Author Topic: [IC] - Scout 42 Corne Case - Low profile, aluminum/PC, wireless-centric  (Read 7851 times)
Offline LogLab
Scout 42 Corne Case
Give me feedback for the low profile corne **case** I'm designing! Compared to my last GB, this is something more optimized to be sleek and travel friendly while keeping a very high end feel.  This time I especially had a focus on wireless use.
Timeline: GB Opening in 3-6 weeks, will last 1-2 months
IMAGES: https://imgur.com/a/bjrRtMA
FEATURES
- Sleek and low profile design
- Battery compartment for large 750mah battery
- Included tenting hardware
- Possible 1/4 - 20 thread for personal pocket tripod mounting systems
SPECS
- CASE ONLY
- O-Ring Sandwich Mount (Optional) See chieftain build guide for more details
- Tenting
   - 2.5 degree base tenting angle
   - Included M4 threaded tenting hardware + 2 threaded mounting points under each half
- Case Material: Polycarbonate and/or 6061 Anodized Aluminum
- Plate Material: Polycarbonate and/or 5052 Anodized Aluminum
- Case Height: 11.7mm to 17.8mm from thin to thick end
- Price: TBD, ≈ $195
- Compatibility: There are two versions, one which is specifically made for Typeractive's choc-spaced PCB, and another version which is made for general corne PCB's. ALL VERSIONS ARE WIRELESS ONLY (No TRRS cutout)
« Last Edit: Sun, 24 September 2023, 12:21:58 by LogLab »
Offline _rubik
A bit of a necro-thread, but any updates here? I'd be interested as a travel alternative to the Chieftain.
Offline LogLab
Sorry! I got super busy, but I am currently planning on launching this in about a month from today!
