Author Topic: GoblinTechKeys for Custom Keycap Set?  (Read 25699 times)
Offline CMYKatt
« on: Sun, 03 December 2023, 02:39:25 »
Hey y'all! I'm new here, so if this isn't the right place to make this post, please lmk!
I was looking into getting a keycap set I designed manufactured for myself, and was comparing companies when I came across GoblinTechKeys. Has anyone used them to print their custom keycap designs before? If so, would you recommend them?
Thanks!!
Offline Orangeeky
Re: GoblinTechKeys for Custom Keycap Set?
« Reply #1 on: Mon, 05 February 2024, 19:47:32 »
I've been looking for this myself. Currently leaning towards Goblintech after watching an unboxing on YouTube.
WASD has a great editor but I hear their keys are really thin. KeyGeak.com, FKcaps.com, and maxkeyboard.com are other options but I don't have any experience with those.
Good luck with your caps!
Offline mingerpager
« Reply #2 on: Mon, 05 February 2024, 20:13:32 »
I appreciate the information you provided, I will definitely try it
Offline anniesteuber
    • Hello Neighbor
« Reply #3 on: Wed, 13 March 2024, 01:55:11 »
I am grateful not to spend time sorting through stuff that isn’t required.
Offline daymansalvort
    • Certificate attestation in Dubai
« Reply #4 on: Mon, 08 July 2024, 08:52:23 »
Thank you so much for sharing this valuable post.
Offline Finnianflyn
« Reply #5 on: Sun, 13 October 2024, 23:50:23 »
 If you're considering them for your keycap set, it might be helpful to check reviews or forums specific to mechanical keyboards to see more user experiences
Offline POMPOKEY
  • Better mkb on your desk and beyond.
    • pompokey.com
« Reply #6 on: Fri, 13 December 2024, 03:43:31 »
Hi I also know their survice as they promote themselves in Instagram etc but have not use it before. If you want to do custom keycap, there are many factories in Taobao store that provides same service with slightly more cheaper price!
