Author Topic: [IC] GMK CYL Beloved | GB: 11 Nov - 11 Dec  (Read 37738 times)
Offline mcmcmc
Re: [IC] GMK CYL Beloved - KA2017 Revival
« Reply #50 on: Wed, 04 October 2023, 22:22:24 »
final kits
added 1u =
added hangul kit : pls buy
removed alice bars : only add cost to base kit and i want to help vendors move deadstock
moved 2<3 & added raster : krelbit told me to
removed shinethrough : sorry but only few people will use it
« Last Edit: Sat, 04 November 2023, 08:37:05 by mcmcmc »
Offline Dreamre
    • kbdlife
« Reply #51 on: Wed, 04 October 2023, 23:16:52 »
Any chance the front printed legends for SysRq and Break can be removed? I just received Frost Witch 2, which has the front printed legends and the font looks pretty tacky than the previous GMK silk-screening.
Offline mcmcmc
« Reply #52 on: Thu, 05 October 2023, 00:11:17 »
hmm that’s weird. can you take a pic?
Offline aa212121
« Reply #53 on: Thu, 05 October 2023, 03:53:31 »
 :( i would have to buy the novelties just for the <3 key?
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #54 on: Thu, 05 October 2023, 05:41:28 »
no shinethrough kinda bummer ngl
Offline azhdar
  • Praise the AZERTY god
« Reply #55 on: Thu, 05 October 2023, 07:06:25 »
Looks good.
Modifier is gonna look good on my Blanc Sur Noir.
Azerty Propagandiste
Offline ankit
  • Formerly ankit-sachdeva
« Reply #56 on: Fri, 06 October 2023, 12:42:08 »
 :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank: :blank:
Offline caap
« Reply #57 on: Fri, 06 October 2023, 17:06:23 »
consider double consonant hangul! thank you :cool:
Offline subieBewies
« Reply #58 on: Fri, 06 October 2023, 22:30:23 »
Super keen for this one
What is the reason for the symbol keys in the hangul kit (apart from the pipe key)?
Offline mcmcmc
« Reply #59 on: Fri, 06 October 2023, 23:11:54 »
it is wat it is  :blank:
nothing, render error again. i totally missed that. photoshopped, fixed now
« Last Edit: Sat, 07 October 2023, 00:02:03 by mcmcmc »
Offline AstralYT
« Reply #60 on: Sat, 07 October 2023, 08:38:51 »
consider keykobo
Offline myanongh
« Reply #61 on: Tue, 24 October 2023, 16:09:23 »
Can you add alt-한/영, ctrl-한자 keys to the hangul kit?
Offline WU
  • WUkds
« Reply #62 on: Thu, 26 October 2023, 01:24:25 »
It has R5 , which is really novel.
Offline mcmcmc
« Reply #63 on: Thu, 02 November 2023, 06:28:18 »
GB: 11/11/23 (Singles Day)
$130 Base @250 MOQ
$45 Hangul @100 MOQ
$30 Novelties @150 MOQ
Offline mcmcmc
Re: [IC] GMK CYL Beloved - GB: 11/11/23 (Singles Day)
« Reply #64 on: Thu, 09 November 2023, 06:16:37 »
added deskmat  :thumb:
Offline mcmcmc
Re: [IC] GMK CYL Beloved | GB: 11 Nov - 11 Dec
« Reply #65 on: Fri, 10 November 2023, 20:09:04 »
GB thread posted :thumb:
