Author Topic: [IC] KKB Green Alert  (Read 9903 times)
Offline mcmcmc
« on: Sun, 11 February 2024, 18:32:04 »
KKB Green Alert
Hey, green man back at it again. There’s no long explanation needed. This keyset is inspired by IMSTO Irish, and I think Green Alert would be cool. I also love green, trees, grass and frogs.
IC Form
If possible, I hope to make this set in-stock. I will gauge interests using the number of responses and pitch it to vendors.
Did I just see KKB Violet Alert and want to do the same? Yes.
So, please fill out the form if you’re interested.
Details
Material - ABS
Legends - Doubleshot, Tripleshot (shinethroughs) and UV print (sublegends)
Colors - L9, U9, SP VV
Kits
Please keep in mind that this is subject to change, smaller or larger depending on the quotes.
Keyboards
Inspired Midori Turf by Filco
Inspired Frog Keyboard by someone
Discord
Follow more of my projects here.
Thanks
Qarmaa for cool sublegends.
Pontus for cool renders.
You for reading.
« Last Edit: Tue, 28 May 2024, 21:20:40 by mcmcmc »
Offline mcmcmc
Re: [IC] KKB Green Alert
« Reply #1 on: Sun, 11 February 2024, 18:47:46 »
Changes
Color:
SP VV —> RAL 160 30 35
(SA Nuclear Data —> GMK Nuclear Data)
Base kit:
remove r3 pgup r4 pgdn
change to bar 5 and add scoop 5 (kkb doesn’t have nipple)
change to text+icon numpad enter
change alt to alt gr
add 3 key 40s
Addition kit:
change to doubleshot cherry enter (like ka1953)
add accent esc and enter
« Last Edit: Thu, 18 April 2024, 04:58:33 by mcmcmc »
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #2 on: Sun, 11 February 2024, 18:57:07 »
nice
Keyboard Collection: Unikorn, Orion v2.5, Orion v3, Realforce 87u, Viper v3, NMB RT8756CGR, Unicorn x Legend, Das II, TC-V3, Jetfire, Wang 325-3770, Lightpad v2
Keyset Collection: OG Doubleshots, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild
Offline bigoldbox
« Reply #3 on: Sun, 11 February 2024, 19:02:58 »
Hello, is it only the sublegends that are UV printed?
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Sun, 11 February 2024, 19:19:40 »
I love *spinning circle of colors* alert
Offline CoolPenguin1
« Reply #5 on: Sun, 11 February 2024, 20:03:02 »
Looks good :thumb:
Please consider putting a Esc in the alert kit.
Offline mcmcmc
« Reply #6 on: Sun, 11 February 2024, 20:33:42 »
Looks good :thumb:
noted  :thumb:
yes only the sublegends. tripleshot is too expensive.
cherry keys maybe possible to do doubleshot like ka1953, but i’ll have to talk to kkb to comfirm.
« Last Edit: Sun, 11 February 2024, 20:36:41 by mcmcmc »
Offline yz
« Reply #7 on: Sun, 11 February 2024, 21:15:13 »
looks great, hoping to see a SEA vendor for this
Offline mr_foggy
  • land of the worst vendor(s)
« Reply #8 on: Mon, 12 February 2024, 00:01:23 »
damn yes
Offline n1sm0__
« Reply #9 on: Mon, 12 February 2024, 01:12:54 »
YES
FINALLY some more move for retro green set.
Offline VXQN
« Reply #10 on: Mon, 12 February 2024, 02:31:18 »
Niiiice. The only thing I'd recommend is adding some macro keys (I am desperate for KKB to run macro keys in "boring" colours so this may help them decide to do that)
Offline JQ27
« Reply #11 on: Mon, 12 February 2024, 05:07:59 »
I didn't realise the Irish language used ñ and umlauts. Why not call the addon kit US-International rather than Irish? I feel like "Just because it's green" is a lazy excuse in 2024. An actual Irish layout would be mostly the same as UK-ISO with some slight additions like fada over some legends.
Offline mcmcmc
« Reply #12 on: Mon, 12 February 2024, 06:06:45 »
i’m asking kkb for new doubleshot mold moq, let’s see if this is possible. if it doesn’t look bad, i’ll try to bring back gmk macros in kkb too.
Just because it’s green.
Offline tactilesbad
« Reply #13 on: Mon, 12 February 2024, 11:24:27 »
accent esc and enter in base maybe?
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #14 on: Mon, 12 February 2024, 11:40:12 »
3key 40s?
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #15 on: Mon, 12 February 2024, 15:05:15 »
Killer set, I know some people are gonna bang on about (insert color here) alert but I think this one is definitely worth the effort. I also second putting a green Esc. key in the alert kit.
Offline mcmcmc
« Reply #16 on: Mon, 12 February 2024, 17:10:09 »
Offline sirieous
  • help
« Reply #17 on: Mon, 12 February 2024, 17:46:01 »
Wicked, consider DC for OCE vendor
Offline patcoll
  • !40s
« Reply #18 on: Tue, 13 February 2024, 18:08:40 »
ne 40s avail
Offline DennisBytes
« Reply #19 on: Thu, 15 February 2024, 21:00:18 »
Excited for this. I am in for all kits.
Offline macclack
    • Macclack
« Reply #20 on: Mon, 19 February 2024, 22:28:06 »
I like the windowed green cherry key
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #21 on: Mon, 19 February 2024, 22:58:11 »
love the addition kit. this may be my first KKB set.
any issues with the quality of previous KKB sets?
Offline niakulah
« Reply #22 on: Mon, 19 February 2024, 23:24:44 »
That is the best Windows key logo I've seen in a while. If this was blue or purple I'd be all over it.
Offline tactilesbad
« Reply #23 on: Tue, 20 February 2024, 09:22:04 »
xyz alert sets are trending so to speak, I don't think it will be long before we see some other color on beige
seconding blue, too
Offline airs
« Reply #24 on: Mon, 26 February 2024, 12:08:52 »
yes
Octagon v2, LZ CLS
Offline actress
« Reply #25 on: Mon, 26 February 2024, 16:54:59 »
imo tripple shot is worth the extra price if it's possible. UV print feels kinda off somehow
Offline mcmcmc
« Reply #26 on: Tue, 27 February 2024, 06:49:42 »
so far so good. kkb has few inconsistencies compared to gmk, but gmk also has inconsistencies to be fair. if you dont look at keyboard from like 3cm all the time, it’s not a problem. for the price i think it’s pretty damn good. i love their tray too.
i may ask if this is possible, but most likely no. they’re pretty costly.
ne 40s avail
maybe? i’m not gonna promise.
Offline POCO Estudio
« Reply #27 on: Tue, 27 February 2024, 07:48:05 »
i think this color look nice
Offline offbrandbiscuit
« Reply #28 on: Tue, 05 March 2024, 01:08:55 »
I love you so much
Those green Cherry keys are super interesting, easily one of the best Addition kits that I've ever seen
i like fire trucks and moster trucks
Offline fzlo
« Reply #29 on: Tue, 05 March 2024, 02:53:36 »
Irish Green R1 would be great!
Offline jeiem21
« Reply #30 on: Mon, 29 April 2024, 09:30:06 »
Please make this happen as soon as possible!!
Offline Keeaboo
« Reply #31 on: Mon, 29 April 2024, 10:34:02 »
you are COOKING.
