Author Topic: [IC]Keylice-Dual-mode Alice style keyboard with arrow key, Great Surface Process  (Read 7690 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
Keylice - Alice 65%
Designed by Kenny 42 Studio
Intro
Greetings keyboard friends.
This is Velocifire team and this is our first time to introduce you an Alice layout keyboard. We hope you like it!
If you have anything question please don' t hesitate to ask us in the comment. :D
Designs
About appearance:Due to the designer's love for the layout of Alice and the rigid demand for Bluetooth connection, Kenny 42 studio designed this keyboard called Keylice. The designer believes that the Alice layout is already eye-catching enough in appearance, and the slender appearance adds a sense of softness for it, so there is no more personality elements are added.
About layout: The original intention of Keylice's layout design is to serve more people's demand, and users can adjust the layout according to their own needs. Therefore, on the basis of the arrangement of Chocolice, Keylice retains the middle 1U Fn key of the standard Alice layout, and adds 2.75u shift and split backspace.
About weight: In order to echo the bottom case, the shape of the weight has changed from the original rectangle to a trapezoid with both sides parallel to the extension of the bottom case, which can make the weight looks less dull and boring to a certain extent, and increase the sense of vitality.
Prototype
Anodized Ice Blue
Anodized Silver
Anodized Black
Anodized Gray
E-White
PCB Features
Flexibility:No felx cuts
Support:VIA
PCB thickness: 1.6mm
Bluetooth solution: Lotlab solution
Connection method: wired, Bluetooth 5.0
Switches installation method: Solder, Hot-swap
PCB material and process: imported black core immersion gold transparent ink
Mount: Gasket mount (whole plate/half plate/plateless), Top mount (whole plate/half plate)
Key layout: multi-layout Alice ( both hot-swap and solder PCB support multi-layout)
Hotswap PCB
Solder PCB
YouTube Video
Unboxing & Assembly & Sound Test
What can you customize?
Cases Color
Anodized: Ice Blue/Silver/Gray/Black
E- coat:White
Ice Blue
Silver
Gray
Black
E-White
Weight
Anodized aluminum (Black, Ice Blue, Silver) + High-gloss chamfer (Silver, Gold)
Stainless steel PVD: Silver/Black
Silver
Black
Crack Stainless steel: Black
Sandblasted electrophoretic brass
Add On
Plate, Walnut hand rest, Dual-mode PCB
Whole Plate: PC, FR4(TBD), Alu
PC
Alu
Half-Plate: FR4(TBD), Alu
Alu
Walnut Hand Rest
Explosion Diagram
Specification
Typing Angle:
Layout: Alice 65%
Size: 356.89mmx 127.92mm x 35.71mm
Weight: 2.15kg (without switches and keycaps)
Case Material: Full CNC 6063 Aluminum
Surface process Electrophoresis/Anodized
Front Height: 18.95mm in the middle, 21.1mm on both sides (including the exposed part of the foot pad: 1.30mm)
Default Plate: FR4
Preorder Information
Preorder Time: July 4th to August 31st, 2023 (The customer who purchases before August can have a gift of walnut hand rest. )
Estimated Delivery Time: 2 months after Preorder end
Sale format: Unlimited
Early Bird Price: From 320USD
Review(TBD)
We will send the prototypes to content creators as soon as possible.
Please stay tuned!  :D
The difference between GB products and prototypes
1. Larger weight chamfer.
2. Changed the shape of the screw fixing place of the plate
3. The rgb patch light is transferred from the original "~" key to "caps" key.
4. For prototypes, the Top mount is pre-installed with 0.3mm gaskets to ensure that the structure does not conflict. This will be further improved in the GB, and it can be used without gaskets.
Vendor(TBD)
Velocifire
Welcome to fill in the IC Form if you are interested in this keyboard! ;D
IC Form
Follow us for the latest information and more discussion about Keylice! ;)
« Last Edit: Thu, 06 July 2023, 04:11:05 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline Cobertt
    • Control on Caps
The way the arrow keys interfere with the position of right shift makes this a no go. Owl Labs did the same thing. Let Alice layout remain Alice layout and if you want arrow keys get an Arisu.
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65Midway LEKei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline NSMN
Honestly, I don't like that they are laughing in the face of the community, putting a product at 120$+ of what it is worth in the Chinese GB.
Offline john08099
  • Velocifire MK
Thank you for your feedback, this is not the final price, we will try our best to set a reasonable price after calculating the product cost with the other necessary cost.
Offline lionaangelin
can you add e-pink color too
Offline john08099
  • Velocifire MK
Hi there, thank you for your comment, we will consider adding this color if there will be a R2.  :)
Offline john08099
  • Velocifire MK
Hello everyone, we have changed the price from 340$ to 320$! :thumb:
Offline NSMN
I think you made a mistake again. 1599 RMB (chinese GB) is 220 USD,  not 320 USD. 100$ difference between those 2. To be so shameless is disgusting
Offline Jesher
Yeah the difference in GB price from CN is way too big makes this an easy skip, $320 for this is too much.
Offline Acid Opal
Pricing is a joke.
