Muramasa - The Longestboi - Prototypes made!!![[IC] Muramasa - The Longestboi - Prototypes made!! 301164-0](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301164;image)
Since getting into prebuilt mechanical keyboards, I have always had a fondness for big boi keyboards - such as full sizes or TKLs.
Coming into the hobby, I have had my fair share of big boards - tons of TKLs - but I always thought: Can I go even bigger?
Introducing the Muramasa - a XT-FRL + numpad longboi.
(PS this is also part of an attempt to get my colleague into mech keyboards, since he won't shut up about how he "needs a numpad".)DISCORD LINKIC FORMSpecs- 9 degree angle
- Adjusted front height of 17.8mm
- Materials: 6063 Aluminum (top&bottom case), Brass (weight)
- Top mount, two piece plate (considering 5052 Aluminum / PP / FR4)
- Three piece brass weight (also considering weight-less option)
- 2505g unbuilt
- Bezels: 8mm(top/down), 5mm(left/right)
PCB Support- Supports: full/split backspace, full/split right shift, full/split left shift, ISO, ANSI, 10u/7u/6.25u bottom row, F107 layout, and different numpads
Gallery- These are renders, see below for prototype photos!
![[IC] Muramasa - The Longestboi - Prototypes made!! 301148-2](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301148;image)
![[IC] Muramasa - The Longestboi - Prototypes made!! 301162-3](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301162;image)
![[IC] Muramasa - The Longestboi - Prototypes made!! 301152-4](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301152;image)
![[IC] Muramasa - The Longestboi - Prototypes made!! 301150-5](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301150;image)
Mounting method- Top mount with separate plates for the 60%+XT area and nav cluster+numpad.
- I wanted a softer typing experience & inspired by the glare, I thought this would be an interesting mounting method.
- Plate options are as follows: ANSI full / ANSI half / ISO full / ISO half, in 5052 Aluminum / FR4 / PP
![[IC] Muramasa - The Longestboi - Prototypes made!! 301156-7](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301156;image)
Layout options- I'm considering offering the top case in two different layout options - "Vintage" & "New-Age"
- Vintage will be a F107-style layout, with winkey & the nav cluster all cut out (as pictured on the left)
- New-age will be standard WKL (as pictured on the right)
Prototypes- Yes, I suck at taking photos.
- Engravings are only on my personal unit, though i will consider other themed engravings for the production version.
- As you can see, keebmat doesn't fit kekw
- Pictured with WOB & GMK Handarbeit
- Waffle towels FTW
- These are test fit units, still missing PCBs...
Issues that are being fixed:
- type-c port is widened just a bit to maximize compatibility
- changed depth of screw points
- added ribs to promote stability in the bottom case (weight section)
- plates are being fixed (minor incorrect measurements)
![[IC] Muramasa - The Longestboi - Prototypes made!! 301168-10](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301168;image)
![[IC] Muramasa - The Longestboi - Prototypes made!! 301170-11](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301170;image)
![[IC] Muramasa - The Longestboi - Prototypes made!! 301172-12](https://geekhack.org/index.php?PHPSESSID=cdd2uspra40uv4iar53rjc17khh6nj2j&action=dlattach;topic=120482.0;attach=301172;image)
What's next?- This post is used to gauge the interest of the community, but either way I will be getting prototypes made. Expect updates to come in the future.
I plan to open source this project at some point, after I make the prototype and make sure I iron out the details.
- Going forward, a GB maybe possible, or even an internals(PCB+plate) GB (for people who want to machine their own)
- I've done some preliminary budgeting for this project.
If there is a GB, I'm aiming for something like $480 @ 100MOQ / $650 @ 25MOQ.
Thank you!
Update- Thanks for all the kind words, including keyboard friends who have filled out the IC form.
- When I open source the project, I will also include version with no weights to hopefully help with cost saving.
Here's a (hopefully)cool signature:
[url=https://geekhack.org/index.php?topic=120482][img width=210 height=120]https://i.imgur.com/Y6aw3ZY.png[/img][/url]
