Author Topic: My not-so-pretty selfmade Game/Application Controller  (Read 9206 times)
Offline Sig
« on: Fri, 15 October 2010, 18:09:31 »
after my belkin n52 became useful as a brick under windows 7
+ there seem to be no real replacement or successor
it was time to build my own
the result isn't very pretty so far:
but it works great!
encoder:
usb 2.0, 500hz, plug'n'play, full-rollover (34 keys), every key re-assignable (software)
switches used:
18 cherry mx "super blues" (no click but tactile, activate 1.33mm earlier, original blue activation bump, stiffer black spring)
1 regular cherry mx blue (the leftmost one)
1 belkin n52 digipad + pushbutton
1 cherry d4 (below the digipad)
- all switches can be reached without moving your hand
well tell me what you think
i guess i'll make a prettier one with more buttons in the future
but so far im rather pleased
« Last Edit: Fri, 15 October 2010, 18:15:18 by Sig »
Offline kriminal
« Reply #1 on: Fri, 15 October 2010, 19:50:06 »
nice but um... how come your nostromo didnt work under win 7?
what controller did u use?
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline Sig
« Reply #2 on: Fri, 15 October 2010, 21:11:53 »
Quote from: kriminal;234464
there are no working drivers for win7 x64 from belkin
i'm using a bu0836x with autohotkey
Offline kriminal
« Reply #3 on: Fri, 15 October 2010, 21:47:13 »
weird... then how does mines work on win7 64bit?
Offline Lanx
« Reply #4 on: Sat, 16 October 2010, 01:59:00 »
i have no issue using either of my nostromos under winxp/win7 32 or win7 64. Thats great tho, i was kind of thinking the way to put the numpad pcb on there but decided against it because well it just didn't look right.
Offline Sig
« Reply #5 on: Sat, 16 October 2010, 03:38:46 »
do you guys mean the n52te?
i already needed a 3rd party program just to make windows use the n52 driver
not to mention the belkin software didn't detect it either way
but glad i have something with more buttons now anyway :smile:
Offline WhiteRice
« Reply #6 on: Sat, 16 October 2010, 08:06:43 »
but it works great!
And that's what really matters! Nice job!
Offline kriminal
« Reply #7 on: Sat, 16 October 2010, 08:41:55 »
nope i dont have the lighted up n52te version, i have the original one, infact i have 2 nostromos.
but i am interested in your design, though my current ongoing mod follows the one ripster did.
« Last Edit: Sat, 16 October 2010, 08:44:34 by kriminal »
Offline Lanx
« Reply #8 on: Sat, 16 October 2010, 10:07:43 »
nope, never got the TE cuz i knew that the razer software sucked, tested it w/ nostromo n50/n52 on all os's no issues. (modded or not)
Offline Sig
« Reply #9 on: Sun, 17 October 2010, 10:47:49 »
hm, which driver version did you use for 7 x64?
i think i had the "newest" beta from the belkin site
Quote from: ripster;234654
Those must be super clicky.
Blue Stems + Black Spring ~ Green Cherry MX
I'd be interested in more details on how you built it.
nope no click
what i did is basically fixing the movable part of the blue switch to fixed position
i used small pieces of 1.33mm isolated copper wire that i pushed in between on both sides
also superglued everything (not needed)
make sure nothing sticks out on the sides if you try it
otherwise the feeling will suck
Quote from: kriminal;234657
apart from my superior keypad its still pretty much the same as the original n52
the keypad is even tilted in about the same angle
layout is like this
next version i wanna have about 30 buttons without hand palm movement :tongue1:
Offline Lanx
« Reply #10 on: Sun, 17 October 2010, 14:34:06 »
i just tried out this one on my win xp laptop recently, probably the same on my current 64 win7 as well
http://en-us-support.belkin.com/app/answers/detail/a_id/478
Offline ricercar
  • mostly abides
« Reply #11 on: Sun, 17 October 2010, 14:44:29 »
Nostromo n50 on Vista and 7 LINKY
Offline Sig
« Reply #12 on: Tue, 19 October 2010, 21:04:03 »
Quote from: Lanx;235213
yeah that one seems to work (at least the software detection does)
wasn't there yet when i was downloading the drivers a few months ago
