Author Topic: [IC] Muramasa - The Longestboi - Prototypes made!!  (Read 44023 times)
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« on: Sun, 04 June 2023, 12:03:22 »
301164-0
Since getting into prebuilt mechanical keyboards, I have always had a fondness for big boi keyboards - such as full sizes or TKLs.
Coming into the hobby, I have had my fair share of big boards - tons of TKLs - but I always thought: Can I go even bigger?
Introducing the Muramasa - a XT-FRL + numpad longboi.
(PS this is also part of an attempt to get my colleague into mech keyboards, since he won't shut up about how he "needs a numpad".)
DISCORD LINK
IC FORM
Specs
- 9 degree angle
- Adjusted front height of 17.8mm
- Materials: 6063 Aluminum (top&bottom case), Brass (weight)
- Top mount, two piece plate (considering 5052 Aluminum / PP / FR4)
- Three piece brass weight (also considering weight-less option)
- 2505g unbuilt
- Bezels: 8mm(top/down), 5mm(left/right)
PCB Support
- Supports: full/split backspace, full/split right shift, full/split left shift, ISO, ANSI, 10u/7u/6.25u bottom row, F107 layout, and different numpads
301166-1
Gallery
- These are renders, see below for prototype photos!
301148-2
301162-3
301152-4
301150-5
301154-6
Mounting method
- Top mount with separate plates for the 60%+XT area and nav cluster+numpad.
- I wanted a softer typing experience & inspired by the glare, I thought this would be an interesting mounting method.
- Plate options are as follows: ANSI full / ANSI half / ISO full / ISO half, in 5052 Aluminum / FR4 / PP
301156-7
301158-8
Layout options
- I'm considering offering the top case in two different layout options - "Vintage" & "New-Age"
- Vintage will be a F107-style layout, with winkey & the nav cluster all cut out (as pictured on the left)
- New-age will be standard WKL (as pictured on the right)
301160-9
Prototypes
- Yes, I suck at taking photos.
- Engravings are only on my personal unit, though i will consider other themed engravings for the production version.
- As you can see, keebmat doesn't fit kekw
- Pictured with WOB & GMK Handarbeit
- Waffle towels FTW
- These are test fit units, still missing PCBs...
Issues that are being fixed:
- type-c port is widened just a bit to maximize compatibility
- changed depth of screw points
- added ribs to promote stability in the bottom case (weight section)
- plates are being fixed (minor incorrect measurements)
301168-10
301170-11
301172-12
301174-13
What's next?
- This post is used to gauge the interest of the community, but either way I will be getting prototypes made. Expect updates to come in the future.
- I plan to open source this project at some point, after I make the prototype and make sure I iron out the details.
- Going forward, a GB maybe possible, or even an internals(PCB+plate) GB (for people who want to machine their own)
- I've done some preliminary budgeting for this project. If there is a GB, I'm aiming for something like $480 @ 100MOQ / $650 @ 25MOQ.
Thank you!
Update
- Thanks for all the kind words, including keyboard friends who have filled out the IC form.
- When I open source the project, I will also include version with no weights to hopefully help with cost saving.
Here's a (hopefully)cool signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=120482][img width=210 height=120]https://i.imgur.com/Y6aw3ZY.png[/img][/url]
« Last Edit: Fri, 14 June 2024, 09:14:18 by masje »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [IC]Muramasa - The Ultimate Longboi / XT-FRL+Numpad
« Reply #1 on: Sun, 04 June 2023, 12:21:02 »
good god
Offline Farhandsome
    • Han Boards
« Reply #2 on: Sun, 04 June 2023, 12:40:09 »
Very cool! Have you considered making the board longer?
Offline roostrc0gburn
  • its just plastic
« Reply #3 on: Sun, 04 June 2023, 13:41:01 »
I think you could fit 5 more keys
Offline warhopper
« Reply #4 on: Sun, 04 June 2023, 14:52:19 »
Fantastic! I was curious what could become longer than my W1 or Calliope, and now I finally have an answer! Lovely design
Offline CoolPenguin1
« Reply #5 on: Sun, 04 June 2023, 15:13:18 »
Offline Muramasa
« Reply #6 on: Sun, 04 June 2023, 15:14:34 »
For some reason, I have an intense urge to join this when it goes to GB ^^
Offline Erinkaze
  • I might be cringe, but at least I'm free.
« Reply #7 on: Sun, 04 June 2023, 15:15:46 »
This board is a perfect excuse to get a bigger desk. I cannot wait to see the protos!
Offline hali
    • hali.studio
« Reply #8 on: Sun, 04 June 2023, 15:21:09 »
cool! why?
Offline hkhawk
« Reply #9 on: Sun, 04 June 2023, 15:28:02 »
This is cool. In the renders I see two different side profiles. Which one are you going with or are you still deciding? Also, would you consider moving the navigation cluster to the left between the macro columns and the alphas for more symmetry and mouse space?
    • Twitchy Homepage
« Reply #10 on: Sun, 04 June 2023, 18:29:05 »
What a happy ending and fitting for pride month.  ;D
Offline masje
    • masjewerke
« Reply #11 on: Sun, 04 June 2023, 23:07:46 »
good god
Yes! This is the emotion I want to capture with this board.
Offline masje
    • masjewerke
« Reply #12 on: Sun, 04 June 2023, 23:08:06 »
Yes
Offline masje
    • masjewerke
« Reply #13 on: Sun, 04 June 2023, 23:08:39 »
Thank you for your kind words! I loved my W1
Offline masje
    • masjewerke
« Reply #14 on: Sun, 04 June 2023, 23:09:54 »
I’m hyped as well!!! Thinking of ways to bring cost down atm, for the benefit of people who might wanna machine themselves as well.
Offline masje
    • masjewerke
« Reply #15 on: Sun, 04 June 2023, 23:11:44 »
Yeah! I think I’m leaning towards the wedge design…
Hmm that might be something interesting to consider! Definitely will want to try that out.
Tho, all my homies hate mouse space :D
Offline beelzking
« Reply #16 on: Sat, 10 June 2023, 15:30:59 »
Now this is what I call long boi, interesting project.
GLWIC
Offline trashem
« Reply #17 on: Sat, 10 June 2023, 20:40:57 »
oh this is incredible, 10/10 for l o n g b o i
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #18 on: Sat, 10 June 2023, 23:47:41 »
This project is so good, especially open sourcing the project, very cool GLWIC!
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline HubertThemad
  • * St. Jude Supporter
« Reply #19 on: Mon, 12 June 2023, 10:26:09 »
This is freaking awesome
Offline boku
  • 東プレ株式会社
« Reply #20 on: Mon, 12 June 2023, 19:40:31 »
It's been a while since a new board IC has drawn my attention, WELL DONE!  :thumb:
PS: Please consider long spacebar support (10u) for this long boi
HHKB Pro2 Ivory | HHKB Pro2 Charcoal | Realforce 87UW | Realforce 101 | Edius V6KB | DN Piss Ogre
Offline Moods
« Reply #21 on: Mon, 12 June 2023, 22:33:58 »
This looks awesome! WKL would seal the deal for me! GLWIC  :thumb:
Offline masje
    • masjewerke
« Reply #22 on: Thu, 15 June 2023, 23:42:30 »
GLWIC
Thanks for all the kind words! BTW, WKL is coming……
Offline masje
    • masjewerke
« Reply #23 on: Thu, 15 June 2023, 23:43:59 »
Also, DISCORD link out now!! Please join if you’re interested!
https://discord.gg/HxJFHkyjbf
« Last Edit: Sun, 25 June 2023, 05:40:50 by masje »
Offline phatmasterq
« Reply #24 on: Sat, 17 June 2023, 05:49:08 »
this brings all the big pp's to the yard. i'm in. wkl a must. you're a wizard.
« Reply #25 on: Mon, 24 July 2023, 18:01:31 »
This board is almost as long as my username
Offline erretter
    • My Merch Shop
« Reply #26 on: Tue, 25 July 2023, 09:12:23 »
EDIT: Sorry posted in the wrong thread
« Last Edit: Tue, 25 July 2023, 09:34:08 by erretter »
Offline herfalerf
« Reply #27 on: Wed, 26 July 2023, 13:52:35 »
such longth. I think I would need a bigger desk, but i love it.
Offline doctorboy
    • ClackX
« Reply #28 on: Thu, 27 July 2023, 03:51:57 »
There are no compromises here. Looks like an interesting project and concept. Looking forward to seeing the first prototypes.
The lower MOQ makes more sense as well. GLWIC and have fun!
Offline Jona_1153
« Reply #29 on: Thu, 27 July 2023, 15:42:56 »
Chad Keyboard :thumb:
Offline lush_bunny
« Reply #30 on: Thu, 27 July 2023, 16:52:05 »
I don't think it's long enough, what else can we add besides the macro and the numpad?
Offline niakulah
« Reply #31 on: Thu, 27 July 2023, 21:03:00 »
Split spacebar and an option to use an encoder instead of a switch on the top left/right would be nice.
Offline lkkedward
« Reply #32 on: Sun, 30 July 2023, 11:39:56 »
chonky board is good board. look forward for build streams
Offline masje
    • masjewerke
« Reply #33 on: Wed, 02 August 2023, 06:03:47 »
Thanks for all the kind word guys!!
Added proto photos! Excited to share more with y'all ;D ;D ;D
Offline lush_bunny
Re: [IC]Muramasa - The Longestboi - Prototypes made!!
« Reply #34 on: Thu, 10 August 2023, 04:34:47 »
I'm still debating whether I am buying this or not. On one hand, I never knew how much I much I loved a full keyboard with the FR chopped off. On the other, I am looking for a productivity board with a southpaw numpad. Whatever happens, this is legitimately the most interesting looking FRL board IC I've seen, so godspeed OP.
« Last Edit: Thu, 10 August 2023, 04:50:52 by lush_bunny »
Offline Patty
  • do u like my cat yes or no
« Reply #35 on: Thu, 10 August 2023, 08:23:47 »
proto looks great, engravings on the weight are great although it's a personal one, board as a concept is wild but great, looking forward to hearing how it sounds!
Offline Nonnegaard
« Reply #36 on: Thu, 17 August 2023, 03:47:19 »
looks like Aeon. Even the colors are 1:1
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline masje
    • masjewerke
Offline Nonnegaard
« Reply #38 on: Thu, 17 August 2023, 05:09:46 »
https://geekhack.org/index.php?topic=116335.0
This?
Yes and no, Aeon was a more limited run that ran a while ago in Quests Discord. This is Aeon:
Offline masje
    • masjewerke
« Reply #39 on: Thu, 17 August 2023, 05:18:32 »
This?
LOL that really does seem similar XD
Maybe I need to offer other color options.
« Reply #40 on: Thu, 18 January 2024, 09:11:09 »
As someone who has a prototype and types on it (and will type on it for forever), I desperately want this in everyone's hands that are able to get one. You have huge support for this, and we're cheering you on! I hope a GB happens in the future, but if not, you are awesome for the plan to make it open-sourced
Offline tactilesbad
« Reply #41 on: Thu, 18 January 2024, 09:23:59 »
gb soon pls
Offline hottrout
  • I'd Hit Dat Key
« Reply #42 on: Sun, 21 January 2024, 09:36:31 »
I don't need any other boards, long you say hmmmmm.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline phinix
« Reply #43 on: Mon, 29 January 2024, 18:08:28 »
Jeee... Holy sh... yeah, that is niiiiice !!! :)
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline clay
  • No foams
« Reply #44 on: Thu, 16 May 2024, 01:09:34 »
I am hoping for a 1.6mm PCB and no foams
Offline Keeaboo
« Reply #45 on: Mon, 20 May 2024, 10:36:42 »
It's giving W1 and JackPickatea vibes. Not gonna be for everyone but I think it's a super nice design!
