Author Topic: [IC] GMK CYL BAE Addon Kits[Update- Pricing for vendors updated,GB on 1st Aug]  (Read 20976 times)
Offline cartersrush
    • Discord
GB thread is LIVE!!
GB- 1st August to 2nd September
Pricing
MOQ of 250 has been met due to Mujimanic(sneakbox) being based and buying it out. All kits will be made  ;D
Dolch & 9009 BAE Kits- $20
WOB, BOW & L9 - $13
Kitting
WOB
BOW
DOLCH
9009
L9 (GMK Black Snail/Pristine/MonoBeige  ;))
Album showing all kits and board renders
IC FORM
Colours
Mostly stock GMK colours are used
WOB- CR Base WS1 legends
BOW- WS1 Base CR legends
9009- U9 Base CR legends 3C Base CR legends 3P Base CR legends
Dolch- N9 dark grey base, CP white legends
Dolch Accent 1- P3 red base, CP white legends
Dolch Accent 2-RAL 180 60 50, CP legends
L9 BAE- L9 base, CR legends
Why?
After growing up using keyboards that had the BAE key, it is sad that it became redundant. I've been in the hobby for years now and there have been countless GB's but only a few had BAE.
So I decided to do this
Why Icon Mod BAE?
Cherry G80-2100 HDU
Because it is cursed beautiful, Just look at it!
Also why not?
Which stablizers would they use?
BAE will work with ANSI stablizers due to a new mould developed for GMK Beige Addon Kits.
Vendors
NA- Sneakbox
UK-Prototypist
EU-Oblotzsky
SEA-Ilumkb
Ocenia - Cafege
India- Neomacro
China-Zfrontier
Korea & Japan-GeonWorks
If you are interested in the project or have any questions reach out to me at @cartersrush on discord!
My Discord for updates & other projects!
Thanks to-
You for reading the IC!
Mcmcmc for making a new mould for GMK BAE possible
Mcmcmc & coolpenguin for all the help & suggestions
Pontus for help with renders
« Last Edit: Wed, 31 July 2024, 21:12:02 by cartersrush »
Offline cartersrush
    • Discord
Re: [IC] GMK BAE Addon Kits
« Reply #1 on: Tue, 09 January 2024, 05:32:40 »
Update 11/03/24
-Vendors added (ongoing)
-Yet to receive quotes from GMK
Update 09/05/24
-More vendors added
-Received quotes from GMK, will update pricing other details etc soonTM
Update 26/07/24
-9009 accents added to Beige BAE kit
-L9 BAE added , it can be used for Black Snail & MonoBeige(soonTM)
-Geon will be taking over for Korea & Japan.
Update 30/07/24
-GB on 1st August. Pricing for most regions updated
« Last Edit: Tue, 30 July 2024, 02:00:50 by cartersrush »
Offline xLeHoy
  • weeb board enjoyer
« Reply #2 on: Tue, 09 January 2024, 05:35:57 »
I am all for it!
GLWIC!
Offline bigoldbox
« Reply #3 on: Tue, 09 January 2024, 05:52:52 »
My hero. :thumb:
Offline tanghus
  • BEIGE GUD
« Reply #4 on: Tue, 09 January 2024, 06:26:31 »
BAEsed.
In!
Offline DirtyGingy
« Reply #5 on: Tue, 09 January 2024, 06:34:24 »
I'll take an all in one kit please.
Offline cartersrush
    • Discord
« Reply #6 on: Tue, 09 January 2024, 07:33:41 »
I added an option to select all in one kit in the IC!
Offline μ
  • dear
« Reply #7 on: Tue, 09 January 2024, 08:11:22 »
Theres multiple types of mounts for BAE. Which does GMK use?
Offline cartersrush
    • Discord
« Reply #8 on: Tue, 09 January 2024, 08:51:00 »
mcmcmc was gracious enough to make text+icon BAE ANSI compatible. I am not sure about Icon Mod BAE, will have to confirm with GMK.
« Last Edit: Tue, 09 January 2024, 15:44:18 by cartersrush »
Offline cartersrush
    • Discord
« Reply #9 on: Tue, 09 January 2024, 10:04:45 »
Offline butre
« Reply #10 on: Tue, 09 January 2024, 11:14:23 »
yes please
Offline pixelpusher
« Reply #11 on: Tue, 09 January 2024, 11:31:14 »
Double checking for clarity...
Use ANSI pbc, put normal switch and stabilizers on Enter, take the spring out of the pipe key switch (and contact leaf if you cannot program to be nothing), and adorn both with BAE?  Is that how it works?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #12 on: Tue, 09 January 2024, 12:54:49 »
In for one of each probably. These are fun. Glad that you're using original Dolch + Dolch R5 colors.
Btw, your text under the beige render is hardly readable with the dark GH theme.
« Last Edit: Tue, 09 January 2024, 12:57:03 by LightningXI »
Offline Guuuf
  • Discord: Guuuf
« Reply #13 on: Tue, 09 January 2024, 13:50:23 »
Oh, I hope I can snag these babies. I will buy them all if they ever get produced.
Born 330 ppm, anonymer Schokoladiker, keyboard enthusiast, age150ramnv8nfx2w740jcqrcewzr88d5xymvqv9asjeamvv0pnad3xqyg8qpt[color]
Offline Meepergon
« Reply #14 on: Tue, 09 January 2024, 14:08:51 »
BAE IS BACK BAEBY
Offline 51p50x
« Reply #15 on: Tue, 09 January 2024, 15:02:21 »
BAE is so nice, GLWIC!
Offline cartersrush
    • Discord
« Reply #16 on: Tue, 09 January 2024, 15:06:00 »
I need confirmation what mounting the Icon mod BAE uses but the text BAE will work with Ansi stabilizers and uses dummy switch in pipe key position so you won't have to remove the switch.
Offline cartersrush
    • Discord
« Reply #17 on: Tue, 09 January 2024, 15:12:35 »
Thank you, dolch is one of my favorite keysets of time  :D
Offline CoolPenguin1
« Reply #18 on: Tue, 09 January 2024, 17:22:00 »
I've found that using a very light spring (like 10-20g) works better than no spring for dummy switches but no spring definitely works too.
Offline Rhienfo
  • GOTHETIGES
« Reply #19 on: Tue, 09 January 2024, 17:22:44 »
Really cool project mate, probably down for wob, dolch and beige if there aren't many extras of the beige addon kit (not the biggest fan of bow, and the one set I have that looks like it isn't CR for the legends, it's more of a grey so it wouldn't match). GLWIC
« Last Edit: Tue, 09 January 2024, 17:24:17 by Rhienfo »
Offline shansoft
« Reply #20 on: Tue, 09 January 2024, 20:07:12 »
OH YES!!!
I would definitely change every single board I have with BAE!! This is one of my favorite thing to do on alps board!
Offline Xury46
« Reply #21 on: Tue, 09 January 2024, 21:26:32 »
Count me in! I've always loved BAE, I recently got one in the DCS WOB GB and I've been so happy to have a custom board with this goofy big-ass key on it.
Offline udller
« Reply #22 on: Tue, 09 January 2024, 21:51:22 »
oh yeahs
Offline Cebrilung
« Reply #23 on: Wed, 10 January 2024, 01:10:45 »
I'm also very curious about this, since AFAIK GMK has a variety of moulds for BAE. Compatibility wise, an ANSI mount with a blank key in Pipe positition would be optimal since virtually all custom keyboards have ANSI support, while ISO support is (unfortunately) less common.
Offline DirtyGingy
« Reply #24 on: Wed, 10 January 2024, 07:57:16 »
so, that older mold you are showing in the flipped over cap is not ANSI compatible...
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #25 on: Wed, 10 January 2024, 08:05:12 »
is this bae-t?
Offline cartersrush
    • Discord
« Reply #26 on: Wed, 10 January 2024, 10:04:05 »
Yes its from the Cherry G80-2100HBU, afaik its the only board that had an Icon mod BAE...
The stab positions are very different from ISO or ANSI.
Offline DirtyGingy
« Reply #27 on: Wed, 10 January 2024, 14:28:47 »
Ah, gotcha. I couldn't tell from the post if that was the icon or the rest of them. If the rest are ANSI compatible, all should be good
Offline udller
Re: [IC] GMK CYL BAE Addon Kits[UPDATE-Added Vendors]
« Reply #28 on: Sat, 23 March 2024, 10:07:21 »
yes please
Offline Kaptain Mike
  • discord: kaptainmike
« Reply #29 on: Sat, 23 March 2024, 11:28:36 »
very good work here :thumb:
Offline dvorcol
  • Discord: dvorcol_5071
« Last Edit: Wed, 31 July 2024, 15:37:36 by dvorcol »
