Author Topic: Strange Caps Lock problem  (Read 1155 times)
Offline gregh
« on: Wed, 13 October 2010, 15:02:43 »
Both of my keyboards, a DAS Pro and a Filco tenkeyless, will just repeat AAAAAA ... when I hit caps lock. As far as I can tell, all of my other keys work just fine.
Any idea what might be causing this?
Both keyboards are using cherry blue switches, though I'm sure it's nothing to do with that.
Thanks for taking the time to read about my problem. :)
Offline WhiteRice
« Reply #1 on: Wed, 13 October 2010, 15:05:11 »
Have you tried a different port? Might be a mobo issue. Do you have any autohotkey software running in the background?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Wed, 13 October 2010, 16:35:58 »
Since A is right next to Caps Lock, it could very well be a mechanical problem. Try taking off the key cap of either.
