Author Topic: Are there any keyboards that handle the natural angle of the pinky?  (Read 20966 times)
Offline kevanjosh
The natural design of the human hand is to have all the bones fan outward from the wrist. If you supinate your hand fully and flex the little finger, it wants to point to the center of the wrist bone cluster Speed Test https://vidmate.bid/ .
I've never seen a keyboard, ergonomic or otherwise, handle this angle.
So all contact with the pinky on the shift key (and A) is at an angle, and worse, the key throws straight downward in parallel to the other keys to its right.
Are there any keyboards where the key travel throws inward?
« Last Edit: Sat, 22 July 2023, 02:22:51 by kevanjosh »
Re: Are there any keyboards that handle the natural angle of the pinky?
« Reply #1 on: Wed, 19 July 2023, 08:03:38 »
Do the Kinesis boards fit what you're looking for?
https://kinesis-ergo.com/explore-keyboards/
