Author Topic: Typematrix KRO?  (Read 2935 times)
Offline Parak
Typematrix KRO?
« on: Sun, 17 October 2010, 03:14:24 »
Anyone that has one able to advise? :)
Offline hoggy
  • * Ergonomics Moderator
Typematrix KRO?
« Reply #1 on: Sun, 17 October 2010, 05:39:15 »
I dragged out my old 2020 with the intention of carrying a sensible test...  but I couldn't resist pretending to use the 'logitech test' instead of aquakeytest
 QICK BRW X JMP 1900312120d3d0001r  lz dg
Really don't know why all those numbers turn up, but there seems to be a few other artifacts when you hold a few keys down.
CBA to do a better test.
Don't know about the later keyboards, though.
Offline Rajagra
Typematrix KRO?
« Reply #2 on: Sun, 17 October 2010, 08:38:47 »
EZR-2030 is 2KRO.
E.g. holding down WAS registers only the first 2 keys.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Typematrix KRO?
« Reply #3 on: Sun, 17 October 2010, 11:21:57 »
Quote from: hoggy;235087
Someone's first attempt at programming a keyboard controller, apparently. This, mes amis, is ghosting.
Offline Parak
Typematrix KRO?
« Reply #4 on: Sun, 17 October 2010, 13:00:11 »
Ew..
Quote from: Rajagra;235120
EZR-2030 is 2KRO.
Thanks! Now if only an owner of a 2030 USB would chime in on rollover and ghosting.. I doubt they'd improve on the former, but hopefully they fixed the latter.
Speaking of matrix boards, I noticed that you have a tipro - is that also a 2KRO, with plate mounted switches? I'd go for a "faux" typematrix on one of those, but typing on blacks might push me into drinking.
Offline Parak
Typematrix KRO?
« Reply #5 on: Sun, 17 October 2010, 13:26:41 »
Quote from: ripster;235188
Why would a typist ever need more than 2KRO?
Yeah, yeah :p I'm actually interested in trying a matrix board for gaming as well, but I know that even there 2KRO is not that bad. This is mostly a curiosity type of thing, and it did help in showing some ghosting problems alongside.
Offline Rajagra
Typematrix KRO?
« Reply #6 on: Sun, 17 October 2010, 13:50:21 »
Quote from: Parak;235186
Yes, plate mounted Cherry blacks with 2KRO. But they are designed to take large keycaps that press multiple switches - 1x2, 2x1 and 2x2. So switches that are next to each other seem optimised to play nicely together.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
Typematrix KRO?
« Reply #7 on: Sun, 17 October 2010, 14:00:49 »
Touch-typists can benefit by more than two-key rollover because they may type fast enough so as to have three (or more!) keystrokes in the pipeline at once, at least momentarily, and it's helpful if they're not slowed down by having to lift their fingers off one key before starting to type the next letter in order to avoid errors.
Offline keyb_gr
  • Cherrified user
Typematrix KRO?
« Reply #8 on: Sun, 17 October 2010, 14:34:59 »
Quote from: quadibloc;235200
You don't really need more than 2KRO for this though - such a situation would typically involve both hands, so the board designer merely has to make sure that the left-hand side and right-hand side of the alphanumeric section don't get too much in the way of each other for a typical touch typist.
