Author Topic: [IC] Krush65 (Keyboard + Crush) Update: GB is open!!!  (Read 81074 times)
Offline nuxroskb
    • Keyboard from Vietnamese Maker
« on: Sun, 30 July 2023, 22:33:49 »
Hello everyone, I'm Nuxroskb . It's been a while since I've been meaning to make a cheap keyboard.
Up to now, I have finally completed the design and also completed the board more carefully, so I would like to introduce to everyone a new project of mine. Krush65 (Keyboard+ Crush)
Despite being an affordable keyboard, there is no cutting corner in quality. It comes with Aluminium or Copper weight that can weight up to 1.7kg before build. The keyboard will support both top mount/o-ring mount with various color and weight options to choose from so you can customize your beloved keyboard to the heart content.
Specifications
Typing angle: 7 deg
Front height: 19mm
Size: 315.3mm x 110.2mm
Weight:
Copper weight unbuild: 1,7kg
Aluminum weight unbuild: 914g
Dual - Mounting
Support both Top mount and gummy O-ring mount
PCB layout Support
Hotswap: 6.25u/7u spacebar, step cap, split backspace
Solder: 6.25u/7u spacebar, split spacebar, step cap, split backspace, ISO
Plate options
FR4/POM/ALU/CF/PP
Color & Weight options
Back/ Navy/Dark Green /Lilac/ Burgundy/ Silver/ PC/ Purple/ Grey/ Raw/ E-cream/ E-white
Update:
Streaming
[Alexotos]
[WeSwtch]
[Lightning]
[Keebaholics]
Soundtest:
Price
GB time: 4/30/2024
Vendor list:
US: Vala
EU: Keygem
UK: Prototypist
CA: Mech.land
Thailand: PJ Aiglatson Studio
VN: Nuxroskb
CN: Kezewa
OCE: Allcaps
SG: K.techs
Indonesia: Kukey
KR: GEON
JP: Basekey
PH: Zion Studios
MY: @liltip1104 (Discord)
Rest of the Word: Nuroskb
*Contact Allcaps for vendoring
« Last Edit: Mon, 29 April 2024, 19:58:49 by nuxroskb »
Offline PlayBox
Re: [IC] Krush65 (Keyboard + Crush)
« Reply #1 on: Mon, 31 July 2023, 13:53:17 »
glwic
propably sent from my amazon kindle 10th gen
Offline aicyborg
« Reply #2 on: Mon, 31 July 2023, 19:55:51 »
65% is probably the most populous segment at the moment - off the top of my head, a list of 65s that recently fulfilled or are due to fulfil soon: QK65 (two rounds), Zoom65 (two rounds and a V2), Jris65 (two rounds), Choice65, Cub65, Neo65, and Mode Envoy.
I appreciate that this uses more premium materials but you might struggle with making MOQ on this given that there are a lot of 65s out there you'd compete with and that I don't personally see a "gimmick" or niche for this to fulfil that's not already been fulfilled several times.
I don't want to discourage you or be overly critical but I think you'd either want to target an even lower price point or come up with something new to bring the market in order for this to succeed properly.
« Last Edit: Mon, 31 July 2023, 20:03:51 by aicyborg »
Offline stewfayew
« Reply #3 on: Tue, 01 August 2023, 19:00:53 »
I like the big copper weight. My arbitrary evaluation of the price is that it's decent. But it is very competitive out there. There may not be a ton of people who like copper as much as me.
Offline doctorboy
    • ClackX
« Reply #4 on: Wed, 02 August 2023, 07:35:06 »
Design-wise, IMO, it is very interesting. Unfortunately, there is already a board that has a very similar design, in the 60% format, the Leviatan.
The price is very good, but I believe that is due to the fact that we are considering 700 MOQ, which I tend to agree with previous comments, is very difficult to achieve nowadays. 65% segment is full of good choices. Even with a good price, I believe the majority of folks that enjoy this design already move forward with Leviatan (I know it is a 60%, but still).
My recommendation is for you to explore other paths with a lower MOQ.
On my geek side, I would like to see more info about the PCB, if it uses a USB daughterboard, etc.
Good luck with the IC.
Offline nuxroskb
« Reply #5 on: Fri, 04 August 2023, 00:22:52 »
At a glance, there will be similarities, but the side and design are different as you can see in these two pictures.
And the interior design is also very different, not at all like Leviatan. keyboard design aspect is very limited, most of the keyboards are almost the same, you can find that point across many keyboards currently on the market
https://imgur.com/a/XdYfEMm
To optimize the cost, people will usually reduce its weight, but for me I really like using a heavy keyboard so I tried to optimize and push the weight of the keyboard to the maximum and still have can keep prices stable.
I can make this keyboard for a better price with only 2 piece design (including weights and case) and 1 mounting like oring mount.
But I wanted a really high quality product so I added another of my favorite mounts, the top mount. However that will lead to the cost will have to be a bit higher because at that time I have to design 3 pieces. (Top-bot-case)
That's what I can't say about the price compared to other cheap keyboards.
But to make a cheap keyboard universal to everyone but its quality is not good, that is not the purpose of my keyboard design.
Outside of looks, I'm very focused on the feel of typing, previous projects like RE65 I had to do 7-8 proto and lasted it for 2 years to be able to open the first GB. I really want my keyboards to achieve the best typing experience for consumers.
Offline Amras
« Reply #6 on: Fri, 04 August 2023, 05:39:59 »
I really like the design of this keyboard.
Any chance you folks know when it will go live for Group buy?
Offline NSMN
« Reply #7 on: Fri, 04 August 2023, 07:17:00 »
Is not even close to Levitan
Offline SDKCAMPING
« Reply #8 on: Sat, 05 August 2023, 02:00:36 »
The only similarity to leviathan is the case resting on a big weight as a base and exposed on the side. I think the Luna from Percent studio and such were the first I've ever seen do it this way and it does look quite good. Leviatan and this also may look very similar because of the silver and copper weight. Though I think both boards look a little too simple so it's not a surprise they are similar. I prefer leviathan PCB mount though.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Dmitri
« Reply #9 on: Fri, 11 August 2023, 17:19:46 »
Split spacebar 3u or 2.75?
Offline nuxroskb
« Reply #10 on: Fri, 11 August 2023, 21:55:38 »
Split spacebar 2.75u
Offline CodemameGlitter
« Reply #11 on: Sat, 12 August 2023, 02:27:41 »
IDK I feel like the bigass copper weight, a top mount at this price which only akko has done so far it seems, along with the gummy dual mount seems compelling enough to me to take it over a qk or a jris
Offline phoenixrage
« Reply #12 on: Sat, 12 August 2023, 12:21:17 »
definitely interested.  Any sound tests?
« Last Edit: Sat, 12 August 2023, 12:23:12 by phoenixrage »
Offline nuxroskb
Re: [IC] Krush65 (Keyboard + Crush) Update Vendor + Soundtest + Prototype
« Reply #13 on: Wed, 21 February 2024, 09:05:55 »
Offline daeyul
« Reply #14 on: Wed, 21 February 2024, 11:53:07 »
gb when?
Offline aristus
« Reply #15 on: Wed, 21 February 2024, 13:59:43 »
Will PC case be offered?
Offline nuxroskb
« Reply #16 on: Wed, 21 February 2024, 23:01:51 »
gb when?
We are manufacturing instock 300units
Offline nuxroskb
« Reply #17 on: Wed, 21 February 2024, 23:02:27 »
That's right. PC case will be provided
« Reply #18 on: Fri, 23 February 2024, 19:05:33 »
Do you have an idea which month this will be available?
Sent from my Pixel 8 Pro using Tapatalk
Offline Nevrest
« Reply #19 on: Sat, 24 February 2024, 16:02:39 »
Please add split LShift on solder. ISO kinda sucks without having the full layout.
Offline nuxroskb
Re: [IC] Krush65 (Keyboard + Crush) Update Streaming + GB Time
« Reply #20 on: Sat, 30 March 2024, 19:59:39 »
Offline apricotmoon
« Reply #21 on: Sun, 31 March 2024, 04:55:32 »
Echoing the request for split left shift support, ideally on both PCBs but solder especially. Not sure of the point of ISO return cluster support without NUBS?
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #22 on: Mon, 01 April 2024, 02:54:30 »
+1 split left shift
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Akele
« Reply #23 on: Wed, 03 April 2024, 01:43:56 »
+1 split left shift
I'll add my +1 too.
Offline Wise Donkey
« Reply #24 on: Wed, 03 April 2024, 07:41:08 »
I agree with Doctorboy. I'd like some info on the PCB and daughter board.
Offline z4nn1ch
« Reply #25 on: Wed, 10 April 2024, 02:02:09 »
Specifications
Typing angle: 7 deg
Front height: 19mm
Weight:
Dual - Mounting
PCB layout Support
Plate options
FR4/POM/ALU/CF
Update:
Streaming
[Alexotos] https://www.twitch.tv/videos/2104315274
[WeSwtch] https://www.twitch.tv/videos/2104836121https://www.twitch.tv/videos/2104836121
Soundtest:
Price
Estimate GB time:
In April
Vendor list:
US: Vala
EU: Eloquent Clicks
UK: Prototypist
CA: Mech.land
VN: Nuxroskb
CN: Kezewa
OCE: Allcaps
SG: K.techs
Indonesia: Kukey
KR: GEON
Eloquent clicks just wrote to me that they will not be the vendor for EU.
Offline nuxroskb
« Reply #26 on: Fri, 12 April 2024, 07:37:24 »
Specifications
Typing angle: 7 deg
Front height: 19mm
Weight:
Dual - Mounting
PCB layout Support
Plate options
FR4/POM/ALU/CF
Update:
Streaming
Soundtest:
Price
Estimate GB time:
In April
Vendor list:
US: Vala
EU: Eloquent Clicks
UK: Prototypist
CA: Mech.land
VN: Nuxroskb
CN: Kezewa
OCE: Allcaps
SG: K.techs
Indonesia: Kukey
KR: GEON
I explained this on my Discord. Because I work with Manu, Eloquent's ex product manager, and got confirmation from him. But after he left Eloquent and there was no handover of work, there is now a bit of a misunderstanding.
For the EU Vendor it will be Keygem
Offline nuxroskb
« Reply #27 on: Fri, 12 April 2024, 07:38:14 »
+1 split left shift
Yeh I added split left shift to the PCB solder. Please check !!!
Offline nuxroskb
Update:
1. EU vendor: Keygem
2. I added a split left shift to the PCB solder
3. Extra:
PP plate
Case + weight
4. Streaming + Soundtest
5. GB time
Offline scorcher36
Please reconsider the US vendor for this GB. They are backed up and their fulfillment is very slow. A lot of people have raised concern about their slow fulfillment and overall engagement in their server and yours. Unlike re65 this is going to move in high quantity therefore it is best to choose other vendors who are more competent to handle this kind GB. Novelkeys, divinikeys, knc keys. As long as the vendors are not backed up like vala.
Offline Wise Donkey
Scorcher36 brings up a valid point. I would say if not an another vendor, maybe consider more than one for US.
Offline NHandKeebs
Are there any images of the raw finish/machine mark weight option? Trying to decide between silver and that one. Would be greatly appreciated 👌. Also support an additional/alternate US vendor.
Offline nuxroskb
Re: [IC] Krush65 (Keyboard + Crush) Update: GB is open!!!
« Reply #32 on: Mon, 29 April 2024, 20:01:56 »
GB is open !!!
Vendor List:
US: Vala
EU: Keygem
UK: Prototypist
CA: Mech.land
VN: Nuxroskb
CN: Kezewa
OCE: Allcaps
SG: K.techs
Indonesia: Kukey
KR: GEON
JP: Basekey
PH: Zion Studios
Offline Wise Donkey
« Reply #33 on: Mon, 29 April 2024, 20:38:20 »
Are we required to use region vendors? Can someone in US use Prototypist? Or, directly order from Nuroskb?
Offline luvtravis
« Reply #34 on: Mon, 29 April 2024, 23:32:25 »
I don't see the GB at Vala (US Vendor)..
Is there a change for the US vendor?
GB is open !!!
Vendor List:
US: Vala
EU: Keygem
UK: Prototypist
CA: Mech.land
VN: Nuxroskb
CN: Kezewa
OCE: Allcaps
SG: K.techs
Indonesia: Kukey
KR: GEON
JP: Basekey
PH: Zion Studios
Offline nuxroskb
« Reply #35 on: Tue, 30 April 2024, 03:03:06 »
Okay no problem. Because I don't have a region lock
Offline nuxroskb
« Reply #36 on: Tue, 30 April 2024, 03:04:05 »
GB is open !!!
Vendor List:
US: Vala
EU: Keygem
UK: Prototypist
CA: Mech.land
VN: Nuxroskb
CN: Kezewa
OCE: Allcaps
SG: K.techs
Indonesia: Kukey
KR: GEON
JP: Basekey
PH: Zion Studios
They will live tmr. Because today in US is not yet April 30
Offline Nerrion
« Reply #37 on: Tue, 30 April 2024, 04:02:46 »
I don't see the GB on Keygem.
Offline nuxroskb
Offline ahmedshibly
« Reply #39 on: Wed, 01 May 2024, 03:14:12 »
I am want to join the GB, Can you provide me china GB link?
Also what is the best way to order from Bangladesh?
Offline nuxroskb
« Reply #40 on: Wed, 01 May 2024, 05:28:45 »
DM me on Discord. I'll support you
Offline T3TRAAA
« Reply #41 on: Wed, 01 May 2024, 08:56:39 »
Love the keyboard and am planning to join the group buy. Any chance you could provide the weight of the polycarbonate body, SS and Aluminium weights. Thinking of bringing the keyboard around study and travel so am concerned about the final build weight. Thinking of either getting PC case + aluminium or PC case + SS.
Offline NumPadEnjoyer
« Reply #42 on: Wed, 01 May 2024, 10:50:09 »
I'm not gonna lie this board reminds me a lot of the mode sixtyfive that just came out.
Offline alexhipa
« Reply #43 on: Wed, 01 May 2024, 18:25:24 »
I'm quite interested on this board, but just a small doubt that worries me: Why is there no GB post for this IC under "Group Buys and Preorders" subforum?
Offline nuxroskb
« Reply #44 on: Thu, 02 May 2024, 00:09:48 »
If you aim to be compact and easy to carry, go with aluminum weight.
But if you want better sound then go with SS or Copper weight
Offline nuxroskb
« Reply #45 on: Thu, 02 May 2024, 00:12:10 »
Because I didn't create it on the "Group Buys and Preorders" forum, all my previous GB are like that. I find that posting in multiple places will dilute the information.
Offline nuxroskb
« Reply #46 on: Thu, 02 May 2024, 00:26:28 »
GB Krush65
US: Vala
https://vala.supply/products/krush65-keyboard
EU: Keygem
https://keygem.com/products/krush-65-group-buy
UK: Prototypist
https://prototypist.net/collections/live-group-buys/products/group-buy-krush65-keyboard-kit
CA: Mech.land
https://mech.land/products/krush65-hot-swap-group-buy
https://aiglatsonstudio.com/products/krush-65
ROW: Nuxroskb
https://nuxroskb.store/products/krush65
OCE: Allcaps
https://allcaps.store/products/gb-krush65
SG: K.techs
https://ktechs.store/products/krush65-keyboard-kit-gb
Indonesia: Kukey
https://kukey.studio/collections/krus65-by-nuxros
KR: GEON
https://geon.works/collections/krush65
JP: Basekey
https://basekeys.jp/products/krush65
PH: Zion Studios
https://docs.google.com/forms/d/e/1FAIpQLScHH4Fnxoi0yghVFOpMWxkivuJm8032XcVgyLFgINaPX-n4hA/viewform
Offline alexhipa
« Reply #47 on: Fri, 03 May 2024, 08:11:02 »
I can understand that reason, but reading what Group Buy Rules and Guidelines (Updated 2023-09-11) (https://geekhack.org/index.php?topic=115197.0) states, every IC must have its corresponding GB post in order to be reviewed and approved by GH's moderation team.
It's just my opinion, but don't you think that in order to avoid any kind of suspicion about possible frauds or exit scams (I am not saying that this GB will be that) and in terms of transparency and best practices, would't it be a good idea to publish a GB post under "Group Buys and Preorders" forum for this keyboard? Then you can also post there all the updates during manufacturing phase till the delivery to vendors...
As I said before, that's just my opinion and maybe I'm wrong and this IC is the normal way of doing things for a GB...but for sure that from my side I would be calmer and safer in joining this GB...
Offline nuxroskb
« Reply #48 on: Thu, 16 May 2024, 00:43:31 »
4 more days left
Offline pseudonym
« Reply #49 on: Sat, 18 May 2024, 00:50:19 »
The aluminium weight is the same material as the case, but it is just coloured in a copper look?
