Author Topic: 60% keyboard with knob  (Read 5550 times)
Offline krystalbulingbuling
« on: Wed, 16 August 2023, 01:56:20 »
There are no 60% keyboard with knob on market, if you have, please share your picture.
Offline Rhienfo
  • GOTHETIGES
Re: 60% keyboard with knob
« Reply #1 on: Wed, 16 August 2023, 04:57:06 »
I found a hotswap pcb on krepublic that has a knob on it, however you will need to use split backspace as the knob is on the top right, it does have via so if you want a backspace in the top row, than you can swap the keys so delete is on the key to the left of the knob. The pcb seems to be compatible with all gh60 cases so any case will work there. From people who have used it the rotary encoder is meh, but it's still the only commercial example I can find.
Link to it is here - https://kprepublic.com/products/bm60ec-bm60-ec-rgb-60-gh60-hot-swappable-custom-mechanical-keyboard-pcb-programmed-qmk-via-rgb-switch-type-c-rotary-knob
The only other example I've seen was this GSKT-00 by pr0ximity that has a knob instead of an esc key. I'm not sure if he put it on there himself or it was an already existing pcb though.
GSKT-00 Poly by josh, on Flickr
Hopefully this helps somewhat.
