Author Topic: Glorious Panda vs Boba UT4 - Worth the change?  (Read 4352 times)
Offline Praetor
« on: Wed, 13 September 2023, 03:43:33 »
I entered the customisation world when a couple of months ago I purchased a Keychron Q2. It came with Gateron Browns, but I changed the switches to pre-lubed Glorious Pandas and I 've been running this setup since.
Lately, I came across the Bobas and the thought of them got intrusive. So, I wanted to ask if anyone has any experience of both. Are Bobas that much better than the Glorious Pandas when it comes to tactility and thockiness? Should I get them unlubed or pre-lubed (they will cost me 2x the price, since I am not yet confident enough to do it myself)? Also, should I go with the UT4 or UT4x Bobas (I am concerned though by the fact that the latter come only in 65g weight)?
Mind you I prefer heavier switches (so, I have eyed the 68g Bobas) and I type for a living.
Of course, if you have to suggest some other switch that fits the criteria above (it is heavy or heavier than the Pandas, has a great tactile bump and is ideal for long typing sessions), I would love to hear what you suggest.
P.S.: Extra question. Do you have any advice on modding my Q2 to improve its thock sounds? As I mentioned above, I a total noob, so it should be something fairly simple and the material should be available in EU stores.
Offline Tribal
Re: Glorious Panda vs Boba UT4 - Worth the change?
« Reply #1 on: Wed, 13 September 2023, 06:28:02 »
I went from unlubed Glorious Panda to lubed U4 silent (I’ve read that the tactile feel is the same).  The U4 is better, but a straight upgrade from lubed GPs to lubed U4Ts doesn’t seem like it would be worth it.
Offline Praetor
« Reply #2 on: Wed, 13 September 2023, 08:15:14 »
Thank you for your answer.
So, you would recommend the Silent U4T rather than the "normal" ones? Why so?
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #3 on: Wed, 13 September 2023, 08:32:59 »
This thread confused me now cuz i havent been really up to date in the MX switch scene in like a year or so. I remember U4 being silent and U4T being the normal version. what is U4tx?
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline Praetor
« Reply #4 on: Wed, 13 September 2023, 17:56:12 »
U4Tx is the variant that has a silenced bottoming out
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #5 on: Wed, 13 September 2023, 18:24:25 »
You can just get tx springs or something (any consistent spring) and swap them for a heavier typing experience, plus those springs are usually better than whatever stock springs there are.
As someone who has tried both (to be fair my experience with u4ts is very limited) and I much rather preferred the pandas (to be fair I think that might be how the U4ts were lubed)
I guess the U4ts sound deeper, and the tactility is probably better from reviews and such. The thing about glorious pandas is that they have way worse leaf chatter than other mx tactiles (they still have it but it's not as bad as the glorious pandas) which is noticeable and a bit annoying, even if you can tune it out.
I think the difference between the two is just not worth paying the price for a second batch of switches, You're probably better off buying aftermarket spring and putting them in the glorious pandas if you need a switch to be heavier, if you ever get a second board, maybe it's best to get them and see which one you prefer.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline garynguyen
    • Tap hoa Phim
« Reply #6 on: Wed, 13 September 2023, 23:35:41 »
In my opinion, I prefer the lubed Panda - still using it with my Tofu65 v2. I know it has leaf ping noise but for me it's acceptable for a tactile experience. If you are looking for a cheaper option, I highly recommend Wuque Heavy Tactile or Gateron Tactile Quinn.
About the Keychron Q2 modding for thock sound, i'm using tape mod + PE foam (case) + Gateron Pro Milky Yellow + Keycap PBT Doubleshot. Hope it will help!
AMD 5600X - RX 6600XT
Ducky One 2, Leopold 900RBT
Keychron Q2, Enter67, Tofu65, Sunset80, Wind Z75
Offline Rhienfo
« Reply #7 on: Thu, 14 September 2023, 00:16:56 »
Oh yeah forgot about the second question my bad. It depends on what you mean by thock since people have so many different ideas. It could be a certain sound signature, a deep muted or sound or even just the sound of topre (which was the only time I ever heard the term when I first joined the hobby)
If you want a deep sound, foam/tape mod is the way to go, keep in mind it will make the sound less resonant and duller, so consider that.
You should probably just experiment with all combinations of stuff, pe foam, tape mod, polyfill all of the foams and see which one you like.
Here is also a science sheet about the sound it if you want to base of some stuff like keycaps or switches (keep in mind there are so many factors to a keyboards sound that you shouldn't take this as 100% true)
blacksimon.tv/science
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline mohawk1367
« Reply #8 on: Thu, 14 September 2023, 06:53:19 »
oh i thought thats what the U4 was
Offline Tribal
« Reply #9 on: Thu, 14 September 2023, 07:54:10 »
To me, clack/thock gets old really quickly.  I can use quiet/silent switches anywhere, but it’s hard to use louder ones at the office.
For the price of a set of U4/U4Ts, you’re getting close to lightly-used Topre territory.  You should be able to get a silenced R2 PFU for about $150.
Offline Praetor
« Reply #10 on: Sat, 16 September 2023, 01:59:54 »
Thank you all for your advice and the great tips.
