Author Topic: [GB] Luminkey80, F13 TKL Keyboard with Tri-Mode & ANSO/ISO Layout  (Read 39869 times)
Offline made in China
« on: Tue, 26 September 2023, 03:10:49 »
Hello everyone! Thank you very much for your attention and support!
We are thrilled to present the Luminkey80, a keyboard that redefines simplicity and sophistication.
With a commitment to minimalist aesthetics, we have crafted a keyboard that merges clean geometric patterns and sleek lines,
creating a design that speaks volumes without saying too much.
-Luminkey80 Spec:
Typing Angle: 7°
Layout: 80% TKL ANSI/ISO (WK/WKL)
Mounting: Gasket Mount
Programming Support: QMK / VIA
Cable type: Type-C Data Cable
Switches: Luminkey Sylva Linear Switches
Stabilizer: Gateron Stabilizers
Connectivity: Wireless/2.4G/Wired
Compatible System: Windows/MacOS
PCB   : 1.6mm Hot-swap
Plate: 1.5mm PC Plate
Case: 6063 CNC Aluminum
Weight: Copper
Badge: Copper
Keycaps: PBT Double-shot Keycaps (WOB/9009)
Color: Ano-Black/ Ano-Silver/ E-Retro White
-Photos:
-Layout:
-PCB&PC Plate: (actual picture)
-Exploded view:
-Size:
-Switches:
Collaborating with GATERON, we proudly introduce the new LUMINKEY Sylva linear switches.
Inspired by the expansive and soothing natural landscapes, this switch provides a harmonious and comfortable typing experience.
Pre-order date: from Oct 1st- Oct 14th
In-stock release: Oct 15th
Price: Barebone Kit: 215 USD
          Pre-built Kit: 280 USD
Extra accessories:
-Stainless Steel PVD Badge: 8 USD
-Add-on keycaps: 5 USD (ISO & LED Indicators)
Packing List:
-Barebone Kit:
1*top case,
1*bottom case,
1*weight,
1*badge
1*pcb,
1*type-c daughter board,
1*PC plate,
1*foam kit,
1*switch puller&keycaps puller,
1*screwdriver,
1*USB cable,
1*Artisan keycap
a set of stabilizers,
1*carrying case
-Pre-built kit:
1*top case,
1*bottom case,
1*weight,
1*badge
1*pcb,
1*PC plate,
1*foam kit,
1*screwdriver,
1*USB cable,
1*Artisan keycap
a set of switches,
a set of keycaps
1*carrying case
Vendors List:
Australia: Allcaps
Australia: Dailyclack
Germany (EU): Keygem
Indonesia: Mechaland
Korea: Laein
Korea: Monstargears
Philippines: Zion Studios
Singapore: iLumkb
Singapore: Ktechs
Singapore: Pantheonkeys
Taiwan: Inpad
Thailand: Nuntachot
U.K.: Keyboardco.com
USA: Cannonkeys
USA: Mechanicalkeyboards
USA: Keebs for all
Vietnam: The Keebs
Website: https://www.luminkey.com/
Discord: https://discord.gg/AHJrVtEZw6
Instagram: @luminkey_official
« Last Edit: Mon, 09 October 2023, 03:34:57 by made in China »
Re: [GB] Luminkey80, F13 TKL Keyboard with Tri-Mode & ANSO/ISO Layout
« Reply #1 on: Tue, 26 September 2023, 08:58:01 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
« Reply #2 on: Wed, 27 September 2023, 01:18:19 »
« Last Edit: Wed, 27 September 2023, 01:22:46 by made in China »
Offline QWER|key
« Reply #3 on: Wed, 27 September 2023, 13:06:58 »
Does this just work normally with the batteries removed when connected via USB??  I've no interest in wireless, and I don't want batteries turning into spicy pillows through being constantly kept at 100%.
Offline EdgeOfInfinity
« Reply #4 on: Wed, 27 September 2023, 19:10:40 »
is the copper coated?
and maybe update the IC post
« Reply #5 on: Wed, 27 September 2023, 21:54:28 »
Sure, you can remove the batteries and connect via USB
« Reply #6 on: Wed, 27 September 2023, 21:57:18 »
No, it's pure copper
« Reply #7 on: Thu, 28 September 2023, 12:24:46 »
sorry i think i was unclear. i meant is the copper clear-coated or just raw (no finish)?
Offline rcradiator
« Reply #8 on: Mon, 02 October 2023, 20:01:28 »
Will the switches be available standalone, or only with the prebuilt configuration?
« Reply #9 on: Tue, 03 October 2023, 01:24:16 »
Different from clear-coated, we use anti-oxidation treatment, which can effectively prevent stains and fingerprints.
« Last Edit: Tue, 03 October 2023, 01:41:01 by made in China »
« Reply #10 on: Tue, 03 October 2023, 01:28:40 »
For now it is only available on the prebuilt kit
Offline jengahgg
« Reply #11 on: Thu, 05 October 2023, 13:50:34 »
has the GB gone live on the UK vendor? can't seem to find it at all.
« Reply #12 on: Mon, 09 October 2023, 03:36:33 »
Our EU vendor Keygem is running the preorder
Offline jengahgg
« Reply #13 on: Sun, 15 October 2023, 07:58:25 »
is Keyboardco.com only doing it in stock as they are listed as the UK vendor?
