Author Topic: [IC] Pneuma Mk.2/60 - Interest Check  (Read 15830 times)
Offline antipode-studio
« on: Wed, 06 March 2024, 05:32:45 »
Introduction on the Pneuma from Stef:
The Pneuma is my take on the 60% form factor that I have worked on for the past couple of years. The name "Pneuma" or "πνεῦμα" is a noun used by the ancient Greeks to describe the "Spirit"  or "Soul". It is also used to describe the creative force within humans, a nod to the inspiration I've gotten while designing the board. The board was developed around the design philosophy that a product shall be interesting from three distances: far away, regular usage distance, and up-close.
From afar, the large shapes, soft lines and material finishes invite the user to come closer. Here they can notice the symmetry, balanced weight and design cues like the slightly larger slope of the case that looks like it sucks in the keycaps. Finally, when getting really up-close with the board, tiny details start to stand out like the continuous curvature of the outer edges and the tiny fillets used on the main chamfers to soften the look & feel.
A private GB was held for the Mk.1 design in 2020. It was planned to enter the public GB phase shortly after but was deemed too risky at that point in time due to the pandemic. However, armed with new insights, we improved the Mk.2 in terms of assembly, typing feel, and machinability while staying true to my initial vision for the board.
Changes from the Mk.1:
Mounting changed from poron gasket mounting to o-ring strip gasket mounting.
Plate coverage and stiffness are similar, but gaskets are now removable/replaceable to experiment with different materials and hardnesses.
Overhauled internal construction.
No mid-piece and faceplate but a single bottom piece. This simplifies the complex machining of the Mk.1 design and reduces the number of screws needed to disassemble the board (from 10 to 4) without losing the screwless exterior.
Added internal weight.
To offset the weight from the previously optional stainless steel faceplate/mid-piece in order to increase total weight and cover the daughterboard cable channel.
Introduced Polycarbonate top version.
Due to the new assembly method of the Mk.2, there are no visible screws in the PC top, and all threads remain in the aluminium bottom. The PC top didn't fit the desired design language in the Mk.1 since the screws would be visible.
The design language and ratios have remained the same but refined with continuous curvature on the outer radii, softened edges less prone to damage, and updated logo at the bottom.
Product details:
Specifications:
6.5 degree typing angle
7.5 degree top case angle
Clean seamless construction
23.1mm Adjusted Keyboard Front Height
O-ring strip gasket mount compatibel with 3mm ø cord
6063 Aluminium top/bottom case or option for PC top.
Copper internal weight
Estimated weight: 1.5kg (built)
Compatible with Geon 60% removable rubber feet
QMK/VIA compatible PCB by Martin
Further options and colourways TBD
Plate & PCB:
Default plate compatibility
PCB compatibility
Current sale plans:
Antipode exclusive in-stock, 100-200 planned units, estimated price $299-499 depending on edtion, further details TBD
Visuals:
Prototype Photos:
First round of prototypes:
Second round of prototypes:
Case internals:
Typing tests:
First round prototype with Gateron Oil kings on Alu plate:
First round prototype with Sarokey strawberry wines on Alu plate:
Special thanks to:
The Antipode team, for collaborating with me on my personal dream project and offering a level of collaboration unheard of in this hobby.
All buyers and supporters of the Mk.1 Pneuma, for offering great insights for improvement and their long term support for this project ❤️.
« Last Edit: Thu, 07 March 2024, 02:56:09 by antipode-studio »
Offline keepoto
  • HHKB top for TKL pls
Re: [IC] Pneuma Mk.2/60 - Interest Check
« Reply #1 on: Wed, 06 March 2024, 06:12:53 »
no HHKB? im so sad
Mod Edit: Test
« Last Edit: Mon, 01 April 2024, 12:51:54 by HoffmanMyster »
Offline mvkb
  • Designer
    • MVKB
« Reply #2 on: Wed, 06 March 2024, 06:35:55 »
The long-awaited return! GLWIC
– Typed on a Crushed Orchid Pneuma Mk.1/HHKB
« Reply #3 on: Wed, 06 March 2024, 06:41:38 »
no HHKB? im so sad
HHKB is an option! :)
« Last Edit: Wed, 06 March 2024, 06:48:43 by antipode-studio »
Offline vhaarr
« Reply #4 on: Wed, 06 March 2024, 07:57:32 »
Rocking it with the 60s! I love it! Keep them coming LOL
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline thestrayed
« Reply #5 on: Wed, 06 March 2024, 08:15:06 »
Would love to see PC case and EC support
Offline LMarci
« Reply #6 on: Wed, 06 March 2024, 10:26:06 »
Looks quite nice but would appreciate some pics of the internals :thumb:
Offline The0rigina1
  • fumoposting
« Reply #7 on: Wed, 06 March 2024, 10:31:58 »
Would highly recommend to add pricing before asking if people would be interested in buying it.
Offline amorino
« Reply #8 on: Wed, 06 March 2024, 12:12:07 »
Excited for this one!
Price range is on the post.
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #9 on: Wed, 06 March 2024, 15:22:10 »
Please consider offering a dedicated ISO plate as Antipode has already done i.e. with the Virgo.
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Stewiedk97
  • Professional overcomplicator
« Reply #10 on: Wed, 06 March 2024, 23:13:15 »
Just took images of the internals yesterday. Will be added soon! :)
« Reply #11 on: Thu, 07 March 2024, 02:34:20 »
Here you go!
« Last Edit: Thu, 07 March 2024, 02:53:23 by antipode-studio »
Offline Nascent
« Reply #12 on: Thu, 07 March 2024, 04:22:33 »
Loving the design! I wish there was an option to get extra tops with the kit, just to get an alu and a PC top
Offline Ekish
« Reply #13 on: Thu, 07 March 2024, 04:23:07 »
GLWIC!
Offline keepoto
« Reply #14 on: Thu, 07 March 2024, 04:25:00 »
« Reply #15 on: Thu, 07 March 2024, 10:58:03 »
Based on the photos, does this use a unified daughterboard? If a HS PCB isn't an option, would a standard 65% PCB be compatible?
Sent from my Pixel 8 Pro using Tapatalk
Offline Stewiedk97
« Reply #16 on: Sun, 10 March 2024, 03:50:57 »
A standard pcb won't fit due to the location of the DB connector and the cutouts for the required assembly screw points. But we'll make sure to have plenty for everyone!
« Reply #17 on: Sun, 10 March 2024, 06:14:15 »
Is there a Hotswap PCB option? Also, is the daughterboard a unified daughterboard or proprietary?
Sent from my Pixel 7 Pro using Tapatalk
Offline conternecticus
« Reply #18 on: Sun, 10 March 2024, 11:35:26 »
Love the pc top alu bottom look! Will keep a close eye on this project. GLWIC!
Offline Stewiedk97
« Reply #19 on: Mon, 11 March 2024, 08:12:46 »
No HS pcb planned for now due to the order quantities of the project so we preferred offering more layout flexibility with the solder pcb. However, the solder pcb is compatible with Millmax sockets so you're still able to make it hotswap if you like to have a Hotswap option (I will do this myself as well for 1 build). The daughterboard is a unified one though!
Offline tactilesbad
« Reply #20 on: Tue, 12 March 2024, 03:45:40 »
based
also 299 starting price sounds reasonable, gg
Offline The0rigina1
  • fumoposting
« Reply #21 on: Fri, 15 March 2024, 16:43:26 »
That is literally useless information. Zero mention on what configuration would cost what money.
Offline Stewiedk97
« Reply #22 on: Mon, 18 March 2024, 15:37:56 »
It is still an IC so we are still collection feedback on the options people would like to see. That means we don't have any concrete prices yet, just this range from the prototype orders and earlier quotations as an indication for now. But we will update prices after we've received updated quotations and once we've decided on options and the best way to run the project :)
Offline involuntarysoul
« Reply #23 on: Mon, 18 March 2024, 19:04:36 »
wish the typing angle would be in the 8 degree range
« Reply #24 on: Sat, 30 March 2024, 06:57:26 »
Hi everyone, we have now decided on final colors and pricing for the Pneuma,
More info can be found here: https://www.antipode.studio/collections/pneuma
Plan is to open up a very limited pre-order for the Pneuma at the end of April/Beginning of May.
Stoic and Midnight will be pre-order exclusives color options. WK and HHKB layouts for all colors will also be a pre-oreder exclusive. We will only stock WKL.
if you are interested in the Pneuma, have questions etc feel free to join our discord http://discord.antipode.no
« Reply #25 on: Tue, 30 April 2024, 10:38:56 »
Hi everyone
We have ordered the Pneuma from our manufacturer, however - we still have a few weeks before we have to give them final number on WK and HHKB tops, we are therefor running a pre-order from the 6th till the 12th of May 2024(or until the allocated units have sold out)
More info on colors, materials and layout options here: https://www.antipode.studio/collections/pneuma
Aegis and Midnight will be pre-order exclusives color options. WK and HHKB layouts for all colors will also be a pre-order exclusive. We will only stock WKL. 100 total units have been ordered.
Alexotos will be streaming an Aegis WKL Pneuma build on the 5th of May, Lulzthax will be streaming an Elysium WK build TBA
Join our discord to be kept closely posted on any updates/info and so on. http://discord.antipode.no
« Last Edit: Wed, 01 May 2024, 06:19:44 by antipode-studio »
