Author Topic: Looking for a vintage compact keyboard  (Read 5166 times)
Offline Setiawan
« on: Wed, 28 February 2024, 01:36:32 »
Looking for my next keyboard, hoping to get some ideas!
Things I’m looking for:
  • Vintage. Either something pre mid-2000’s, or a recreation of an old design.
  • Layout: Roughly 75%. ANSI. Arrow keys present. Function keys highly desirable
  • Colour: preferably the two tone beige/grey colour way.
  • Replaceable keycaps moderately desirable.
  • Tactile key feel preferable, but open to other types.
  • Standard positioning of modifier keys
The closest thing I’ve seen so far is the BTC 5100C. I may very well get it, though it does fall short of my criteria a little. Example, it has arrow keys, but they’re arranged in an L shape rather than T. It takes MX key caps, but has unorthodox sizes. The left control key isn’t in the bottom left corner.
Also been thinking about the F77, except it doesn’t have function keys. Also it’s so big it may as well be 104 keys.
Anyone know of any other keyboards that may interest me?
the quick brown fox jumps over the lazy dog
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: Looking for a vintage compact keyboard
« Reply #1 on: Wed, 28 February 2024, 16:05:48 »
the only 75% vint board that I can remember of the top of my head that fits most of that description is the g80-5000. There are ansi models but they are really expensive from the last I saw of them.
Hope you find what you are looking for.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #2 on: Thu, 29 February 2024, 06:53:52 »
doesn't really match well but i thought i'd mention the Apple M0110A simply because they're relatively cheap if ur lucky ($75 on ebay for my pretty clean example, sent to someone else to get extra clean and lightly lubed, overpaid them cuz i know them and after converting was still well under $150 iirc) and its also one of my favorite boards lol
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline LavenderB
  • I believe in unix control supremacy
« Reply #3 on: Thu, 29 February 2024, 14:10:07 »
You could try looking for a beige IBM space saver keyboard (not to be confused with the space saving keyboard). It uses buckling rubber sleeve switches and is relatively low-profile. The only modern vintage-inspired keyboard I could think of that would suit your requirements is the 68-key version of the Vortex PC66, but that doesn't have function keys.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline wjrii
« Reply #4 on: Sat, 02 March 2024, 16:32:10 »
Are you okay with moving up to TKL?  If so, your options open up, particularly on repro and homage designs.
« Reply #5 on: Sat, 02 March 2024, 17:46:55 »
Does it have to be vintage? I'd think that you could find quite a few modern 75% layout keyboards available with classic beige and grey keycaps if you look. Keychron has a couple, for instance.
« Last Edit: Sun, 03 March 2024, 04:39:10 by Findecanor »
Offline marcusr
« Reply #6 on: Sat, 02 March 2024, 20:18:46 »
Maybe 8BitDo Retro?
Offline Sup
« Reply #7 on: Sat, 02 March 2024, 21:31:55 »
Siig Minitouch comes to mind it uses Alps switches, but not original alps instead they use Hua-Jie AK series
SMK Alps mount. Is it vintage muah 2002-2003 that is still 20 years old at the least.
current
Coming soon
Offline Tribal
« Reply #8 on: Mon, 04 March 2024, 05:49:54 »
How much are you looking to spend?  How loud do you want to be?
An 87u or R2 Realforce TKL would be a quick and easy solution.  The Vortex PC66 in 68-key layout would also be good, or the Leopold FC660C if you look really hard or pay a lot.
Model M and Model F are *really loud.*  Many of the original 80s/90s compact/subcompact keyboards used real or fake white Alps clicky switches.  While not as dominance-asserting as buckling springs, they’re still just, a lot.  The good news is that even soldered alps (which is all of them) are really easy to modify and dampened sliders are available.
True vintage less-than-101 keyboards also tend to have odd modifier placement.
Offline Exquite
  • GeekAnubis
« Reply #9 on: Sun, 10 March 2024, 15:20:30 »
I remember vintage keyboards are all about some huge jack-wide board. Finding a compact one is a bit hard
I'm a Color lover and a designer.
