Author Topic: [IC] Createkeebs Luminkey80 -TKL F13 + ANSI/ISO Layout  (Read 13641 times)
Offline made in China
« on: Wed, 26 July 2023, 05:06:02 »
Hello and thank you for your support! We're glad to bring our new work 'Luminkey80' to you all!
Luminkey series custom mechanical keyboard- Luminkey80
Details:
- Layout: ANSI/ISO 80% TKL with F13 key, WK/WKL options
- Mounting: gasket mount
- Material: CNC 6063 aluminum case with copper weight
- Weight: ≈2.1kg (fully assembled)
- PCB: 1.6mm tri-mode hot-swap PCB
- Plate: 1.5mm PC plate
- Typing Angle: 7 degree
- Keycaps: Double-Shot WOB PBT keycaps / 9009 Double-Shot PBT keycaps (LED Indicator support)
- Switches: Customized switches made by Createkeebs x GATERON
- Price: barebone kit:255 USD; assembled:320 USD
- Date: 2023 Q4 in stock sell
- Vendors: will update in GB
We also prepare gifts for you: kits include an artisan keycap, carrying bag, and the barebone kit includes stabilizers.
Colors: Ano-Black, Ano-Silver, E-Retro White:
Badge: We offer 3 badge options to choose.
Sides:
Layout:
Plate & PCB:
Exploded view & Size:
Keycaps:
*LED Indicators and ISO keycaps need to extra purchase.
Artisans:
*Artisan Included in the kit (fully assembled & barebone)
Switches:
Thank you for your reading!
Discord: https://discord.com/invite/7vWtyKjjdA
Website: https://createkeebs.com/
« Last Edit: Wed, 06 September 2023, 01:01:52 by made in China »
Offline Thevenny
« Reply #1 on: Wed, 26 July 2023, 05:34:05 »
Split rshift it would be appreciated for a WKL..
Re: [IC] Createkeebs Luminkey80 -TKL F13 + ANSI/ISO Layout
« Reply #2 on: Wed, 02 August 2023, 02:24:24 »
Hi, Extra soldered PCB would support split rshift
Offline doctorboy
    • ClackX
« Reply #3 on: Wed, 02 August 2023, 07:55:54 »
Thanks for sharing your project!
Can you please share what "assembled" means here? What is included? Switches, keycaps?
More information about the extra options that will be available, would be great as well, since you mentioned an extra solderable PCB.
Thanks in advance. GLWIC!
Offline Sieglinde
« Reply #4 on: Wed, 02 August 2023, 23:09:36 »
Those arrow accents need to go.
« Reply #5 on: Mon, 14 August 2023, 02:23:46 »
Luminkey80 will provide pre-built version. (included switches, keycaps, stabilizer) No need to build/adjust when you received the keyboard.
Offline bigmaxnonions
« Reply #6 on: Sat, 19 August 2023, 09:33:32 »
Really like the look of this board. Will the PCB be QMK/VIA compatible
« Reply #7 on: Thu, 24 August 2023, 21:33:34 »
Yes, Luminkey80 is support QMK and VIA
Offline EdgeOfInfinity
« Reply #8 on: Thu, 31 August 2023, 13:52:30 »
will there be an optional internal weight or foam piece to install for those who prefer not to install the batteries?
« Reply #9 on: Wed, 06 September 2023, 00:58:29 »
We will send it out after installing the battery. LUMINKEY80 will also provide barebone kit and pre-built options.
