Author Topic: [GB] NOOK75 | A very different 75%  (Read 37372 times)
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« on: Wed, 19 July 2023, 10:57:14 »
NOOK75
Introducing a very different 75% layout keyboard that both turns head and type nicely
Designed by Raw Studio
Duration: 19/07/2023 - 10/08/2023 (August)
Fulfillment begins in November, 2023
Price: from $185
Worldwide shipping
Link: https://iconlabsofficial.com/product/gb-nook75-keyboard-kit/
Features
- Unique badge design
- Bottom case made out of thick CNC 6063 Aluminum
- 12 color options with various surface finishes (Anodization, E-coat, PVD)
- Designed to sound lovely with/without foam
Spec list
Typing angle: 6 degree
Dimension: 320*139cm
Height: Front 20cm, Back 34cm
Case Alu 6063 CNC
Gasket Mount
PCB 1.2mm, Hot-swap, Non Flex-cut, RGB, (Keymap VIA supported)
Traditional ANSI layout
Connection: Wired (type-C USB)
Daughter board
Foam kit including PCB Foam, Switch Foam IXPE, Case Foam x2
Complementary carrying case and screw driver kit.
Plate PC (Extra: Alu/FR4/POM)
*Kits (Gray, Silver, Navy, Coffee, Baby blue, Red and E-white) will come with complementary anodized badge/hook.
Sound test
More photos
Thank you very much!
« Last Edit: Tue, 08 August 2023, 09:34:01 by IconlabsOfficial »
Re: [GB] NOOK75 | A very different 75%
« Reply #1 on: Wed, 26 July 2023, 12:34:05 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
    • Iconlabs
« Reply #2 on: Tue, 08 August 2023, 09:33:34 »
Update with a quick review:
Offline Havattack
« Reply #3 on: Tue, 08 August 2023, 14:44:17 »
Is that purple ano? I love it. Not my kind of board, but that color is amazing. The accessory badge things are cool too.
