Author Topic: [GB] MKC65 PCB Gasket Mount Customize Keyboard - Pre-order is now live!  (Read 3999 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hello everyone,
I am so excited to announce that MKC’s second series-MKC65 is now live!
If you are looking for a truly entry-level customized keyboard, I believe it will not disappoint you.
Without further ado, read on for more details about the MKC65 pre-order.
Pre-order Time:
From January 15th to February 15th
Estimated Delivery:
The delivery is expected to be around two months after the pre-order ends.
Due to the influence of the Spring Festival holiday and potential adjustments in the order quantity, there might be a slight variation in the delivery time.
[/color]
MKC65 Variation and Price
MKC65 Pre-Order Page
MKC65 Prototypes
MKC65 Renders
4 E-coat case:E-white, Milky White, Pink, Mint Green
4 Anodized Case: Wine Red, Black, Grey, Silver
Vendor List:
○ US: KeebsForAll
○ US: Cannonkeys
○ Canada: Ashkeebs
○ UK: Prototypist
○ Germany: KEYGEM
○ Italy: Coffeekeys
○ AU: SwitchKeys
○ South Korea: Geonworks
○ Singapore: Mecha.Store
○ Japan: Basekeys
○ Vietnam: MOKB STORE
○ Philippines: Zion Studios
○ Malaysia: Rebult Keyboards
○ Indonesia: KeebsMark
○ Thailand: NTCH Keys
○ Taiwan: PNKeyboard
○ Bangladesh: Cybertronics
○ Chile: Fancy Customs
○ International: Mykeyclub
MKC65 information
Features
○ Compact 65% layout.
○ 6.5° typing angle for a more comfortable typing experience.
○ 100% CNC-machined with 6063 aluminum case.
○ Alu Internal Weight, adding to the overall weight and stability.
○ Simultaneously support two functional modules (Rotary Knob & Light Sign), also compatible with ○ JRIS80 Rotary Knob/LED Light Sign.
○ Three-in-one design with Top Mount, Plate Gasket Mount, and PCB Gasket Mount for an enhanced keyboard experience.
○ Supports tri-mode PCB (Wired, Bluetooth and 2.4ghz).
○ Supports Plate and Plateless Build.
○ Supports Caps Lock Indicator Light.
○ 2 x 2200mha large battery capacity.
MKC65 Specifications
○ Typing angle: 6.5°
○ Front height: 9 mm
○ Material: Full CNC 6063 aluminum
○ Dimension: 319.85*110.3*29.95mm
○ Three-in-one Structure: TOP Mount / Plate Gasket Mount / PCB Gasket Mount
○ QMK/VIA Supported(wired)
○ Support PCB stabilizers
○ Unbuilt Weight
  With PVD WEIGHT: 1.23kg
  With Alu WEIGHT: 1kg
○ Built Weight
  With PVD WEIGHT: 1.45kg
  With Alu WEIGHT: 1.22kg
Three-in-one structure (Top Mount, Plate Gasket Mount, and PCB Gasket Mount)
is a versatile keyboard mounting system that combines the distinctive features of these three structures for comprehensive performance.
Users can customize based on personal preferences and usage scenarios.
○ TOP Mount
○ Plate Gasket Mount
○ PCB Gasket Mount
Support Rotary Knob & LED Light Sign at the same time
The four keys located on the rightmost row of the MKC65 keyboard (Insert, Delete, PgUp, and PgDn keys) can function as a customizable module,
providing the flexibility to arrange and combine a Rotary Knob and Light Sign.
It supports a maximum of two functional modules simultaneously.
For example, 2 * Rotary Knob, 2 * Light Sign, or 1 * Rotary Knob + 1 * Light Sign.
What can you customize for MKC65?
8 Case Options:
○ 4 E-coat case:E-white, Milky White, Pink, Mint Green
○ 4 Anodized Case: Wine Red, Black, Grey, Silver
8 Weight Options:
○ 4 Alu Weight: Gold/ Silver/ Rose Gold/ Black
○ 4 PVD Mirror SS Weight: Gold/ Silver/ Black/ Chroma
5 PCB Options:
○ Wired Flex Cut Hotswap PCB
( 1.2mm, Multi Layout , 7u split spacebar, No Per-key RGB, support QMK and VIA )
○ Wired Non-Flex Cut Hotswap PCB
(1.6mm, Multi Layout, 7u split spacebar, No Per-key RGB, support QMK and VIA )
○ Wired Solder PCB
(1.6mm, Non-Flex Cut, Multi Layout, 7u split spacebar, No Per-key RGB, support QMK and VIA )
○ Wired Per-Key RGB Hotswap PCB
(Add-on only, 1.6mm, Non-Flex Cut, ANSI Layout, support QMK and VIA )
○ Tri-mode Hotswap PCB
(1.2mm, Non-Flex Cut, ANSI Layout, No Per-key RGB, support Mykeyclub Software)
Noted: The Tri-mode technical support is provided by IRISLab.
5 Plate Options:
○ Plateless
○ Flex Cut Plates: FR4, ALU, Brass (Brass Plate Add-on only)
○ Non-flex Cut Plates: PC, POM
Noted: We highly recommend using a PC/ POM/FR4 plate for Tri-mode PCB
because the Brass and ALU plate will have a little affection for connectivity.
What's Included in MKC65?
Full CNC Aluminum Top case *1
Full CNC Aluminum Bottom case *1
Weight (Anodized Alu Weight or Stainless steel PVD Weight) *1
Internal Alu Weight *1
PCB *1
Plateless or Plate *1
IXPE Foam *1
Poron Case Foam *1
Poron Plate Foam *1
Type-C Daughterboard with JST Cable *1
PCB GAS Silicone Column *12
Plate GAS Silicone Sock *18
Top mount screw and spacer *12
PCB stabilizers o-ring *12
Footpad *6
Poron case strip *6
1.5mm hex key *1
Gift(will not send make-up or replacements)
1 MKC Stabilizer Set
1 Type-C Cable
1 Pack of Extra Screw
M2x3mm cylindrical head screw *2
M2x8mm cylindrical head screw *2
M3x5mm countersunk screw *2
1000mha battery (Only for the Tri-mode Version Case) *2
Silicone pad of battery compartment *2
Review links (Stay Tuned for More)
Rx003
바룬 Baroon
Merkeebs
MechTech Keyboards
kittykat mechkey
MCZ Studio
Lattech 라떼크
WhitKeebs
Nicola Sagliano
strawberryjam1986
Zeke DGTL
Simulator Tech
Mykeyclub Team
We are a platform that integrates creativity and innovative design and brings you more fun and cool products.
Please participate in our MKC family for more discussions and future updates.
MKC65 IC form
Mykeyclub discord
Mykeyclub Ins
Best Wishes
Mykeyclub Team
« Last Edit: Sun, 28 January 2024, 19:48:32 by Mykeyclub »
Offline PrizeOcelot5911
Re: [GB] MKC65 PCB Gasket Mount Customize Keyboard - Pre-order is now live!
« Reply #1 on: Mon, 29 January 2024, 01:58:14 »
Placed my order. Excited about finally getting to try out MKC65 (and in a colorway I love, too)! :thumb:
