Author Topic: Ibm terminal space saver?  (Read 2841 times)
Offline Infinite north
« on: Wed, 20 October 2010, 01:32:36 »
Offline Half-Saint
« Reply #1 on: Wed, 20 October 2010, 01:43:30 »
Too bad it's a rubber dome...
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline didjamatic
« Reply #2 on: Wed, 20 October 2010, 13:24:36 »
Oh, good to know, I thought it was mechanical for sure.  I was going to go for one.
Offline sethstorm
« Reply #3 on: Wed, 20 October 2010, 18:05:05 »
Quote from: Infinite north;236257
This could be fun for someone wanting to convert a terminal keyboard.
http://cgi.ebay.com/IBM-POS-24-Function-Key-Keyboard-P-N-73X3832-/130445786977?pt=PCA_Mice_Trackballs&hash=item1e5f2cbf61
the 73X**** terminal boards are reported to be all rubber dome.
If you really wanted to convert this rubber dome "unsaver" board, then by all means do get the board.
« Last Edit: Wed, 20 October 2010, 19:24:38 by sethstorm »
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline Shawn Stanford
« Reply #4 on: Wed, 20 October 2010, 18:27:33 »
I've never had an IBM RD, I assume the 'dome' is molded into the top membrane? In other words, it isn't a membrane just like a BS membrane with the rubber dome portion on top of that.
The Brat Prince of COBOL
« Reply #5 on: Wed, 20 October 2010, 20:47:19 »
So, could you theoretically take the guts from a 122-key BS, hack off extra stuff on the right and use this case, membrane and controller?
Offline Half-Saint
« Reply #6 on: Thu, 21 October 2010, 01:34:07 »
For anyone not sure.. check the item specifics, says Rubber membrane right there :)
[SIGPIC][/SIGPIC]
Offline ch_123
« Reply #7 on: Fri, 22 October 2010, 12:14:57 »
They're quite different to the buckling spring version. Lowpoly has one, and reviewed one, so there's pics if you search the part number in the Geekhack search engine. It's like a purpose-built rubber dome keyboard that has the same layout as the buckling spring version.
Offline sethstorm
« Reply #8 on: Sun, 24 October 2010, 15:02:19 »
Quote from: Shawn Stanford;236590
The keyword would be Buckling Spring.  Chopping off a capacitive board would not work.
Current:
