Author Topic: New Filco - How to remove keycap without tool?  (Read 13837 times)
Offline Kenshin
« on: Sat, 16 October 2010, 14:00:23 »
Just got my FILCO Tactile Touch, and I wanted to put in the red esc key. How do I remove a key without damaging the keyboard? I have some various household tools but not the key-removing tool offered on the elitekeyboards website.
Thanks ^_^
Offline WhiteRice
« Reply #1 on: Sat, 16 October 2010, 14:00:59 »
Just use some paper clips.
Offline MissileMike
« Reply #2 on: Sat, 16 October 2010, 14:09:05 »
These are super easy to remove.  Don't worry, you're not going to break anything.  Just loop some dental floss under the corner of the key and pull up.  It will pop right off.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline Kenshin
« Reply #3 on: Sat, 16 October 2010, 14:11:01 »
ok thanks :)
Offline Fwiffo
« Reply #4 on: Sat, 16 October 2010, 14:15:30 »
The trick is to find a way to pull it straight up and not twist or pry at it. Hooking a bent paperclip under two corners works well.
You can call me... Keyboard Otaku... or not quite...
Offline WhiteRice
« Reply #5 on: Sat, 16 October 2010, 14:24:51 »
Quote from: MissileMike;234797
Compared the Alps cherries are a breeze.
Offline calavera
« Reply #6 on: Sat, 16 October 2010, 21:03:57 »
Quote from: ripster;234855
Wiggle.
lol :laugh:
Offline kriminal
« Reply #7 on: Sat, 16 October 2010, 21:08:17 »
Quote from: WhiteRice;234805
indeed alps caps takes so much force to pull, i get worried i might destroy the switch..
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline kriminal
« Reply #8 on: Sat, 16 October 2010, 21:16:37 »
okay now im scared.... lol
heck even one of the pins stayed smh..
Offline Rajagra
« Reply #9 on: Sat, 16 October 2010, 21:20:05 »
Quote from: kriminal;234994
There's only one safe way to remove Alps key caps:
  • Stand about five feet away from the desk.
  • Hold the keyboard at one end.
  • Raise it above and behind your head.
  • With all your might, swing the keyboard forward so the far end of it hits the edge of the desk.
  • The keyboard will stop, and momentum will cause the key caps to keep moving and fly off all at once.
  • Your switches and key caps will be intact. The rest of the keyboard on the other hand may suffer from the experience.
Quote from: ripster;235002
These were Simplifieds (Fukkas).
Looks like they are all "Simplified" by the time you are finished with them! :rofl:
« Last Edit: Sat, 16 October 2010, 21:24:45 by Rajagra »
Offline Kenshin
« Reply #10 on: Sun, 17 October 2010, 04:21:28 »
My next mission is to find a program that will allow me to make simple macros for things like increasing/decreasing volume,  pause/play music etc.
Any program fit that description that doesn't need to be ran on boot? Or is that impossible?
Offline WhiteRice
« Reply #11 on: Sun, 17 October 2010, 07:52:46 »
Quote from: ripster;235104
AutoHotkey.  Check the "Turn Any Keyboard Into A HHKB" mod for a Media Script - make sure you put into XP compatibility mode.
Stupid Win7 is forcing me to elevate privileges every time I run AHK - anybody here know a workaround (other than completely turning off UAC).
Does AHK start as a service or a shortcut in your startup folder? If it is the latter you can adjust the properties of the shortcut to "run as admin".
