Author Topic: [IC] Terminal 60% HHKB Layout (Rendering Prototype)  (Read 9843 times)
Offline kwk236
« on: Tue, 12 December 2023, 16:55:30 »
Terminal
UPDATE Dec-12-2023
IC Form
Hello everyone, I'm kwk236 from San Francisco!
I'm super excited to share a project that's close to my heart. As a software engineer, I've always been a big fan of the HHKB keyboard layout. This passion led me to create my very own keyboard version, tailored to be the perfect blend of style and functionality. Here's a sneak peek at what makes it special:
1. It's got a cool, minimalist look with a sharp focus on the quality of the metal finishes.
2. Acoustics and typing experience - it must be super satisfying and comfortable. Minimized vibration and reduced high pitch sounds.
3. Great for coding marathons or gaming sessions.
Now, diving into the specs:
* Dimensions: 294mm x 111mm x 20mm x 35mm.
* Typing Angle: 6 degrees.
* Layout Options: Two variants – HHKB and 60%, both accommodated in identically sized cases.
* Mounting System: Poron Gasket Mount style for a seamless feel.
* Detachable Bottom Weight: Brass or Copper
* Material Choices: Aluminum, Titanium, or Stainless Steel
* Metal Finishes: hairline / mirror polish / aerospace
* Space Bar: A centered 7u space bar
* PCB: Custom-designed PCB, but it is also compatible with the h60.
* Dampener: Merino wool felt bottom dampener
* Construction: Internal screws ensure a sleek exterior with no visible holes.
Also, I'm excited to announce that the prototype is in the manufacturing phase. Stay tuned for updates!
IC Form
Discord Community
« Last Edit: Tue, 12 December 2023, 17:22:56 by kwk236 »
Offline mr_foggy
  • neue = nope
Re: [IC] Terminal 60% HHKB Layout (Rendering Prototype)
« Reply #1 on: Tue, 12 December 2023, 17:19:22 »
nice and essential. stainless steel sounds very interesting.
fix ur IC form link tho lol
Offline kwk236
« Reply #2 on: Tue, 12 December 2023, 17:23:38 »
Just fixed it.. thank you :)
Offline nathanchere
« Reply #3 on: Wed, 13 December 2023, 16:59:30 »
If it fits a standard size 60% PCB, what's the point of a custom PCB (other than vanity)? It doesn't look like there's anything happening here to warrant the additional effort, cost and risk of a custom PCB versus a known commodity PCB.
Offline xhxzzh
« Reply #4 on: Wed, 13 December 2023, 18:36:37 »
What is the estimated price?
Offline vhaarr
« Reply #5 on: Wed, 13 December 2023, 23:59:03 »
They're listed in the IC:
Titanium ($1000+)
Stainless Steel ($800+)
Aluminum ($350+)
Which is quite rough, I'm sure the aluminium one could be at least $100 less.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline xhxzzh
« Reply #6 on: Thu, 14 December 2023, 14:01:32 »
Titanium ($1000+)
Aluminum ($350+)
Wow that is insane, was expecting an entry level price like tofu or qk60.
Offline kwk236
« Reply #7 on: Thu, 14 December 2023, 14:40:47 »
Titanium ($1000+)
Aluminum ($350+)
The price is a conservative estimate with everything (brass weight and dampers) packaged together.
I am negotiating with the manufacturers to lower the price. But for the Aluminum, it is very hard to manufacture this below $250 without sacrificing the quality as this is a two piece item with added complexity with gasket mounts. Adding costs for wool felts, brass weight, rubber stops, gaskets, screws, etc... the cost alone is easily $300+.
Now that is under assumption that this will be manufactured in small quantity, the price can go down if there's more demand - I'll keep yall updated on this.
« Last Edit: Thu, 14 December 2023, 16:12:44 by kwk236 »
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #8 on: Sun, 17 December 2023, 10:14:43 »
This is 3 years too late, all the idiots already left the hobby
Clearly you're also 3 years too late to leave.
Offline NSMN
« Reply #9 on: Sun, 17 December 2023, 10:37:09 »
Titanium ($1000+)
Aluminum ($350+)
I want what you are smoking
« Last Edit: Sun, 17 December 2023, 10:41:11 by NSMN »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #10 on: Sun, 17 December 2023, 16:41:22 »
Only idiots watch your stream so can you further explain what's wrong here as well
Offline LMarci
« Reply #11 on: Sun, 17 December 2023, 20:12:00 »
350 entry for this is a tough sell. Also next time don't post an IC until you have a prototype.
Offline diyachronic
« Reply #12 on: Sun, 17 December 2023, 20:53:24 »
Do you have an estimated weight for each of the materials?
Offline kwk236
« Reply #13 on: Sun, 17 December 2023, 20:54:10 »
I am committed to maintaining full transparency and I am not looking for idiots. It's important to me that I avoid making any promises regarding a low price that I cannot uphold. I want to ensure that there are no surprises with sudden price increases later on.
Offline stomaha
« Reply #14 on: Tue, 19 December 2023, 19:37:27 »
I liked this and am comfortable with the higher prices a for premium materials. Thank for pulling this project together.
Offline KrisonB
« Reply #15 on: Thu, 21 December 2023, 05:00:51 »
Are you writing about normal HHKB or your project? You don't have proto so how would you know that it's grate for "coding marathons and gaming"
Offline Nebulonix
« Reply #16 on: Fri, 22 December 2023, 01:05:11 »
Absolutely thrilled about this layout variant. Can't wait to see the final product!
Offline donaldchavez319
« Reply #17 on: Thu, 29 October 2026, 22:37:33 »
The layout is just amazing. I will buy one of them to work on my merinoprotect project.
