Author Topic: Creamy VS Thocky switches, need some quiet  (Read 1473 times)
Offline huan588
« on: Tue, 27 June 2023, 08:50:27 »
I want some nice linear switches that will not break the bank completely. I am wondering which switches tend to be quieter, creamy or thocky switches. I ask because I need quiere switches but I do not want to get silent switches since they sound bland. I don’t mind if there is a bit of sound when you press the switch but I would like for them to still be quiet and still have some linear smooth sound omegle xender . Any recommendations?
« Last Edit: Thu, 29 June 2023, 14:13:25 by huan588 »
Offline autoelk
Re: Creamy VS Thocky switches, need some quiet
« Reply #1 on: Sat, 08 July 2023, 21:01:19 »
I think the most typical recommendation for budget linear switches are the Gateron Milky Yellows. You can also look at this spreadsheet from the mechkeys subreddit: https://docs.google.com/spreadsheets/d/e/2PACX-1vSWkz3vJflKwHt6aYwWWAULPU3NKbqfZj8J9h6IkcapPYVUbtxsaLXF9hnRmf-1aBAijMmBg0Jm6D7A/pubhtml#.
