Author Topic: Reflection XT FRL | Shipping now!  (Read 147328 times)
Offline Farhandsome
    • Han Boards
« on: Wed, 18 October 2023, 16:47:45 »
Reflection
An XT FRLTKL by Han Boards
GB Window: 10/20 - 11/20 (live on 10/20 at 11AM CST / 5PM BST)
Design Summary
External
Reflection features a three-piece / three-tone design with a silver base, copper weight, and top color variants. It is an XT FRLTKL (basically a TKL with the F-row removed and a macro column on the side). The board features a large swept cut copper weight that follows the curve of the top piece side profile. The front of the board has a cherry lip of sorts - with the lip being the deepest in the middle and gently flowing into the chamfer on the side edges. There is a gentle cut on the sides and back of the board to give the perimeter some flair. Two engravings are present - one left justified on the back of the board and one on the underside of the board (see Inspiration). The mirrored engraving on the aluminum bottom is half the depth of the one of the copper weight to give the appearance of a “reflection”.
Internal
The board features an internal screw system to keep the weight design as clean as possible. The final screws will be black oxidized and recessed slightly below the plate to be as hidden as possible. The aluminum inner frame has an open bottom so the copper is effectively a through weight giving a nice contrast on both the bottom as well as the inside of the keyboard. The daughterboard is installed upside-down with the cable being colinear with the PCB molex connector eliminating the need to bend the jst cable in a channel. There are small press-fit bumpers placed next to the screw holes to eliminate any chance of case ping. There are no adhesives anywhere on the board so it can be unassembled fully.
Technical Specifications
General Details
Material (case): Sandblasted 6063 Aluminum
Material (weight): Sandblasted Clear-Coat Copper
Variants: WK and WKL
Weight: 7 lbs (3.2 kg)
Typing Angle: 7 deg
EKH: 23mm
Plate Options: Aluminum, Carbon Fiber, PP, POM - full/half options (determined by IC)
Colors: Green, Black, Brown, Silver, Sand
Layout
Solder
Hotswap
Support
  • Split Backspace
  • ISO (solder only)
  • Split Right Shift
  • Stepped Caps Lock
  • 10U Spacebar (7U and 8U stab placement)
  • 7U bottom row / 6.25U bottom row (WK only)
PCB Details
Type: Solder & Hotswap
Structure: 1.6mm FR4
Processor: STM32F072
Software: QMK/VIAL
Switch Type: MX
ESD Protection: Onboard Fuse
Daughterboard: Custom DB - based on UDB C3
Cable Type: Molex EZMate
Mounting Options
Gasket Plug Mount
The gasket plugs are secured into the plate tabs and the overall assembly is dropped into the bottom case. The top case is then placed over it. This should make for a more flexible typing experience.
Burger O-Ring Top Mount
The plate is fixed to the top chassis using a screw and two small o-ring gasket pieces. This provides a stiffer typing experience overall.
Group Buy Details
Kit Contents
  • Keyboard case (top, bottom and weight)
  • Aluminum full plate (other plates will be extras)
  • PCB
  • Custom daughterboard and Molex cable
  • Gasket kit
  • Top mount kit
  • ESD protective sheet
  • Assembly hardware
  • Geon rectangular feet
  • Carrying case
  • Microfiber cloth
Extras
  • Plates (full / half) - Alu, CF, PP
  • PCBs (solder, hotswap)
  • Foam Kit (case, plate, PCB)
Schedule
The group buy will take place on October 20th and will end on November 20th.
Expected fulfillment is end of Q1 2024.
Price & Quantity
Pricing will be between $440 - $475 depending on configuration. See below image for details
Vendors
  • Han Boards - USA
  • ProtoTypist - International
Content Line-up
  • Nainaigogo
  • nearLucid
  • TheKeyCircle
  • CaptainSterling
  • Keypothecary
  • Alexotos
  • Xinxinwong
  • Eleagnifolia
  • Kimlynnwin
  • LightningKeyboards
Color Renders
Green (anodized)
Black (anodized)
Brown (anodized)
Silver (anodized)
Sand (e-coat)
Gallery
Final Prototype - Brown
v2 Prototype - Sand
v1 Prototype - Green
Thank You
  • Jan, Nainaigogo, and MatthewDias for causing me great distress at all times
  • My friend MelghiDoodles for providing the art for the board
  • OCM for transforming the artwork to the keyboard world
  • Olivia (OJ Designs) for the fantastic render work
  • Jan (again) and CaptainSterling for the insane pictures
« Last Edit: Tue, 16 April 2024, 17:38:00 by Farhandsome »
Re: Reflection XT FRL | GB Live 10/20 - 11/20
« Reply #1 on: Wed, 18 October 2023, 16:53:51 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline warhopper
« Reply #2 on: Wed, 18 October 2023, 17:09:25 »
Hell yeah, I'm so excited to see this in GB. Really knocked it out of the park in terms of design on this.
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #3 on: Fri, 20 October 2023, 03:29:40 »
Pretty keybort  :thumb:
GLWGB!
Offline phinix
« Reply #4 on: Fri, 20 October 2023, 04:13:25 »
Pretty but too expensive.
Nowadays we noticed many builds being for around $200-300, in recent years prices of high quality custom keyboard went down, proving that it is possible to have quality build for much less money.
$440 is just too much for this design - look at the QK80, Cycle7, phenomenal quality and design.
9100 | 3070 | 8TB SSD + 2x 1TB SSD | Z390 Aorus Pro ITX | 16GB RAM | SFX 600W | Sentry 2.0 | Ruark Audio MR1 Mark II | LG OLED 48CX
Realforce 87u55 | CM QuickFire Rapid MX Blacks | NCR-80 87g Gateron Oil Kings | Drop CSTM80 | Logitech Pro Superlight
SA: Retro Petscii, 7bit Round6 'Symbiosis', Filco, Carbon Bone Cherry: GMK Laser, OG double shot caps, CRP APL GSA: Retro High-light HSA: Hyperfuse
Offline iwobobul
« Reply #5 on: Fri, 20 October 2023, 08:14:17 »
Go get a QK80 then, I dare you.
What a stupid comment, really. You should then go and leave the same comment under every GB that is not a QK or TKD, because small batch manufacturers will never match the prices of manufacturing at scale. Should they all stop making things then? No more unique layouts, all hail QK80.
Also have a look at the size and weight comparison. Look at the honking weight on this board, it's a huge piece of copper, compared to processed sheet brass that QK or Cycle use. This one is 3.2kg while QK is what, 1.75?
The abscence of tacky golden badge should also count as something.
« Reply #6 on: Fri, 20 October 2023, 08:23:52 »
This^
Small batch production can't compete on price.
Offline Farhandsome
    • Han Boards
« Reply #7 on: Fri, 20 October 2023, 08:30:58 »
I understand where you're coming from, but as others have mentioned, it's hard to keep prices at down at a low MOQ (50 for this GB). I'd love to keep things more affordable but as with all more customized products, the market is undoubtedly smaller. I'm hoping this targets the folks who are interested in trying a unique layout and design :thumb:
I will hope to make a more affordable design in the future depending on the success of this GB!
Offline HubertThemad
  • * St. Jude Supporter
« Reply #8 on: Fri, 20 October 2023, 09:23:10 »
GLWGB!!!!
Extremely tempted by this, such a banger board in aesthetics, specs, you name it.
« Reply #9 on: Fri, 20 October 2023, 10:12:54 »
Did the brown prototype arrive? If so, I am not seeing the brown prototype amongst the gallery.
Offline Farhandsome
    • Han Boards
« Reply #10 on: Fri, 20 October 2023, 10:39:35 »
The brown prototype is in! We didn't get to take dedicated shots of it yet, but you can see it in the first image in the GB post as well as a couple more in the Discord and Notion pages.
Alexotos will be building the brown one this Sunday.
« Last Edit: Fri, 20 October 2023, 10:42:44 by Farhandsome »
« Reply #11 on: Fri, 20 October 2023, 10:45:36 »
Ah thanks. So the first photo is of the prototypes, nice :)
Offline Farhandsome
    • Han Boards
« Reply #12 on: Fri, 20 October 2023, 11:01:18 »
The GB is now live!
USA Group Buy Page
International Group Buy Page
I hope you will consider Reflection for your next purchase  :D
« Last Edit: Fri, 20 October 2023, 11:18:18 by Farhandsome »
Offline iwobobul
« Reply #13 on: Mon, 23 October 2023, 13:25:06 »
Brown was built by alexotos on stream. He unfortunately went with very safe keycap set for it. Still looked nice
Offline Farhandsome
    • Han Boards
« Reply #14 on: Tue, 24 October 2023, 09:15:59 »
The Alexotos vod is up!
It's a good look at the brown variant since we don't have too many photos of it.
Offline sketch3v
  • Sketch
    • Astro
« Reply #15 on: Tue, 24 October 2023, 09:29:43 »
Not a big fan of this layout, but the seamless design looks absolutely fantastic.  :thumb:
Offline Farhandsome
    • Han Boards
« Reply #16 on: Mon, 30 October 2023, 13:48:00 »
Eleagnifolia's vod is up!
Amazing job to her for running a marathon stream and capturing sound tests for every config! (sans foam)
Reflection Sound Tests - all built w/ Zaku switches & GMK keycaps
Alu Plate, Top Mount
Alu Plate, Gasket Mount
CF Plate, Top Mount
CF Plate, Gasket Mount
PP Plate, Top Mount
PP Plate, Gasket Mount
Offline Farhandsome
    • Han Boards
Offline Farhandsome
    • Han Boards
« Reply #18 on: Mon, 06 November 2023, 08:55:25 »
Kimlynnwin's vod is up!
Halfway through the GB and numbers look great! Thank you for all the support so far :thumb:
Will be getting some pics of the brown colorway up today or tomorrow.
Offline Farhandsome
    • Han Boards
« Reply #19 on: Tue, 07 November 2023, 12:45:52 »
Added some photos of the brown colorway to the main post.
Offline LogLab
« Reply #20 on: Tue, 07 November 2023, 15:07:41 »
This looks sick. Idk if I just missed it, but what does the engraving say?
Offline Farhandsome
    • Han Boards
« Reply #21 on: Wed, 08 November 2023, 09:14:01 »
Ah yes, I added the "inspiration" section in the IC but not the GB - it says "reflection" in Bangla  :)
Offline Farhandsome
    • Han Boards
« Reply #22 on: Thu, 09 November 2023, 09:45:10 »
CaptainSterling's review video is up!
Another great look at the brown unit.
Offline Farhandsome
    • Han Boards
Offline Farhandsome
    • Han Boards
« Reply #24 on: Mon, 13 November 2023, 09:05:44 »
Xinxinwong's VOD is up!
There is one week left in the group buy! Be sure to get yours before the 20th  :thumb:
Offline Farhandsome
    • Han Boards
« Reply #25 on: Mon, 20 November 2023, 10:46:39 »
And lastly, a summary video by XXW!
The GB will be closing tonight at 9pm! Be sure to get your orders in before then  :thumb:
Offline Farhandsome
    • Han Boards
Re: Reflection XT FRL | GB closed!
« Reply #26 on: Tue, 21 November 2023, 17:18:42 »
The GB is closed as of yesterday evening! We blew past MOQ which is amazing and I wanted to thank all the participants for making this project come to a reality. I will be providing regular updates in here on fulfillment timeline and updates on production!  :thumb:
Offline Farhandsome
    • Han Boards
« Reply #27 on: Mon, 04 December 2023, 10:58:17 »
Update - 12/4/2023
Hello! I updated in the Discord, but forgot to post here -
  • The initial invoice has been paid - we are now in the production queue.
  • PCB manu has been contacted as well and that invoice will be paid this week.
  • All other accessories will be ordered shortly.
  • The MOLEX connectors have all been changed to JST connectors.
Feel free to join the Discord for the most up to date real time updates!
« Last Edit: Sat, 30 December 2023, 10:07:31 by Farhandsome »
Offline Farhandsome
    • Han Boards
« Reply #28 on: Sat, 30 December 2023, 10:09:44 »
Update - 12/30/2023
Feel free to join the Discord for a real-time updated timeline, but here's the end of the year update!
  • All invoices paid.
  • Manufacturing is underway - estimated to be completed at the end of February.
Have a great New Year  :thumb:
« Last Edit: Mon, 05 February 2024, 10:06:53 by Farhandsome »
Offline Farhandsome
    • Han Boards
« Reply #29 on: Mon, 05 February 2024, 10:10:41 »
Update - 1/31/2024
Feel free to join the Discord for a real-time updated timeline, but here's the January month-end update!
  • All manufacturing besides the cases have been completed.
  • Cases have all been machined. Two of the colorways have been anodized, awaiting the other three to be finished.
  • The estimated time of completion is still the end of February due to the Lunar New Year Holiday.
  • Boards are still targeting for an end of Q1 timeline for fulfillment!
The GH updates are a little delayed as I forget to cross post haha. Discord always has the real time announcements!  :thumb:
« Last Edit: Tue, 19 March 2024, 15:24:36 by Farhandsome »
Offline Farhandsome
    • Han Boards
« Reply #30 on: Tue, 19 March 2024, 15:25:56 »
Update - 3/18/2024
Feel free to join the Discord for a real-time updated timeline, but here's an update!
  • All manufacturing has been completed.
  • Cases are currently being packaged to be sent to ProtoTypist and myself.
  • Boards are targeted to be fulfilled in April/May timeframe!
« Last Edit: Tue, 16 April 2024, 17:38:10 by Farhandsome »
Offline Farhandsome
    • Han Boards
Re: Reflection XT FRL | Shipping now!
« Reply #31 on: Tue, 16 April 2024, 17:39:00 »
Update - 4/16/2024
  • All US orders have been shipped.
  • Please follow the ProtoTypist discord for updates on international orders.
« Reply #32 on: Tue, 16 April 2024, 20:41:13 »
Really cool design! Is GB still open now?
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #33 on: Wed, 17 April 2024, 04:12:11 »
No. GB was live 10/20 - 11/20.
But I suppose you might be able to secure extras.
