Author Topic: Project-EC - A topre 60%  (Read 16523 times)
Offline bowlkeyboards
« on: Thu, 13 July 2023, 21:12:03 »
IC FORM
Project-EC is my first foray into designing around topre. Combining a low front height, accented mid-layer, and soft typing feel, Project-EC is meant to be a premium upgrade to the normal topre experience.
 == Specifications and Details ==
 Layout -  6U HHKB, WKL, WK
 Materials - 6063 aluminum top and bottom housing, 6063 Aluminum or Polycarbonate mid layer, 6063 aluminum USB accent, stainless steel weight
 Typing angle - 8.5 degrees
 Front Height - 17.38 mm (without lip) EKH - 22.94mm
 Weight - 1.3Kg Unbuilt
 Mounting - Leaf Spring Silicone Gasket Mount (more information below)
 Other features:
  -Accented color midlayer
  -USB DB Carrier
  -Hidden DB and Molex-JST cable
  -C4 DB with ez-mate connector
  -PCB with JST connector
 == Mounting and Layout Details ==
For the mounting of this board i have used a similar method to my previous keyboard the oc-62. This utilized molded gaskets that isolate the plate. They are inspired by the F1 and F2 where it is a strip, but in this case, there is a nub on the top of the strip that holds the gasket into the case for easier assembly. This mounting fully isolates the plate from the case and the leaf spring cuts in the plate provide a softer bottom out feeling even with a metal plate.
Mounting Details:
Layout:
The PCB used for the prototype of this design is the EC-60 by Cipulot. Big thank you to cipulot for open sourcing this design and other designing resources.
Supported PCB layouts can be viewed here: LINK
== Sales Info ==
TBD - the most up to date info will be posted in my discord server
Current estimate would be $450 for a 100 unit soft cap for a base kit
== Renders and Prototype Images ==
Renders by Synthetics, Photos by me
Renders:
Photos:
== Current Status and Changelog ==
Proto V1 arrived and tested for the past month.
Prototype v1 thoughts:
 - Prototype built with Pro 2 stems, springs, and domes. Deskeys housings, housing gaskets, and #3 silencing rings
 - Aluminum plate with leafspring gasket mount provides desired soft bottom out feel without pinging or resonance
 - Side and rear profile highlight mid-layer accent as desired
 -Hidden DB and JST with DB carrier work as expected
 Current Status:
Received quotes for an “R0” organized in my discord
TBD
== Contact and other links ==
 You can join my discord here: https://discord.gg/n9FRZewwNR
 Follow the project on my website as well: https://www.bowlkeyboards.com/
== Special Thanks ==
Synthetics for the ideas and render help
Cipulot for the PCB and other open source resources
« Last Edit: Sat, 13 April 2024, 09:42:51 by bowlkeyboards »
Re: Project-EC - A topre 60%
« Reply #1 on: Thu, 13 July 2023, 21:13:15 »
Reserved for updates  ;D
Offline lush_bunny
« Reply #2 on: Thu, 13 July 2023, 21:37:58 »
Custom topre? Interesting.
Offline hunos
« Reply #3 on: Thu, 13 July 2023, 22:09:05 »
Thocc
Offline Oraeth
« Reply #4 on: Thu, 13 July 2023, 22:53:28 »
this board such a cutie
Offline nainaigogo
« Reply #5 on: Thu, 13 July 2023, 23:20:39 »
excited to see this
Offline andreas
« Reply #6 on: Fri, 14 July 2023, 00:31:37 »
This is really nice.
Good luck moving forward.
Offline vhaarr
« Reply #7 on: Fri, 14 July 2023, 00:54:03 »
glwic!
Please consider adding some kind of design flair visible while using it, like in the lower right corner blocker for example there is room for some love :D
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #8 on: Fri, 14 July 2023, 07:00:20 »
GLWIC
Offline growler
« Reply #9 on: Fri, 14 July 2023, 07:53:45 »
6u spacebar? I like it.
Tappity tap tap tap
Don't just stare at it ...
Offline Rhienfo
  • GOTHETIGES
« Reply #10 on: Fri, 14 July 2023, 09:56:24 »
More topre stuff is always good for the hobby. It does look really plain on the top so maybe an engraving on the bottom right area could look cool (similar to the hhkb professional 2 engraving there), If you could maybe offer an ec kit to go along with it, because harvesting old topre domes creates a lot of waste.
Just hope the price is good for this and GLWIC
Offline lush_bunny
« Reply #11 on: Fri, 14 July 2023, 11:29:13 »
+1 for ec kit. Topre modding/harvesting is a pain where I'm from.
« Reply #12 on: Fri, 14 July 2023, 12:14:18 »
Hello all, thank you for the interest!
I see some people saying the Hhkb top looks somewhat plain. I understand this sentiment, but due to the offering of WK, and WKL, I felt doing some sort of badge or engraving would not fit well. I will explore adding something there for the Hhkb variant  :cool:
In terms of an EC kit, this is definitely something I would be interested in pursuing  ^-^
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #13 on: Fri, 14 July 2023, 12:37:30 »
I like this
Offline growler
« Reply #14 on: Fri, 14 July 2023, 13:20:01 »
I'm a dummy, whats EC?
Tappity tap tap tap
Offline lush_bunny
« Reply #15 on: Fri, 14 July 2023, 16:04:38 »
Tappity tap tap tap
I assume electro capacitive (which is what topre domes are)
Offline growler
« Reply #16 on: Fri, 14 July 2023, 16:24:13 »
Ah yes, the dome, spring things, how or where do you get them, bet it's trickier than buying a few MX switches!
Tappity tap tap tap
« Reply #17 on: Fri, 14 July 2023, 17:43:04 »
Tappity tap tap tap
Yes domes, sliders, housings and springs are the extra topre components, all parts are available at Deskeys and soon, KLC! Ideally i will be able to oraganize a full kit for buyers where everything needed to assemble the board is included  ;D
Offline growler
« Reply #18 on: Fri, 14 July 2023, 17:51:05 »
Tappity tap tap tap
Tappity tap tap tap
Offline Furki
« Reply #19 on: Sun, 16 July 2023, 12:23:08 »
That side profile tho  :eek:
Offline hottrout
  • I'd Hit Dat Key
« Reply #20 on: Tue, 18 July 2023, 05:21:07 »
Yes, following
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline actress
« Reply #21 on: Thu, 20 July 2023, 05:53:24 »
such a cool project man!
8.5 degrees, beautiful side profile, WKL topre?!
In for sure
Offline SDKCAMPING
« Reply #22 on: Sat, 05 August 2023, 01:55:40 »
I'm a fan of this case design
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline phaxin
« Reply #23 on: Mon, 13 May 2024, 21:47:56 »
Love this. This hobby needs more custom topre that isn’t just a drop in from a hhkb or realforce. Any chance for a blank back weight? I’m not the biggest fan of the engraving.
« Reply #24 on: Tue, 14 May 2024, 02:06:56 »
really into all the love that EC is getting recently.
