Author Topic: [IC] Navi60 - GB LIVE 10/9 - 11/8 - #lainttl  (Read 68153 times)
Offline psychetype
Re: [IC] Navi60 - "Serial Experiments Lain" themed 60% Keyboard - #lainttl
« Reply #50 on: Fri, 29 September 2023, 10:34:56 »
No more e-white?
Hi fuzzypanda24! Sorry e-white was voted out for e-beige :'(
Offline psychetype
Offline givemecopper
Re: [IC] Navi60 - GB LIVE 10/9 - 11/8 - #lainttl
« Reply #52 on: Mon, 16 October 2023, 23:20:37 »
Hello,
Super interesting board!
I have 2 questions:
1. I did notice some movements of the plate and PCB in Alexotos video. Is that totally fine to use?
2. Can I build the o-ring config with hotswap PCB?
Thank you!
Offline psychetype
« Reply #53 on: Wed, 18 October 2023, 11:09:44 »
Hello,
I have 2 questions:
Thank you!
Hi!
So we switched to a medium size o-ring (it was small before), which fixed the pcb movement. Also, yes that should be fine, but I would recommend getting these screws from KBDfans: https://kbdfans.com/products/kbdfans-m2-3-countersunk-flat-head-screw-kit. There are holes in the PCB/Plate for these screws, which will help prevent the pressure of the o-ring mount from dislodging the PCB and plate.
Btw, the GB is live until Nov 8th! Thanks for the comment! :thumb:
« Reply #54 on: Wed, 18 October 2023, 23:42:51 »
Thank you so much for your answer! I really appreciate it!  :D
Offline RACCOON93
« Reply #55 on: Sat, 09 November 2024, 09:48:33 »
Please anyone got the same issue?
Got the board few months back, it's a great looking board but.....anyone with the solution to get to the configuration at VIA.
With the supplied cable in the box, VIA can't detect anything...
Much appreciated for any support here.
Offline kins
« Reply #56 on: Sat, 09 November 2024, 10:55:03 »
same - had to flash with qmk instead
Offline mul7i
« Reply #57 on: Sat, 09 November 2024, 23:13:04 »
the discord has a fix for that
Offline kins
« Reply #58 on: Sun, 10 November 2024, 09:17:50 »
[/quote]
can't even get in the discord - been 3 weeks and requested twice
Offline psychetype
« Reply #59 on: Sun, 10 November 2024, 12:37:42 »
[/quote]
Sorry kins, links are updated! Just in case links are broken again, our email is support@psychety.pe. We also made sure to enable notifications for every post under our threads on Geekhack
« Last Edit: Mon, 18 November 2024, 15:20:22 by psychetype »
