Author Topic: [IC] DCS Hangul (updated March 11, 2026)  (Read 75866 times)
Offline ggggggg
  • schmeiß die forties durch den club
Re: [IC] DCS Hangul (updated 03/5/2025)
« Reply #100 on: Thu, 08 May 2025, 03:12:48 »
Just FYI if you're doing Alps, Alps ABS doubleshot DCS keycaps interfere with the switches on the entirety of the home row. Alps PBT DCS does not have this issue at all, I strongly suggest dye-sub PBT if you're doing Alps DCS.
Can you link to a discussion? First time I hear of this, have got an alps wob set sitting and waiting for an eventual alps build.
Offline Figgy
« Reply #101 on: Thu, 08 May 2025, 06:01:54 »
I read about it on the Sandkeys ME Discord server (owned by the runner of DCS 9009, which had Alps kits) so I've attached a screenshot. I couldn't find anyone talking about it on GH. Additionally, here is a video which I believe demonstrates said interference, high pitched tapping noise when pressing home row keys compared to keys on other rows.
Offline Thebloodyez
  • Just a random keyboard builder.
« Reply #102 on: Thu, 08 May 2025, 06:16:08 »
I want 10U ALPS for a NeXT version! :p
GLWIC!
Offline kennnyshiwa
Re: [IC] DCS Korean Beige (Alps + MX) 9/8/2023 Update
« Reply #103 on: Thu, 08 May 2025, 12:17:23 »
Hell yeah! Love seeing a new alps set come to life
« Last Edit: Thu, 08 May 2025, 12:23:44 by kennnyshiwa »
Offline joy.o
« Reply #104 on: Sun, 31 August 2025, 22:41:52 »
Any motion?
Offline danielsun23
Re: [IC] DCS Hangul (updated February 6, 2026)
« Reply #105 on: Sat, 07 February 2026, 11:45:12 »
bumping because IC updated
Offline joy.o
« Reply #106 on: Sun, 08 February 2026, 01:11:39 »
 :eek:
Offline cht1821
« Reply #107 on: Sun, 08 February 2026, 10:16:27 »
Do you have a discord to join?
Offline getupbuzz
Re: [IC] DCS Hangul (updated February 23, 2026)
« Reply #108 on: Fri, 27 February 2026, 07:10:11 »
Looking forward to the dual-shot abs alps in the future!
Offline mr_foggy
  • neue = nope
« Reply #109 on: Sat, 28 February 2026, 10:05:58 »
**** yes PBT DCS
as I said 100% in
