Author Topic: Zoom65 - is there a way to disable battery?  (Read 589 times)
Offline amaneul
« on: Thu, 06 July 2023, 06:03:17 »
I run my Zoom65 wired, so I want to make sure I dont charge/use my battery at all.
Any idea? mobdro I know i can remove the battery but wondering if theres another way
« Last Edit: Fri, 07 July 2023, 02:28:18 by amaneul »
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: Zoom65 - is there a way to disable battery?
« Reply #1 on: Thu, 06 July 2023, 09:56:49 »
I don't think the battery is used in the wired mode, which according to a document I found about the board which wired mode is FN+Space. That should minimize the usage of the battery.
https://docs.google.com/document/d/1FiWiAnXCSsFjtqqpReWLJHxV8eZ7lqBj/edit
The rest of the user manual is on their website in-case you threw out the documents that probably came with the keyboard.
