Author Topic: Favorite space / galaxy themed keycaps?  (Read 4952 times)
Offline dunsparth
« on: Mon, 11 September 2023, 16:20:43 »
Doing a new build soon and wanting to go for a space / galaxy theme with the board that i bought.
i was going to get Traitors Infinity :( set but they are sold out on drop now, what would be some keycaps y'all can recommend me that are in stock.
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: Favorite space / galaxy themed keycaps?
« Reply #1 on: Mon, 11 September 2023, 18:55:08 »
what's your budget?
I know of gmk yuri which is based on the first person in space? which is on clearance on nk for 85 bucks, but that may be out of your budget range but that's a really good deal for gmk.
https://novelkeys.com/products/gmk-yuri-r2
I guess gmk lazer has a sorty spacey futuristic vibe - just make sure you get it on sale, they are kinda overpriced otherwise. I also wouldn't recommend buying from drop anyway unless there is a really good deal. Maybe also look on the aftermarket for this set as you could find it cheaper.
https://drop.com/buy/drop-mito-gmk-laser-custom-keycap-set
Heard alright things about polycaps but a lot of those people get paid off by kinetic labs so I actually haven't seen an opinion of these caps without affiliates or whatever. It is cheaper than gmk but I would still go for polycaps
https://kineticlabs.com/keycaps/polycaps/galaxy-pbt
I couldn't really find anything that fits that traitors infinity (which I wouldn't recommend getting anyway because it's reverse dye sub)
I know about KAT Space dust which kinda fits it, but that hasn't been made and shipped (it's been 2 years since I ordered and still hasn't come) I'll tell you when you can buy the set in stock with extras and if the set is worth it, since they are using new doubleshot + dye sub stuff.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline dunsparth
« Reply #2 on: Mon, 11 September 2023, 22:27:11 »
what's your budget?
I love those gmk yuri caps i am going to have to order a set of those even tho idk if they will fit my theme im going for they look great.
I found GMK Galaxy they are pretty pricey but if GMK caps are worth the money i will probably order these https://vala.supply/products/gmk-galaxy
Offline Rhienfo
« Reply #3 on: Mon, 11 September 2023, 22:32:07 »
GMK is pretty good, but quality control isn't the best, I would say 179 is too much for modern gmk imo, maybe 140 would be where you would start considering it, with extras pricing at least.
Yuri is a great deal which I might actually buy (assuming I have others that can split shipping with their orders, cause nk shipping to australia is rough) because it is a nice set.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline Gareth_SL
  • ins:gareth_sl
« Reply #4 on: Tue, 12 September 2023, 04:09:13 »
I was imagining galaxy themed spacebar keycaps....
Offline dunsparth
« Reply #5 on: Fri, 15 September 2023, 22:07:03 »
i ended up buying a set of gmk galaxy clones hopefully they are nice if not the search continues..
Offline Rhienfo
« Reply #6 on: Fri, 15 September 2023, 22:31:54 »
Usually a lot of the clone sets are not that good quality, even for the price you can get a lot better, but you aren't getting the colourway you want since most of the best options only do beige.
There is also an ethical issue surrounding clones which is why I will not support clone makers personally, and reccomend others not to but that is a person by person basis.
Maybe look on the aftermarket for gmk galaxy if you are looking for specifically that find a set from a reputable maker that is similar, those colours shouldn't be too hard to find. Or you can wait for another space set that catches your eye it is a common theme.
GL with your search.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
