 | 65%+5% | White gold edition Build | IN STOCK LIVE !!!
« Reply #30 on: Mon, 04 September 2023, 22:46:31 »
Bump for new  video and Photos
Offline Akele
Re: [IC]AeroBoard70 (65+5) | Dual-Ring-Leaf-Spring | Update photos taken by phone
« Reply #31 on: Sat, 09 September 2023, 06:55:03 »
Hope the sale is going well. I'd love to see an ISO PCB and plate offered in the future.
Offline S61
Re: [IC]AeroBoard70 & Wrist Rest with new colors of Powder coat
« Reply #32 on: Tue, 27 February 2024, 12:00:24 »
Bump for New product information updates.
