Author Topic: [GB] BSUN Aniya Switches LY stem with a full POM housing (Concluded and instock)  (Read 15312 times)
Offline DashanYYY
    • Unikeys
299995-0
Hi everyone, this is Dashan from Unikeys. Here is the link to the IC Post of the BSUN Aniya Switches: https://geekhack.org/index.php?topic=120459.msg3163246#msg3163246. Finally, we have received the switches from the factory, and we are ready to launch the in-stock sale.
Price
The price of the switch is 0.45 USD per switch.
Link to the Aniya Switches: https://unikeyboards.com/products/bsun-aniya-linear-switch-factory-lubed-edition
Form of Sales
Thanks to PH Studio and BSUN, we will be having the Aniya switches as an in-stock item, and the quantity is essentially unlimited. After the current batch is sold out, we will order the next batch from the factory very soon.
Please join our Discord server to stay updated: https://discord.gg/xprJb8Ta26
Time of Sales
Sale Starts: June 24th 12:00 PM ET
Switch Specifications
Switch type: Linear
Manufacturer: BSUN/YOK
Stem material: LY
Top and Bottom Housings: POM
Operating Force: 45g
Bottom-out Force: 50g
Pre-travel: 2.0mm
Total Travel: 3.2mm
Spring: 20mm Single Stage
Factory Lubed: Yes! On spring, stem feet, and stem sliders
Something Special
Let's start with the material choice regarding the design of the Aniya Switch; The Aniya Switch has a full POM housing and an LY stem. If you have read the X Switch IC/GB post and my comment on the LY material, you might remember that they are currently the smoothest material being used to manufacture switches. This might not be the most accurate way to describe them, but they do have a surface coefficient rate of 0.03 which is the lowest among major switch materials.
The LY material is a proprietary blend that first appeared on JWICK switches such as the SOTC. Even though they are all called LY, there are some major differences between JWICK's and BSUN's LY materials as they use different blend ratios. I wouldn't say one's blend ratio and formula are superior to another's as it is simply not the truth. Different blend ratios create different sound signatures in switches. The word on the street is BSUN's LY material is stiffer than JWICK's, and when you combine the BSUN's LY stem with a full POM housing, what you will get is a super smooth switch with a clacky and high-pitched bottom-out.
Besides choices of materials, PH studio also put some thought into the structural design; The Aniya Switch comes with an extended pole and a non-thickened bottom housing. The reason to do so is to create a concentrated sound profile while ensuring the bottom-out feeling is not too stiff or harsh (A major reason why some people hate long pole switches). I know some of you guys prefer switches with shorter stems, and even though the 3.2mm travel distance does look quite scary, they actually do not feel so bad thanks to the design. The Aniya Switch is very balanced with its concentrated sound and bottom-out feel.
The last thing I would like to mention here is BSUN's factory lubrication process. This is what I learned from them yesterday: Even though the Aniya Switch was released in the year 2022, BSUN's factory lube has been improving ever since. They will use their newest factory lubrication technique on the newest batches of the Aniya Switches we will be getting. The goal is to make the Aniya switches good-to-go stock to save 2 hours of your life. However, I am afraid to say that BSUN's factory lubrication is going to be perfect, or any factory's lubrication technique is ever going to be. I just want to address that some of the switches might need a little bit of your attention to make them better.
Vendor List
Global: Unikeys (https://unikeyboards.com/)
Singapore: https://ktechs.store/products/bsun-aniya-switches
UK and EU Vendor: TBD
Pictures
299997-1
299999-2
300001-3
300003-4
Socials and Videos
KeebTaro
title="PH Studio(BSUN/YOK) Aniy/Aniya - LY stem, POM housings / 出会ってしまったかもしれない" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>[/youtube]
title="Ridiculously SMOOTH - Bsun Aniya Switches" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>[/youtube]
title="Bsun Aniya linear (unikeyboards)" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>[/youtube]
title="Smit6y Works AeroBoard 70 with BSUN Aniyas Typing Sounds" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>[/youtube]
« Last Edit: Thu, 07 September 2023, 13:27:13 by DashanYYY »
Re: [Instock GB] BSUN Aniya Switches | LY stem with a full POM housing
« Reply #1 on: Fri, 23 June 2023, 11:18:10 »
Approved :thumb:
Offline DashanYYY
    • Unikeys
Offline DashanYYY
    • Unikeys
« Reply #3 on: Sat, 24 June 2023, 12:21:15 »
Aniya switches are live now!
Offline DashanYYY
    • Unikeys
« Reply #4 on: Fri, 30 June 2023, 14:03:15 »
Low quantity alert guys
Offline DashanYYY
    • Unikeys
« Reply #5 on: Mon, 10 July 2023, 17:29:12 »
The factory-lubed aniya switches are currently out of stock. Restock will happen soon
