Author Topic: [IC] GMK 3077 (Previously Brown on Beige)  (Read 130626 times)
Offline thicthacthok
« on: Fri, 23 June 2023, 02:19:56 »
I've decided to overhaul this IC with new sample colours from GMK. I've also taken all the feedback and changed the kitting slightly to better accommodate for everyone's needs. Hopefully most people will be happy with the new kits :')
The inspiration for this set was the OG Cherry dyesub keycaps from the NCR G81-3077SAU, that had faded to a nice brown colour.
IC Form     Discord
Base Kit
Hangul Alphas
Num Row
Spacebars
Colour Codes
Alphas - Custom colour matched
Mods - Custom colour matched
Legends - RAL8017
I sat at Geonworks with a GMK colour ring and his NCR G81-3077SAU comparing the two and we both came to the conclusion that CB and L9 more closely matches the NCR.
I originally planned to run 3K alphas since I really like the colour contrast but decided to go with the more original one instead.
Let me know in the IC form if you would like to see 3K alphas instead. Photo will be in the form.
I ended up purchasing the Dyesub keycap set and sending GMK the physical samples to colour match off. When I got the samples they were a little off so now I'm waiting for the 2nd round of samples.
Vendors
Mekibo - North America
Cafege - Australia
Geonworks - South Korea
Maamaadei - Malaysia/Singapore
Oblotzky - Europe
Prototypist - United Kingdom
Typo.works - Taiwan
ZFrontier - China
Aiglatson Studio - Thailand
Pricing
Base - $115USD
Hangul Alphas - $49USD
Hangul Num Row - $35USD
Spacebars - $25USD
Renders by Masje_
Horangi60 HHKB
Horangi80 WKL
Horgo Ergo TKL
G81-AH
I'll also be releasing a limited number of these fullsize keyboards and sell them together with the GMK set.
If there's demand, I'll increase the number of units.
Please let me know in the IC if you are interested.
« Last Edit: Sat, 04 May 2024, 10:47:00 by thicthacthok »
Re: [IC] GMK Brown on Beige
« Reply #1 on: Fri, 23 June 2023, 02:20:27 »
Changelog
- Taiwan, EU, China, and Malaysia vendors added.
- Custom colours for the alphas and mods from GMK standard colours. Physical samples were provided.
- Kitting expanded to 5 kits instead of the All in one Base and Hangul Alphas (Num row, Extensions, Spacebars)
- Removal of Extensions kit and moved basic 3 key 40s support to base and 1.75, 1.5u, 1.25u, 1u spacebars moved to spacebars kit
- Pricing adjustment with estimated sales numbers
- Added a 2nd 1u alt to the base kit
- Added accent ISO
« Last Edit: Sat, 04 May 2024, 10:47:17 by thicthacthok »
Offline Spazza
« Reply #2 on: Fri, 23 June 2023, 02:23:39 »
First.... I love TTT & Cafege
Offline pohpoh
« Reply #3 on: Fri, 23 June 2023, 02:25:18 »
Very cool ThiccyBoi. Any r4 bottom row avail tho?
Offline CAZ
  • Project Manager for Switchkeys
    • Switchkeys AU
« Reply #4 on: Fri, 23 June 2023, 02:27:23 »
More Beige More Better.
Love the design and can't wait to pick up a set.
Keep up the good work Johnge, been waiting for you to finally drop this ic for a while.
Offline mr_foggy
  • neue = nope
« Reply #5 on: Fri, 23 June 2023, 02:31:46 »
3K alpha would be veeeery nice though.
good set nonetheless.
« Reply #6 on: Fri, 23 June 2023, 02:32:00 »
I'll try whip up another R0/R5 kitting. Hopefully it hits MOQ
Offline vegs
« Reply #7 on: Fri, 23 June 2023, 02:51:48 »
Interested!
hhkb 4 life
buy less
Offline nordhelle
« Reply #8 on: Fri, 23 June 2023, 03:17:00 »
This is pretty
Offline Theman2k
« Reply #9 on: Fri, 23 June 2023, 03:24:41 »
That's nice but pricy, Hineybeige and Classic beige exist and are still available for pre order.
Offline densus designs
  • * St. Jude Supporter
« Reply #10 on: Fri, 23 June 2023, 04:41:03 »
ThicThacThok based, Cafege based!
Will buy!  :D ;D ;D
Offline ZavaZ86
« Reply #11 on: Fri, 23 June 2023, 05:04:53 »
135$ seems high for what the basekit is. Looks more like sub 125$ but otherwise looking good
Offline whirlwind
« Reply #12 on: Fri, 23 June 2023, 05:22:12 »
Brown never lost, this is awesome
Offline LMarci
« Reply #13 on: Fri, 23 June 2023, 06:17:50 »
Looks good but too expensive
Offline Arrinura
« Reply #14 on: Fri, 23 June 2023, 11:59:39 »
3K > L9 alphas
Consider Sys Rq and Break side print on Prt Sc and Pause. Ashkeebs as the Canadian vendor, please.
Offline Bunn3y
« Reply #15 on: Fri, 23 June 2023, 12:22:43 »
Great looking set. Can't fault with more beige.
Also, echoing what the poster above me have said, please consider changing/adding the legends to fit with the OG NCR board.  ;D
Collection: Ivery Praxis | HHKB Pro 2 | JTD.Works Ovinnik | Realforce R1 87u | Switchplate iiA Sanction
Offline GMKClassicRed
« Reply #16 on: Fri, 23 June 2023, 12:23:32 »
Can you include R3 Home and R2 Delete?
Offline Arrinura
« Reply #17 on: Fri, 23 June 2023, 13:23:50 »
Thought I'd add this as well to fit with OG NCR.
Offline IOVERCALLHISTIOCYTES
« Reply #18 on: Fri, 23 June 2023, 14:39:51 »
Brown accents? Brown numrow? I'm in without it but I think there might be a few of us who would roll w a brown alert look on a beige board.
I love R0 and I'd buy a kit but I'm one of a very small subset of people.
Everyone who thinks the pricing is high should remember what MOQ 250 pricing used to look like. Base kits were more than this.
Offline caap
« Reply #19 on: Fri, 23 June 2023, 22:22:54 »
Hi lovely set^^
The renders in the kitting show double Hangul sublegends but the keyboard renders show single sublegends. Which would it be?
Offline howGoodAreKeyboards
« Reply #20 on: Sat, 24 June 2023, 00:12:24 »
on the wishlist
professional button presser and clicker and also enemy of the state
Offline Rhienfo
  • GOTHETIGES
« Reply #21 on: Sat, 24 June 2023, 00:12:52 »
Very cool. Love the inspiration behind the project. As other people have said I do agree that 3K might be the best option to go here when it comes to the alphas, and maybe to fit with the theme more, replicate the keycaps on that NCR board as someone else said, if it is possible. I do think the price is a bit much for a beige set, so if it can be done I would love to see the price lowered down a bit or make it worth the price (such as maybe replicating the NCR Board keycaps, but that would probably make it more expensive if the price is already at 135).
Offline Hinkerbottom
« Reply #22 on: Sat, 24 June 2023, 12:45:48 »
this looks really great. i’m in as long as you keep R5 bottom row and double consonants for the hangul kit. gl!
+1 to matching legends to OG NCR, but it’s not a deal maker/breaker for me personally. 3K> too.
« Last Edit: Sat, 24 June 2023, 12:58:52 by Hinkerbottom »
Offline ph4nt0m
« Reply #23 on: Sat, 24 June 2023, 15:34:14 »
Could you please include R3 PgUp and R4 PgDn?
Offline VoodooBear
« Reply #24 on: Sun, 25 June 2023, 00:29:48 »
3 key 40's support (1.75u Back, 1.5 Ent., 1.25 Tab) would be lovely.  ;D
Offline HubertThemad
    • Podcast Links
« Reply #25 on: Mon, 26 June 2023, 09:25:37 »
Match made in heaven with the upcoming Glare65 GB in Goat Brown. GLWIC
« Reply #26 on: Tue, 27 June 2023, 22:57:57 »
Thanks for this, I'll try my best to match all the legends and side prints to be inline with the NCR.
gotchu
Offline actress
« Reply #27 on: Sat, 01 July 2023, 14:47:06 »
Yes pls
Offline J0hnojoheneczko
  • Discrod - https://discord.gg/26VvnCBzKZ
« Reply #28 on: Sat, 01 July 2023, 15:15:37 »
i like it
Offline B_D
    • bdskeyboards
« Reply #29 on: Tue, 04 July 2023, 17:01:41 »
looks pretty good and pricing is also nice, I might buy a set  ;)
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Offline Kinesiologist
« Reply #30 on: Tue, 04 July 2023, 21:38:45 »
Beige good.
Would love a dedicated Canadian vendor please
Offline Dmitri
« Reply #31 on: Thu, 06 July 2023, 12:41:42 »
a retro beige set without sublegend, tempting.
missing a spacebar kit
Offline gfreeman11898
« Reply #32 on: Thu, 06 July 2023, 14:25:07 »
Please consider OG design for print screen, scroll lock, and pause, see GMK Hineybeige.
Offline marcin_nyga
« Reply #33 on: Fri, 07 July 2023, 15:16:18 »
it's not better to produce a set at keykobo?
Offline pr0ximity
« Reply #34 on: Fri, 14 July 2023, 11:20:42 »
Maybe controversial take, but if it helps to get the price down skip the windowed keys. GMK's pad printing has been really bad lately, and I'm someone who loves windowed caps.
Very cool idea otherwise, I also prefer K3.
Offline actress
« Reply #35 on: Fri, 14 July 2023, 13:57:52 »
please keep the windowed keys
Offline Furki
« Reply #36 on: Sun, 16 July 2023, 12:27:59 »
Brown alphas look dope!
I'll definetely consider it together with the Hangul alphas!
Offline boku
  • 東プレ株式会社
« Reply #37 on: Wed, 19 July 2023, 16:51:28 »
There seems to be a few different groups of people interested in this set for different reasons, I fall amongst the brown lovers and would LOVE to see brown accents or brown alert style number row. Like some said before me, brown keyboards are gaining in popularity and this set would be a match made in heaven for them.
Pro2 Ivory | Pro2 Charcoal | RF 101 | Martingale Ver.SUS | Ogre | KFE CE
Offline Mcnos
    • GMK Fuyu
« Reply #38 on: Mon, 31 July 2023, 17:45:15 »
Considering this is imitating NCR Dye Subs, why not run with a PBT manufacturer unless it's for R0/R5 and that's a requirement if so, hit up CRP/Hammer?
Also, idk if I'm in the minority or maybe i didnt let my NCR sit in the sun long enough but did 3077 legends turn brown when fading?
« Reply #39 on: Wed, 27 September 2023, 19:14:23 »
It's been a while since I've checked back on this post but the set is going to run guaranteed. I'm hoping for mid to late Q1 2024.
I've read through all the feedback and comments and will try to accommodate for everyone.
I'll check back in by November or December with a revised kitting that will hopefully satisfy the majority.
Thank you all for your patience.
« Reply #40 on: Fri, 08 December 2023, 21:21:12 »
While kitting please think up brown num row
I’d pay MOQ 50 prices and buy two
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #41 on: Fri, 08 December 2023, 22:32:39 »
Brown Alert :thumb:
Offline usedchopstick
« Reply #42 on: Sat, 27 January 2024, 22:42:09 »
Would also like a brown num row. Brown alert. Also, comprehensive 40's kit would be nice.
Offline involuntarysoul
« Reply #43 on: Sun, 28 January 2024, 21:50:04 »
why not run with kkb? they have better molding than gmk now
Offline dcsenjoyer
« Reply #44 on: Sun, 28 January 2024, 23:01:56 »
KKB legends are inconsistent. Some are thick and some are thin, the kerning of modifier keys not consistent. Some caps got their legends misaligned vertically.
and I don't believe KKB color matching. KKB violet alert was supposed to be U9/CP, but it actually came out closer to L9, rather than CP. For stock colors of GMK, I have full trust in GMK.
I prefer the sound of GMK(0.1mm thinner than KKB)
« Reply #45 on: Mon, 29 January 2024, 00:40:19 »
i am looking really close, cannot find any defects
Offline dcsenjoyer
« Reply #46 on: Mon, 29 January 2024, 12:55:11 »
-the second "ac" from "Backspace" is fat
-"PgUp" is thick, "Pg Dn"is thin
-"e" from "Home" is thin
-"d" from "End" is thin
-"s" from "Insert" is thick
- "P" from "Pause" is thick
- "u" from "Pause" is partially thick
The kerning of modifier keys not consistent
- "T a b" can be better
- "Pg Dn" must be fixed (see "PgUp")
- "p" from "Caps Lock" is low
- "F 2"
- "F 9"
- "5" from "F5" is lower than "F"
- "Ente r"?
- "Print", "Insert", "Delete", "End" these legends are not centered vertically. A bit higher
Offline phinix
« Reply #47 on: Mon, 29 January 2024, 18:05:22 »
Nice.
« Reply #48 on: Tue, 30 January 2024, 00:44:51 »
i can live with all above, but i cannot live with the large S
Offline tactilesbad
« Reply #49 on: Tue, 30 January 2024, 03:43:29 »
mental gymnastics world championship right here.
please consider kkb honestly, base + brown numrow pls (or separate them they will be cheaper and nicer than recent GMK anyway)
