Author Topic: Keyboard Recommendation  (Read 684 times)
Offline shubham7646
« on: Fri, 07 July 2023, 08:02:30 »
I need some help finding a decent, solid but not too pricey keyboard.
I don't have any idea what keyboard should I buy for my man. He mentioned mechanical keyboard, hot swappable, and multidevice (because he wants it to be able to connect it on his working and personal laptop). And soon he'll built his own computer 192.168.0.1 router login  .
Any suggestions/advice you could give would be much appreciated!
« Last Edit: Sun, 09 July 2023, 09:21:39 by shubham7646 »
Offline ELE.WORKS
Re: Keyboard Recommendation
« Reply #1 on: Fri, 07 July 2023, 20:26:37 »
cherry
Offline autoelk
« Reply #2 on: Sat, 08 July 2023, 21:06:23 »
I think if you're buying for someone else its probably easiest just to go with the keychron products because they have a rather complete feature set and come prebuilt.
