Author Topic: [GB] KeyKobo Miami Nights | GB Closed  (Read 149933 times)
Offline nostyle_au
« on: Wed, 04 October 2023, 19:15:22 »
Discord | Website
Big cities never sleep, so why should your desk? Miami Nights is a classic set with quite the lore. Stunning on dark boards, while discrete on loud ones, this set is a must have for any collection.
Kitting:
A large base kit provides extensive physical support for most common layouts and some legend preference options too.
A NorDeUK kit for language compatibility in a variety of regions.
* Please note only Keygem, Prototypist and ZFrontier will be offering the NorDeUK kit.
Colours:
Colour matched to GMK’s CR/MG1/TU2 colours. See samples below.
Samples:
Vendors and Pricing:
USA: Mekibo
Base Kit - 95 USD
NorDeUK Kit - 30 USD
OCE: Daily Clack
Base Kit - 162 AUD inc GST
CA: Apex Keyboards
Base Kit - 140 CAD
EU: Keygem
Base Kit - 110 Euro inc VAT
NorDeUK Kit - 40 Euro inc VAT
(92.43/33.61 exc VAT)
UK: proto[Typist]
Base Kit - 94 GBP inc VAT
NorDeUK Kit - 34 GBP inc VAT
(78.33/28.33 exc VAT)
SEA: Hex Keyboards
Base Kit - 140 SGD
MENA: Sandkeys
Base Kit - 350 AED
CN: ZFrontier
Base Kit - 649 RMB
NorDeUK Kit - 249 RMB
ROW: ZFrontier
Base Kit - 95 USD
NorDeUK Kit - 35 USD
Dates:
The GB starts on the 6th of October and runs until the 6th of November in all regions.
Estimated delivery Q1 2024
Board Renders:
[img width=640 height=480]https://i.imgur.com/h8DwV6c.jpg/img]
Thanks to:
- Everyone who purchased Miami Dawn, I would not have had the confidence to run this without the success of that set
- The legendary Elvenmonster and the beautiful Baul for board render files
- OCM for the palm tree graphic
« Last Edit: Tue, 14 November 2023, 16:38:05 by nostyle_au »
Offline whirlwind
Re: [GB] KeyKobo Miami Nights
« Reply #1 on: Thu, 05 October 2023, 13:33:50 »
Rush rush rush
Offline nostyle_au
« Reply #2 on: Thu, 05 October 2023, 16:16:53 »
Post will be reserved for updates
« Last Edit: Fri, 06 October 2023, 16:59:32 by nostyle_au »
Offline caap
« Reply #3 on: Thu, 05 October 2023, 16:22:30 »
purse caps great, glwgb! :thumb:
Offline The0rigina1
  • fumoposting
« Reply #4 on: Thu, 05 October 2023, 16:34:31 »
rush rush
Offline mr_foggy
  • neue = nope
« Reply #5 on: Thu, 05 October 2023, 17:48:23 »
seeing how flawless miami dawn came out, 100% in on this
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #6 on: Thu, 05 October 2023, 21:24:55 »
Very cool mate, GLWGB
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline NinjaAdeeb
  • Formerly Zefterous
« Reply #7 on: Fri, 06 October 2023, 04:33:59 »
rush rush
Current collection:
OG Black Tofu65 | Red WK Frog Mini | Yellowed HHKB Pro 2 | Burgundy W1-AT | Beige BBOX60 | Black Jane V2 CE
Offline sabas
« Reply #8 on: Fri, 06 October 2023, 09:33:45 »
Looking good, definitely want to pick this up!
Offline nostyle_au
« Reply #9 on: Fri, 06 October 2023, 16:55:27 »
Updated OP with links to all listings under the vendors section. Only Apex currently missing as their listing is not live yet. Will update when they're live  :thumb:
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #10 on: Fri, 06 October 2023, 18:18:24 »
good
Offline mcmcmc
« Reply #11 on: Sat, 07 October 2023, 00:17:19 »
rush rush rush
Offline nostyle_au
« Reply #12 on: Sat, 07 October 2023, 09:38:04 »
A small mistake has been found in the base kit render files regarding alignment of the icon modifiers in Miami Nights. Thank you to a member of my discord server for pointing out the discrepancy here:
Unfortunately the molds that KKB offer for icon modifiers are of the centred variety for the Shift keys and Purse caps. This is in line with the specifications provided to Keykobo for the manufacturing of another set by a large vendor.  As such all of the keys will be center aligned vertically as this is the only option available.
I'm sorry if this is disappointing to you and I really hope it's not a dealbreaker. Thank you for your support with this set so far. I think this change is quite minor but I understand small things like this are important in the community so I wish to be as transparent as possible.
I've updated the OP with a fixed kitting render, this will be updated by all vendors to match soon. In the morning I will be taking the time to update board renders.
EDIT: OP has been updated with fixed board renders
« Last Edit: Sun, 08 October 2023, 06:44:46 by nostyle_au »
Offline nostyle_au
« Reply #13 on: Sun, 08 October 2023, 05:21:25 »
OP updated with Apex Keyboard's listing and pricing.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #14 on: Tue, 10 October 2023, 15:12:42 »
Edit: revised end date
« Last Edit: Mon, 06 November 2023, 23:51:53 by dvorcol »
Offline nostyle_au
« Reply #15 on: Tue, 10 October 2023, 17:29:19 »
Thanks dvorcol! Still a ways to go but confident we can make it  ;)
Offline involuntarysoul
« Reply #16 on: Tue, 10 October 2023, 19:19:49 »
why is this $10 more expansive compared to KKB Miami Dawn?
Offline nostyle_au
« Reply #17 on: Tue, 10 October 2023, 19:24:25 »
Larger kit, greater manufacturing cost, greater raw material cost, increase in international freight costs. Margins have remained the same so it's not in an attempt to profit more off it.
« Last Edit: Tue, 10 October 2023, 21:11:54 by nostyle_au »
Offline dvorcol
« Reply #18 on: Wed, 18 October 2023, 10:29:03 »
« Last Edit: Mon, 06 November 2023, 23:53:18 by dvorcol »
Offline nostyle_au
« Reply #19 on: Wed, 18 October 2023, 18:10:49 »
Making progress :llama:
Offline dvorcol
« Reply #20 on: Tue, 24 October 2023, 09:41:01 »
« Last Edit: Mon, 06 November 2023, 23:53:53 by dvorcol »
Offline nostyle_au
« Reply #21 on: Wed, 25 October 2023, 00:28:41 »
Less than two weeks left! Please consider buying now if you're planning to join  :-*
« Reply #22 on: Wed, 25 October 2023, 12:06:27 »
consider getting better renders next time, why all the renders only show half of the board?
Offline nostyle_au
« Reply #23 on: Wed, 25 October 2023, 20:52:01 »
You have a unique way of giving feedback, just for you my friend  :thumb:
Offline nostyle_au
« Reply #24 on: Thu, 26 October 2023, 03:09:50 »
Regarding the previous change to modifiers for KKB Miami Nights, this has been reverted. After discussions with KeyKobo we have confirmed that new molds will be made to support non "Dixie" style modifiers. This also means that with the success of this GB modifiers of this type will be available from KeyKobo.
This means that the original renders from the beginning of the GB are now accurate. I'm once again updating all material to reflect this. It is likely we will extend the GB by an extra week to allow for more orders to be placed in light of this change.
Tldr; the shift and lock modifiers will not be centred (Dixie style), they will be in line with traditional Cherry icon modifier placement.
I have updated the renders in the OP with the correct images
Offline airs
« Reply #25 on: Fri, 27 October 2023, 09:15:05 »
That’s great news, can’t wait for this set! Thank you for making this happen :)
Octagon v2, LZ CLS
« Reply #26 on: Mon, 30 October 2023, 12:55:58 »
Any chance to get a blue esc and blue palmtree added?
Offline nostyle_au
« Reply #27 on: Wed, 01 November 2023, 18:25:43 »
Unfortunately this late in the GB it's too late to make kitting changes as it would affect quotes and therefore pricing sorry
Offline nostyle_au
« Reply #28 on: Sun, 05 November 2023, 16:53:09 »
One week left! Just a reminder we have non centred modifiers for this set so jump on if that was holding you back!
Sorry for the lack of numbers update last week, had trouble getting updates from all vendors but we're looking at mid 70s as of last Monday. I'll chase up vendors for numbers as of today soon  :thumb:
But yeah, please get onto the GB now!
Offline dvorcol
« Reply #29 on: Mon, 06 November 2023, 23:10:30 »
« Last Edit: Mon, 06 November 2023, 23:56:37 by dvorcol »
Offline nostyle_au
« Reply #30 on: Fri, 10 November 2023, 17:04:39 »
Last few days!!
Offline Exquite
  • GeekAnubis
« Reply #31 on: Sat, 11 November 2023, 21:20:25 »
Looks great!
I'm a Color lover and a designer.
Offline treeleaf64
    • treeleaf64
« Reply #32 on: Sat, 11 November 2023, 23:35:29 »
Am I allowed to purchase this keyset if I have not ventured outside in 1 days
Everyone must pay the cat tax
Offline nostyle_au
« Reply #33 on: Sun, 12 November 2023, 03:20:03 »
In that case you are required to purchase it
Offline clay
  • No foams
« Reply #34 on: Sun, 12 November 2023, 12:23:13 »
Love the colors. Perfect for using once I get GTA VI
Offline nostyle_au
« Reply #35 on: Sun, 12 November 2023, 17:52:34 »
Final Day!
Offline nostyle_au
Re: [GB] KeyKobo Miami Nights | LAST DAY!
« Reply #36 on: Tue, 14 November 2023, 16:37:51 »
GB is closed! We're finalising numbers now and will have more info soon. Thanks to everyone who supported the set
Offline aicyborg
Re: [GB] KeyKobo Miami Nights | GB Closed
« Reply #37 on: Thu, 23 November 2023, 21:30:04 »
Did this make it?
Offline nostyle_au
« Reply #38 on: Sun, 26 November 2023, 02:43:06 »
Yep! We’re gonna make it on the base kit. Regrettably the NorDeUK kit had to be cancelled but all affected customers have been contacted. Just finalising numbers now before and official count gets posted. Lots going on in the background hence the lack of updates sorry
Offline dvorcol
« Reply #39 on: Thu, 30 November 2023, 13:49:46 »
<-- without extras
Offline nostyle_au
« Reply #40 on: Sun, 17 December 2023, 07:52:18 »
All vendors have been invoiced and we’ll be entering production soon! In the meantime Amano Studios has an artisan collab live right now; https://www.instagram.com/p/C077T72R4SP/?igshid=MzRlODBiNWFlZA==
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #41 on: Sun, 17 December 2023, 15:04:34 »
Offline nostyle_au
« Reply #42 on: Thu, 02 May 2024, 01:58:10 »
Just an update, production has completed and we're in the process of organising shipment to vendor's proxies now. China is off for a few days but this should be sorted shortly after they get back  :thumb:
Offline nostyle_au
« Reply #43 on: Thu, 23 May 2024, 19:08:01 »
Delivery in China has been completed, if you'd like to see some photos there are some awesome ones in this zF thread: https://www.zfrontier.com/app/flow/8vW9z9wbgjVm
Offline Udyrstruidor
  • uga uga
« Reply #44 on: Thu, 30 May 2024, 17:52:05 »
It came out looking great! I will try to get extras. Congratulations for the project :thumb:
Poseidon60 | GrayStudio Space65 R1 | Ikki68 Aurora | CannonKeys Bakeneko60 | Gok 7V | NotFromSam Samice | CableCarDesigns Prophet | Geonworks Frog TKL | FancyAlice | Aeboards Praxis R2 | HHKB Pro BT | Geonworks F2-84 | UTD 360C | Elongate | Realforce 87u | GrayStudio Space65 R3 | TGR Jane v2 ME | TGR x Singa Unikorn R2.2 | Singa Kohaku65 R1 | Cherry G80-1824HBU | Matrix 8xv 3.0 | CableCarDesigns Prophet | Daji Seis Cero | Matrix 8xv 2.0add Xmas | TGR Jane v2 CE | Baionlenja Bias R2 | Merisi Ottantaquattro | TGR Jane v2
