Author Topic: [IC] KeyKobo Nori Keycap Set  (Read 15719 times)
Offline kahlilnc
    • KNC Keys LLC
« on: Sat, 17 June 2023, 14:50:53 »
Renders can be found here: https://imgur.com/gallery/DyA56aZ
Renders are done by lebowitz, Pensa73 and Synthereal
UPDATE 1: KITTING HAS CHANGE SINCE INITIAL POST: Added 2 Latin Alpha Kits and overall kitting changes according to the recommendations that we have received via the community
The keycap set is themed after SEAWEED and one of my favorite things to eat, SUSHI!
IC Form: https://forms.gle/figJt4dFv6XMHoWAA
Kitting
Kitting as well as pantones can be found here: https://imgur.com/CI8ONnr
Contact
Discord: https://discord.com/invite/knckeys
Discord Username: kahlilnc#1599
Email: knckeys@gmail.com
Vendors:
* NA: KNC Keys
* CA: AshKeebs
* KR: SwagKeys
* UK: Prototypist
* AU: PrestigeKeys
* SG: Qwertypop
* CH: NLandkeys
* ID: KeebsMark
* TH: Aiglatston Studio
* VN: Thekeeb.store
* Others TBD
If you want to become a vendor, please DM me via Discord (kahlilnc#1599).
Specs:
Material: ABS
Mold: Double Shot Injection
Sub-Legends: UV Printed
Manufacturer: KeyKobo
Designer: KNC Keys
We would love to expedite production and get this into everyone's hands ASAP. But for this to happen, we need there to be some interest. Please fill out the IC following this link: https://forms.gle/UKkpvRMt3bqD4wip6
Thank you for taking the time to look over my post. Please add me on Discord or comment in the IC if you have any questions or concerns. I am active on Discord and will check the IC regularly for the next few weeks.
« Last Edit: Fri, 18 August 2023, 22:45:37 by kahlilnc »
Offline airs
Re: [IC] KeyKobo Nori Keycap Set
« Reply #1 on: Sat, 17 June 2023, 14:58:56 »
Not bad - I would be more interested if it light latin alphas were the default (or offered at all).
Octagon v2, LZ CLS
Offline kahlilnc
    • KNC Keys LLC
« Reply #2 on: Sat, 17 June 2023, 15:01:49 »
Thanks for sharing. I will inquire if I can add two more kits.
Offline mr_foggy
  • neue = nope
« Reply #3 on: Sat, 17 June 2023, 15:08:56 »
merge the numpad with the basekit, make the novelties a separate kit, put alice spacebars in base.
nice set though. good to see more keykobo.
Offline kahlilnc
    • KNC Keys LLC
« Reply #4 on: Sat, 17 June 2023, 15:25:05 »
Thanks for the suggestions. I will inquire with the manufacturer.
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #5 on: Sat, 17 June 2023, 15:50:09 »
Your 40s kit is like the fever dream version of a pbtfans 40s kit. Any reason it's all icon mods when the base kit has text + icon (aside from the fact pbtfans do icon mods)?
  • r2 1.5u backspace should be a 1.75u
  • if the third and fourth row from the top are supposed to be in r3, then you have two 1.5u enters too many, replace them with regular and accented 1.25u enter
  • your lock key should be 1.75u, but also it's not supposed to be a caps lock key so it shouldn't have a caps lock icon, but also there's like ten people that actually still use that key so maybe just remove it...
  • ...and add another 1.75u spacebar because only having one is worse than not having any
Other than that I like the set.
Offline kahlilnc
    • KNC Keys LLC
« Reply #6 on: Sat, 17 June 2023, 17:18:06 »
Ahhh yeah, sorry, it was a last-minute switcharoo from PBTFans to KeyKobo due to the long wait times just to color sample. I will be redoing the kitting soon. Adding Latin Alpha Kits and going with the suggestions you have made. Thank you!
Online Rhienfo
  • GOTHETIGES
« Reply #7 on: Sat, 17 June 2023, 19:27:31 »
Colours are nice but as someone else already said, wish there was at least an option for latin alphas only, as I think the sublegends are unnecessary (the best bet is probably just an option, I do know that weebs are a huge market XD). Glad to see the switch from pbtfans to keybobo, since it will probably result in better quality caps. GLWIC
Offline Dmitri
« Reply #8 on: Sun, 18 June 2023, 11:20:52 »
interested
Offline sketch3v
  • Sketch (astro-keys)
    • Astro
« Reply #9 on: Sun, 18 June 2023, 18:47:51 »
white and green match so great. I like al alpha kit a lot more
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #10 on: Sun, 18 June 2023, 23:11:02 »
The kitting render for the numpad seems to be incorrect? These should be alpha colored. I know the board renders show the right color 1U zero so just wanted to let you know of the issue.
299931-0
Offline kahlilnc
    • KNC Keys LLC
« Reply #11 on: Mon, 19 June 2023, 14:51:31 »
Thanks for the feedback. I will have this corrected.
Offline EdgeOfInfinity
« Reply #12 on: Tue, 20 June 2023, 18:27:42 »
really like the colors. wish KKB had tripleshot tho.
glwic!
edit: actually i think they do have tripleshot, guessing colors are the issue.
« Last Edit: Thu, 22 June 2023, 17:51:25 by EdgeOfInfinity »
Offline kahlilnc
    • KNC Keys LLC
« Reply #13 on: Thu, 22 June 2023, 21:20:19 »
ALCON
@Synthreal and I have made the adjustments recommended by the community. Thank you all so for your suggestions. Would like your feedback before proceeding any further.
Offline keepoto
  • HHKB top for TKL pls
« Reply #14 on: Thu, 22 June 2023, 21:40:07 »
has KKB confirmed they have / will be making the moulds for icon mods and the 40s kit?
I think it's fine not to include numpad in base, as the increase in cost is not insubstantial. That being said, if you're going for a cheap base kit approach then it doesn't make sense to include novs in base.
Offline Theman2k
« Reply #15 on: Fri, 23 June 2023, 03:25:59 »
Why the numpad is separate?
Offline kahlilnc
    • KNC Keys LLC
« Reply #16 on: Fri, 23 June 2023, 07:39:41 »
Hey,
It is no longer separate. Just working on updates renders now.
https://imgur.com/a/AfQ1u7t
Please see the Imgur link for the updating kitting.
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #17 on: Fri, 23 June 2023, 08:26:07 »
Thanks for including the numpad to the base kit. I'll be joining this GB!
Offline ppatches24
« Reply #18 on: Mon, 26 June 2023, 01:03:50 »
Ill probably pick up a Alt Alpha Kit. Looks great. I just wish they were triple shot, but I understand price is a thing.
Love the colors
Offline J0hnojoheneczko
  • Discrod - https://discord.gg/26VvnCBzKZ
« Reply #19 on: Wed, 28 June 2023, 14:03:34 »
GLWIC
Offline kahlilnc
    • KNC Keys LLC
« Reply #20 on: Fri, 14 July 2023, 19:59:10 »
Love the colors
GLWIC
Please see the latest thread updates! Kitting has been completely redone. Please let me know of your thoughts!
Offline involuntarysoul
« Reply #21 on: Mon, 17 July 2023, 20:52:07 »
please make latin alpha the default, i cannot stand the Japanese sub-legends
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #22 on: Fri, 18 August 2023, 16:19:37 »
Should there be a 1u "00" for the numpad?  To go with the 1u "0" it currently has.
Offline keepoto
« Reply #23 on: Sat, 19 August 2023, 06:23:26 »
think the 1u 0 is intended to go with 96% layouts
Offline hottnucks
« Reply #24 on: Wed, 06 September 2023, 10:50:46 »
I will buy if latin base kit is an option. I will not buy if I'm forced to buy sub-legends AND then a latin child kit.
Offline lampmk
  • box art peddler
« Reply #25 on: Wed, 06 September 2023, 11:34:04 »
Very nice set! Looking forward to this one.
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
« Reply #26 on: Sun, 10 September 2023, 17:03:44 »
+1 for latin base
