Author Topic: 【IC】MM Studio覧Class 80R2  (Read 28402 times)
Offline Totoro
« on: Wed, 23 August 2023, 02:54:31 »
Hello, long time no see! Thank you again for your all love and support for Class 80.
In the time when there are no updates, we are still creating with our hearts-Class80 R2 is coming.
Join MMkeyboard Discord: https://discord.gg/3Mv5gNDbxZ
1.Design:
  • Layout: WK/WKL 80%
  • Case materials: 6063 aluminum
  • Color:Retro E-White, Retro E-Red, Retro E-Green
  • Size: 39.34*18.95*2 cm (L*W*H)
  • Typing angle: 7 degrees
  • PCB: 1.6mm Wired Hot-swap & Wired Soldered & Wired EC kit (With Niz standard switches and plate stabs)
  • Plate: POM/ Stainless Steel (EC PCB)
  • Mounting: Top Mount, Gasket Mount(Plateless Supported)
2. Inner and Structure:
Changes from Class80 R1:
a. Class80 R2 only provide wired version. (Solenoid and buzzer supported.)
b. The internal weight is changed to stainless steel with special surface
treatment to greatly improved the steadiness.
c. PCB: Hot-swap and solder version are available with 1.6mm no flex cut.
The most important is that we have added Wired Capacitive EC kit for you
to choose, which contains switches and stabs of NIZ standard just like Class60.
P.S: All PCB for Class80R2 will support Class80 R1 case.
Hot-swap PCB Layout
Soldered PCB Layout (Plateless Supported )
Wired Capacitive PCB Layout
(The EC plate we provide is tsangan layout: 7u bottom row, 2u BS)
3.Badge :
We provide a blank badge as standard and fixed it with magnetic suction.
At the same time, we will provide an additional random badge the same color as the case.
4.Indicator light module:
We have modified the fixing method of the indicator light for easier installation.
Retro Colors
The whole kit includes:
Alu keyboard case
Internal weight: stainless steel
Badge: Alu
Solenoid and Buzzers
1.5mm plate: POM / Stainless steel (EC only)
3.5mm Poron plate foam
0.5mm PE foam
PCB: Soldered(with 5mm Poron plate foam)/Hot swap/Wired capacitive(EC)kit
Type-c daughter board
Case foam : 2*1mm foam, 2mm HS foam
Gasket poron
Top mount silicon pad
Feets
Screws and tools
Prices:
Wired standard kit: $355
Wired Capacitive kit: $450 (EC kit includes everything needed to build except keycaps)
GB Date: About Oct (TBD)
Limited Quantities: TBA
GB method: FCFS Instock sale, Order fullfilled within 2 weeks
GB link: TBA
Extras:
Indicator Light Module(Optional): $20
Extra Foam Kit(Optional): $15
1.5mm plate foam
3.5mm plate foam
0.5mm PE sheet
2mm hot-swap case foam
2*1mm case foam
Gasket poron
Extra Tools and others(Optional): $5
Screws and tools
Feets
Gasket poron
Type-C daughter board
PCB extras GB will be opened later.
More Renders
« Last Edit: Wed, 23 August 2023, 21:18:55 by Totoro »
Offline lampmk
  • box art peddler
Re: 【IC】MM Studio覧Class 80R2
« Reply #1 on: Wed, 23 August 2023, 09:57:33 »
Nice. Will the EC kit be sold separately? I would love to buy one for my R1.
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
Offline takuto
« Reply #2 on: Wed, 23 August 2023, 10:23:08 »
YES, so glad this is getting an R2. Waiting for my Class60, but already want to plan a build for this one too.
Offline Totoro
« Reply #3 on: Wed, 23 August 2023, 19:49:09 »
Will run a pcb GB after the instock sell and the pcb gb fullfillment is about 5 weeks.
Offline Totoro
« Reply #4 on: Thu, 24 August 2023, 01:37:04 »
Offline Surefoot
« Reply #5 on: Thu, 24 August 2023, 01:50:51 »
I'll try and grab one, was unlucky the first time around... Thanks for the R2.
Offline tko2007
« Reply #6 on: Thu, 24 August 2023, 05:07:14 »
Am I correct, ISO Layout only on soldered version. What are the next steps. Definitely trying to get one.
Offline Totoro
« Reply #7 on: Thu, 24 August 2023, 20:04:23 »
Yes,Will run a pcb GB after the instock sell and we will post it
Offline khoathanh2807
« Reply #8 on: Sat, 26 August 2023, 01:46:57 »
Where is the Brass plate option?
You don't make the extra Brass plate option anymore?
Offline juliday
  • Synth, Controller, and Keyboard
    • SagakLabs
« Reply #9 on: Sat, 26 August 2023, 01:53:48 »
Is the stainless plate brushed? or glassy?
Offline Totoro
Re: 【IC】MM Studio——Class 80R2
« Reply #10 on: Mon, 28 August 2023, 01:55:16 »
Brushed SS.
« Last Edit: Mon, 28 August 2023, 22:03:37 by Totoro »
Offline Totoro
« Reply #11 on: Mon, 28 August 2023, 01:58:09 »
Yes, there is no Brass plate option anymore, only POM plate and Stainless steel plate
« Reply #12 on: Mon, 28 August 2023, 09:45:58 »
Oh it's pretty bad news for me! Guess I will choose only EC option then. I plant to buy both EC PCB and normal PCB if it has Brass plate for normal PCB.
But anyway thank you!
Offline Deru
« Reply #13 on: Mon, 28 August 2023, 11:47:33 »
Are there any plans to have a split right shift pcb?
Offline CaesarAZealad
  • Racc
« Reply #14 on: Mon, 28 August 2023, 14:47:33 »
I want this but I don't need any more aluminum boards. My NCR80 is gonna have to suffice for now :(
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline Totoro
« Reply #15 on: Mon, 28 August 2023, 20:01:14 »
That's OK to choose the EC kit, thank you again!
Offline Totoro
« Reply #16 on: Mon, 28 August 2023, 20:15:23 »
Hi, sorry that no plan to have other pcbs. only Hot-swap PCB & Soldered PCB &Wired Capacitive PCB(The EC plate we provide is tsangan80% layout: 7u bottom row, 2u BS)
Offline Totoro
« Reply #17 on: Mon, 28 August 2023, 20:19:11 »
Hi, Thanks for your feedback. Yes, our case materials are still 6063 aluminum.
Offline EdgeOfInfinity
« Reply #18 on: Thu, 31 August 2023, 14:18:53 »
the rendered colors look really great! hopefully they look as good in person
Offline Mcnos
    • GMK Fuyu
« Reply #19 on: Thu, 31 August 2023, 21:56:15 »
Does it have ALPs support?
Offline Razer1987
« Reply #20 on: Fri, 01 September 2023, 07:37:44 »
Hi, will the EC plate support ISO?
Also any chance to get a blanck weight? I
I know it is just the bottom but I struggle a bit to see the link between old computer board and Famicom pad.
« Last Edit: Fri, 01 September 2023, 07:45:23 by Razer1987 »
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #21 on: Sun, 03 September 2023, 04:07:39 »
No carrying case in base kit?
ォHow much wood could a woodchuck chuck if a woodchuck could chuck wood?サ
Offline Totoro
« Reply #22 on: Sun, 03 September 2023, 21:55:16 »
Hi, there is keyboard bag as for carry case in the base kit.
Offline Totoro
« Reply #23 on: Sun, 03 September 2023, 22:10:44 »
Sorry but the EC plate can only support single layout out duel to the EC switch attributes, but we'll provide platefile.
Btw we'll give every kit both a blank badge and patterned badge.
Offline Totoro
« Reply #24 on: Mon, 04 September 2023, 00:38:14 »
sorry that class80r2 don't support ALPs
Offline sntXrrr
« Reply #25 on: Mon, 04 September 2023, 17:59:18 »
Any chance you will do a new Class65 with solenoid and buzzer support?
Offline Totoro
« Reply #26 on: Tue, 05 September 2023, 04:33:33 »
hey, maybe we consider to start class65V3 with solenoid and buzzer supported in the future :).
Offline Totoro
« Reply #27 on: Tue, 05 September 2023, 04:37:07 »
you will check the real colors when some real videos/pictures posted.
Offline techycat
« Reply #28 on: Fri, 15 September 2023, 17:19:51 »
Would prefer I get to choose which back badge I receive or choice to buy the one I want.
Offline Nothatso
« Reply #29 on: Sun, 17 September 2023, 16:33:28 »
Love the design of this board, but the lack of plate options is pretty disappointing. For a retro-styled board I think it would make sense to have a metal plate available for the MX-compatible version.
« Last Edit: Sun, 17 September 2023, 16:49:07 by Nothatso »
Offline drfilco
« Reply #30 on: Mon, 18 September 2023, 09:01:16 »
Request: fix the stretched typography of the "Num Lock" text on the LED module
Add that to the bullet list and I'll buy another one of these lol
Offline Totoro
« Reply #31 on: Mon, 18 September 2023, 20:14:34 »
Our standard kit is blank badge and fixed it with magnetic suction. At the same time, we will provide an additional random badge the same color as the case.
Please wait for our GB info whether to open additional nameplates separately.
Offline Totoro
« Reply #32 on: Mon, 18 September 2023, 20:25:24 »
There is only POM plate for MX-compatible version, of couse if you need metal plate, we can provide the platefile for you to make cutting service by yourself.
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #33 on: Tue, 17 October 2023, 11:15:21 »
I've seen a few different content creators state that the in-stock sale occurred on October 10th. Is this correct? Or is the sale going to take place later this month?
Offline Thumb Key
« Reply #34 on: Wed, 18 October 2023, 01:11:00 »
great retro form factor! :thumb:
Offline Totoro
« Reply #35 on: Tue, 31 October 2023, 01:20:04 »
thank you  :)
Offline Totoro
« Reply #36 on: Tue, 31 October 2023, 01:23:35 »
Yes, We will run GB for FCFS in stock on 15th Nov, now busy Packing class60 for each vendors.
Offline WU
  • WUkds
« Reply #37 on: Thu, 02 November 2023, 01:10:48 »
The design on the back is really great and beautiful.
    • Podcast Links
« Reply #38 on: Thu, 02 November 2023, 12:49:57 »
Thank you!
Offline tko2007
« Reply #39 on: Tue, 14 November 2023, 08:44:08 »
How will Europeans be able to purchase?
Offline Rhodactis
« Reply #40 on: Sat, 02 December 2023, 10:49:58 »
Sorry, not interested... Because I'm still in love with my (Round 1) Class 80 ;)
Easily my favorite board. I've been daily-driving it since I got it. I prefer it to pricier boards I have.
I just wish I could buy some of those weights.
"A Typewriter is a means of transcribing thought, not expressing it."
"As expediter, the typewriter brought writing and speech and publication into close association."
-Marshall McLuhan
