Author Topic: my own top 4 list of relatively budget-friendly 60-65% keyboards  (Read 6462 times)
Offline matiiska
« on: Tue, 05 December 2023, 08:06:14 »
thank you for checking this thread out. after a few hours of searching, i have put together a list of good 60-65% keyboards that are in stock atleast atm. hope someone finds this useful
1- Neo65 https://www.qwertykeys.com/products/neo65-1?variant=43882015129843
2- Tokyo60 https://drop.com/buy/massdrop-x-tokyo-keyboard-tokyo60-keyboard-kit?defaultSelectionIds=975916
3- Bauer Lite https://omnitype.com/products/bauer-lite?variant=42689953366185 (batch 2 should be coming soon)
4- Stellar65 https://spaceholdings.net/products/stellar65?variant=43276168462594#specifications (frosted black version has hotswap in stock)
thank you and please suggest
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: my own top 4 list of relatively budget-friendly 60-65% keyboards
« Reply #1 on: Tue, 05 December 2023, 22:41:50 »
The bauer lite does seem like a really good deal which is neat.
I don't think the tokyo60 is very good though, I would much rather get something else.
In terms of kits, I think the bakeneko60 and 65 is a great budget that's instock option.
https://cannonkeys.com/products/bakeneko-60
https://cannonkeys.com/products/bakeneko65?_pos=1&_sid=1f226b6d3&_ss=r
If you need a hhkb layout, just go on japanese marketplaces and find a real hhkb for a lot cheaper.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Tseg
« Reply #2 on: Wed, 06 December 2023, 18:52:50 »
You mention Neo 65.  Per their website, the last batch (#13) ended 11/28 and no new batch creation has been identified.  Not sure if they are just waiting for new orders to pile up to continue with another batch?
Sale Batch 1~9: Completed
Sale Batch 10: Nov. 1st to Nov. 7th →  Completed
Sale Batch 11: Nov. 8th to Nov. 14th  → Completed -  Orders in fulfillment
Sale Batch 12: Nov. 15th to Nov. 21st  → Completed - Orders waiting for fulfillment
Sale Batch 13: Nov. 22nd to Nov. 28th  →Completed - Orders waiting for fulfillment
The future batches follow a similar pattern.
The sale continues until we determine that the product is no longer competitive enough in the market.
Offline Exquite
  • GeekAnubis
« Reply #3 on: Mon, 18 December 2023, 09:30:45 »
Bauer lite material is so neat. Looks plastic but rigid also.
I'm a Color lover and a designer.
Offline udller
« Reply #4 on: Mon, 18 December 2023, 09:42:11 »
the satalite is instock, like a constelation but cheaper. 200aud
Offline Rhienfo
« Reply #5 on: Mon, 18 December 2023, 10:11:45 »
Satellite does look really good for the price.
Another thing on keyboard treehouse that is really good value is the praxis IM (it's ergo but still a 60%), it's currently on sale right now.
https://keyboardtreehouse.com/collections/all/products/praxis-injected-molded-keyboard-kit
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline matiiska
« Reply #6 on: Wed, 20 December 2023, 00:27:14 »
praxis is also very based for 75 bucks, adding to the list
Offline matiiska
« Reply #7 on: Thu, 21 December 2023, 06:37:08 »
polycarbonate is really neat and innovative. for some reason it doesn't feel cheap like a gmk67 etc, very nice and kudos to omnitype team
Offline Rhienfo
« Reply #8 on: Thu, 21 December 2023, 06:53:06 »
The gmk67 (and other cheap plastic boards) use abs plastic, which is much cheaper than the polycarbonate used for the bauer light. PC is a more durable plastic which is why it's used in a lot of boards. the design may also have an impact, but don't know much about the gmk67 (or the bauer lite for that matter) to know for sure.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline Nebulonix
« Reply #9 on: Fri, 22 December 2023, 03:39:46 »
The Neo65 looks like a solid choice,Thanks for putting this together! :thumb:
Offline Tseg
« Reply #10 on: Fri, 22 December 2023, 08:07:20 »
Looks like Neo65 production still going strong.  Mine should arrive within a week.
Offline SynthoraKB
« Reply #11 on: Mon, 25 December 2023, 03:42:58 »
Awesome job on the list!
Offline garynguyen
    • Tap hoa Phim
« Reply #12 on: Tue, 26 December 2023, 00:58:08 »
How about Enter67 v2? https://www.kezewa.com/products/new-enter-67-keyboard-kit-v2
I have no experience with all 4 that you mentioned above, so I wonder how they compare with Enter67.
AMD 5600X - RX 6600XT
Ducky One 2, Leopold 900RBT
Keychron Q2, Enter67, Tofu65, Sunset80, Wind Z75
